    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 160.0k Views 6 Watching
      Manu85 @mumblebaj
      @mumblebaj you are the best !!!
      If you want you can delete the country comnne and can the column headers be “changeable” in French?
      Pld = MJ / W=V / D=N / L=D /
      GF= I think points marked? if that’s it then if possible PM
      GA= I think not cashed? if that’s it then if possible PE
      and for pts no problem
      This is only if it is possible, if it is configurable this would give a possibility of configuration for the countries where your module is installed.
      But you are on top, BRAVO
      • mumblebajM Offline
        mumblebaj Module Developer @Manu85
        @Manu85 I can look at adding a Translation option. The fields are as follows.
        Rank
        Flag
        Team
        Country
        PLD=Played
        W = Win
        D = Draw
        L = Lose
        GF = Goals For
        GA = Goals Against
        Pts = Points
        If you can provide me with the French equivalent then I can add it.
        Still have a bit of work to do on the Previous tables.
          Manu85 @mumblebaj
          @mumblebaj Yes!!! Below is the French translation if you want the diminutives so that it takes up less space, tell me
          Rank = Classement
          Flag = écusson
          Team = équipe
          Country= pays
          PLD=Joué
          W = Gagné
          D = nul
          L = Perdu
          GF = Marqués
          GA = Encaissés
          Pts = Points
          mumblebajM 2 Replies Last reply Reply Quote 0
            @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
            PLD=Joué
            W = Gagné
            D = nul
            L = Perdu
            GF = Marqués
            GA = Encaissés
            Pts = Points
            Are there ay short codes I can use for these? The table will become too big with the full text
            M M 3 Replies Last reply Reply Quote 0
              Manu85 @mumblebaj
              @mumblebaj ok, you can put the following things:
              PLD=J
              W = G
              D = N
              L = P
              GF = MA (if it possible Otherwise M)
              GA = EN (if it possible Otherwise E)
              Pts = Pts
                Manu85 @mumblebaj
                @mumblebaj you can even save a column (if you want) by making a single column of the difference of the points scored and conceded to have the goal-average: GA-GF and this column in French would be called “DIF” :-)
                  manu85340 @mumblebaj
                  @mumblebaj and for the top 14 there are 14 teams, so it would be great to have all 14, thank you again for your work
                    Points
                    You can now do an update. Please take note of the requirements. You need to register for an API-KEY on API-SPORTS. Check the readme for new settings.
                      Manu85 @mumblebaj
                      @mumblebaj ok, I will try this as soon as I get home, I will let you know, thanks again
                        Manu85 @mumblebaj
                        @mumblebaj Hello when I go to the API-SPORTS site I have a page where I have a link for api rugby but when I click on the link the page returns me an error code, perhaps I am not in the right place , I need your help please, below is the link to the api-sports page and this from api rugby
                        https://api-sports.io/
                        API-SPORTS: https://v1.rugby.api-sports.io/
                          Manu85 @mumblebaj
                          @mumblebaj sorry I didn’t see that in the readme there was a link… I registered and when I am on the page I have several api sports when I click on api-rugby nothing happens
                            @Manu85 Check under account and then my access. You should see if you have a key. If not then create one.
                            If you already have one then you should see it here.
                            If you do not have one yet then scroll down and click subscribe next to Rugby.
                              Manu85 @mumblebaj
                              @mumblebaj ok, thank you very much, I got there, I have a few questions to ask you I will do that tomorrow because it must be dark at your place too!
                                Manu85 @mumblebaj
                                @mumblebaj Hello, I hope you are well my first question is the following I cannot get the “Six Nations” I first thought that on your example in the readme there was “Six Nations 2024” and in the leage_data.json was “Six Nations” but it didn’t work then I saw the line:
                                apiSportStandingLeagueId: 16
                                ```, was on 16 (top 14) I tried to delete this line but the mirror does not start I tried to put "0" at the end but that does not work either
                                I changed the line:
                                sport: "mru",
                                by
                                sport: "mrs",
                                but it's the same
                                I'm trying to follow my config.js if you could tell me where the problem is please?
                                        		module: "MMM-Rugby",
                                        		disabled: false,
                                                        updateInterval: 1000*60*60*24,
                                                        rotateInterval: 60000,
                                                        sport: "mrs",
                                                        rankingLimit: 14,
                                                        matchesLimit: 10,
                                                        matchesOlderThan: 7,
                                                        competitions: ["Top 14","Six Nations"],
                                                        collectionType: "apiSport", // api-key required
                                                        apiSports: {
                                                            apiSportStandingLeagueId: 16,
                                                            apiSportKey: "beb4f679043bxxxxxxxxxxxxxxxxxxxx",
                                                            apiSportTZ: "Europe/Paris",
                                                            numberofGamesToDisplay: 10,
                                                            apiSportsNumRankings: 10,
                                                            apiSportDaysPast: 7,
                                                            apiSportsDaysFuture: 14
                                  module: “MMM-Rugby”,
                                  position: “top_right”,
                                  disabled: false,
                                  updateInterval: 10006060*24,
                                  sport: “mrs”,
                                  rankingLimit: 14,
                                  matchesLimit: 10,
                                  competitions: [“Top 14”,“Six Nations”],
                                  collectionType: “apiSport”, // api-key required
                                  apiSports: {
                                  apiSportKey: “beb4f679043bxxxxxxxxxxxxxxxxxxxx”,
                                  apiSportTZ: “Europe/Paris”,
                                  The competitions are used for free only and not for apiSports. If you want to see six nations on apiSports then you need to specify it’s leagueId in the apiSportStandingLeagueId, which is 51.
                                  The free api does not have a Top 14 that I could find.
                                  I will update the example configs for both in a bit.
                                  Example Config for free
                                          		disabled: false,
                                                          sport: "mrs",
                                                          rankingLimit: 14,
                                                          matchesLimit: 10,
                                                          competitions: ["Six Nations", "Rugby Europe Trophy 2024"],
                                                          collectionType: "free"
                                  Example Config for apiSports:
                                          		disabled: false,
                                                          rankingLimit: 14,
                                                          matchesLimit: 10,
                                                          apiSports: {
                                    @mumblebaj do you think that in apisports I can put the top 14 and six nations so that they are displayed in the module?
                                      mumblebaj Module Developer @manu85340
                                      @manu85340 Hi, no, the apiSports API only takes a single league as input.
                                        Manu85 @mumblebaj
                                        @mumblebaj shit ! Do you think it is possible to remove the lines of rows and columns that look like an Ecxel table? and I think it would be preferable to make a single column of the difference of the points scored and conceded to have the goal-average: GA-GF, it would be clearer to read and it would take up less space, thank you, I think your module is going to be a real success
                                          Manu85 @mumblebaj
                                          @mumblebaj Hi ! it could look like this without column “B” which indicates the offensive and defensive bonuses
                                            @Manu85 You can set the below in your css/custom.css which would eliminate the borders if you prefer not to see them.
                                            .MMM-Rugby #MMMRugby-rankingTable td,
                                            .MMM-Rugby #MMMRugby-rankingTable th,
                                            .MMM-Rugby #rankingMatchesTable td,
                                            .MMM-Rugby #rankingMatchesTable th {
                                              border: none;
                                            Do you mean you would prefer to see a Goal difference and not the Goals For and Goals Against columns?
                                            • 2 / 6
