    MMM-CalendarExt3 color formatting
    15 Posts 6 Posters 7.6k Views 7 Watching
      A Former User @MMRIZE
      @MMRIZE I’m not concerned about the keyword transformation custom color going through. What I am really trying to figure out is why the original colors that I assign (#385723 for ‘holidays’, and #7030A0 for ‘Family’) are not showing up on the CalendarExt3 Module. The symbols are passing properly, even the keyword transform for “birthday-cake”, but none of the colors are passing.
        sdetweil @Guest
        @jlward73 as the data is broadcast to all modules, you could install one of the notification modules and look at the event data to see what is there
        also try “red” or “green” as the color, altho that shouldn’t matter
          MMRIZE @Guest
          @jlward73
          About the style of event;
          The default styles are like these;
          • Singleday Event (start and end in one day)
            • symbol : calendarColor
            • text : white (defaultColor)
            • background : none
          • Fullday Event & Multiday Event
            • background : calendarColor
            • symbol & text : white or black (oppositeColor) / oppositeColor is calculated by calendarColor to get more visibility by contrast.
          So, I think you are asking text of singleday event. To be honest, I don’t like the colorful text, so it is not considered in the default style.
          However, of course, you can override it.
          /* In your custom.css */
          .CX3 .event.singleday .headline .title,
          .CX3 .event.singleday .headline .time {
            color: var(--calendarColor);
          Then you can get this.
            A Former User @sdetweil
            @sdetweil How do I do that? As I’m reading the posts from you and MMRIZE, I feel like the code is right in my default calendar and in the css file for CalendarExt3, but maybe the color property is not being broadcast, so I would like to check that.
              sdetweil @Guest
              @jlward73 look in the 3rd party modules list for one that shows the notifications in the developers window (ctrl-shift-i, select the console tab)
                MMRIZE @Guest
                @jlward73
                https://github.com/MMRIZE/MMM-LogExt
                You can track Frontend logs and notifications in the backend log with ease.
                • BKeyportB Offline
                  BKeyport Module Developer @MMRIZE
                  Why aren’t you guys using the transformer?
                  eventTransformer: (ev) => {
                  					if (ev.title.search("🏠") > -1) {
                  						ev.title = ev.title.replace("🏠 Personal Commitment", "🏠 Personal Event");
                  						ev.color = 'yellow';
                  					if (ev.title.search("✈ Flight") > -1) {
                  						ev.title = ev.title.replace("✈ Flight", "🏠 Personal Event");
                  					if (ev.title.search("busy") > -1) {
                  						ev.title = ev.title.replace("busy", "🏠 Mom Event");
                  					if (ev.title.search("Weekley") > -1) {
                  						ev.title = ev.title.replace("Weekley", "Weekly");
                  					return ev
                  • Z Offline
                    ZiggidyZ
                    I understand 100% what you are saying, I had this same issue. What you are experiencing is the DEFAULT of CX3, that is how it looks if you don’t edit anything. By default the ICON next to the event will be the color you configured, but the event text will all be white. To change this you will need to edit your CUSTOM css file, DO NOT edit the css file inside of the module. I started off making that same mistake. The trouble in doing that, is that when a module gets updated, you lose anything you did. The customizations should be done in that custom.css file and should be backed up. Copy the code below into your ~MagicMirror/css/custom.css file, save, then refresh the browser window (I use the MMM-Remote-Control to refresh mine remotely), and you should see it load with the colors you configured in the default calendar module.
                    * CalendarExtende3 */
                    /* Sets event titles to configured color */
                    .CX3A .event .description {
                      display: none;
                    .CX3A .event .location {
                      display: none;
                    I have 10 different calendars which my default calendar loads, all of which are displayed in CX3 with no issues.
                      A Former User
                      So I figured out what the problem was, and it was much simpler than I suspected. For some reason, in my default calendar module, I used
                      module: 'calendar' instead of module: "calendar" in the config file. When I ran npm run config:check, it made me change many of my quotation marks to “correct” the syntax. When I went through and changed everything to the double quotes, the color coding passed through to CalendarExt3 just as expected/designed. Now, I think I can go through and tweak the single day events as MMRIZE was suggesting to match my background pictures so they stand out appropriately for my set up. Thank you for all the guidance.
                      G S 2 Replies Last reply Reply Quote 0
                      • G Offline
                        greedyvegan @Guest
                        @jlward73 said in MMM-CalendarExt3 color formatting:
                        So I figured out what the problem was, and it was much simpler than I suspected. When I ran npm run config:check, it made me change many of my quotation marks to “correct” the syntax.
                        whenever I run con fig check, it just says syntax error and I gotta figure what the issue is and it’s usually a missing comma.
                        What do I have to do to get config check to diagnose the exact issue?
                          sdetweil @greedyvegan
                          @greedyvegan said in MMM-CalendarExt3 color formatting:
                          config check cannot get any closer…
                          it ‘compiles’ the source, and dies when it discovers something incorrect.
                          it cannot tell WHY it is incorrect… that is a human thing
                          all it can say is ‘here’ is bad. and this is the logical error I encountered. (‘unexpected token’ for example)
                          • G Offline
                            greedyvegan @sdetweil
                            ok, thank you.
                            I may have misread what he wrote.
                              sdetweil @Guest
                              @jlward73 many times the content pasted into the forum does not use a code wrapper.
                              when this happens, the content is assumed to be word processing ( ms word or like), and the double and single quotes are changed to match (curved)
                              zoom in on these two sets of quotes
                              JavaScript uses text mode, (quotes are vertical not curved) and freaks out when encountering the word processing quotes, as they don’t match anything expected.
