    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 14.4k Views 3 Watching
      drx1984 @sdetweil
      @sdetweil what do you mean by LSR? what does that mean?
      I have now done this:
      Of course, with “npm run server” it runs in the browser.
      but how do I do it natively on the computer itself? When I enter the command “npm run start” there is an error in the cmd, something with the display.
      I wonder if I did everything correctly, as you described it.
        @drx1984 DISPLAY… you didn’t follow all the instructions …
        see https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
        LSR (you can install the linux system runtime under windows too) …
          sdetweil @drx1984
          @drx1984 said in MagicMirror stutters and doesn't run smoothly:
          i don’t understand your question…
          MM is a browser app.
          it runs in Electron, (default), Chromium, Firefox, Edge, Safari, Midori, …
            drx1984 @sdetweil
            @sdetweil oh yes sry, I saw it, ok now I have adapted the Package.jason and it is now running.
            Did I do that correctly with the mm.cmd file so that the GPU is active? It still stutters or the clock module is also lagging behind :-(
            Do you speak German too?
              sdetweil @drx1984
              @drx1984 I don’t speak German, but can use translators to read/reply.
              I mislead you, for Windows to set the env variable you have to use set
              set ELECTRON_ENABLE_GPU=1
                drx1984 @sdetweil
                @sdetweil So you mean?
                …unbelievable does it require so much power? of the stottort anyway.
                the IntelNuc is powerful enough, right?
                S B 2 Replies Last reply Reply Quote 0
                  sdetweil @drx1984
                  @drx1984 yes, set ELECTRON_ENABLE_GPU=1
                  powerful enough? I do not know…
                  drawing lots of things on the screen takes lots of power. the screen is very slow compared to the processor…
                  I don’t run either of those module.
                    drx1984 @sdetweil
                    @sdetweil yes certainly more than a Raspi 4 or 5.
                    then are the script and path correct?
                    I don’t notice any difference and it still stutters.
                      sdetweil @drx1984
                      @drx1984 yes, looks OK.
                      I would try to run one module at a time
                      to disable the other, add
                      disabled: true,
                      after the module: line
                      so you don’t have to redo config.js
                      we don’t officially support Windows, so I don’t know if you have to do something else to enable gpu for electron.
                      you could try running under edge, at
                      http://localhost:8080
                        drx1984 @sdetweil
                        @sdetweil yes, I have already tried the exact same configuration under Linux. > unfortunately it stutters there too.
                        That’s why I thought I’d try it on Windows level.
                        I will probably install Ubuntu on the Intelnuc again >because Windwos is not official, as you say.
                        But I don’t think it will stutter anymore, unfortunately.
                          sdetweil @drx1984
                          @drx1984 well, you tried before enabling the GPU on linux so I still think the best approach is to test with one module at a time… globe alone, rain alone. see what they do
                          then enable the other…
                            bhepler Module Developer @drx1984
                            I don’t think so. It’s the MMM-Globe module. It’s pure javascript and doesn’t make use of the graphics hardware at all. You might get away with turning off the MMM-Rain and running just the globe module. Might.
                            I really should get around to rewriting it.
                              drx1984 @bhepler
                              @bhepler
                              Good morning, I have now deactivated MMM Rain. The Globle module is still shaking/stuttering a bit.
                              I have already set the parameter “export ELECTRON_ENABLE_GPU=1” in the mm.sh file.
                              But yes then the Globle module should also have GPU support.
                              Can you fix that?
                                @drx1984 - Yeah, I can. It’s on the list of projects. I don’t know when I’ll get to it. For you I’ll bump it up the priority list a bit. But I don’t have an estimate.
                                  drx1984 @bhepler
                                  @bhepler said in MagicMirror stutters and doesn't run smoothly:
                                  Good morning,
                                  aha ok, thank you very much, yes that would be very good.
