    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 15.7k Views 3 Watching
      sdetweil @drx1984
      @drx1984 if you are running under windows native… you don’t need to run in lsr
      if you ARE running under lsr, then u need the ‘export’
      just open cmd.exe and follow instructions in doc…
      have to manually install nodejs on windows and git.
      then a windows mm.cmd file
      @echo off
      cd %home%\MagicMirror
      ELECTRON_ENABLE_GPU=1
      npm start
      then execute
      %home%\mm.cmd
      D 1 Reply Last reply
        drx1984 @sdetweil
        @sdetweil what do you mean by LSR? what does that mean?
        I have now done this:
        Of course, with “npm run server” it runs in the browser.
        but how do I do it natively on the computer itself? When I enter the command “npm run start” there is an error in the cmd, something with the display.
        I wonder if I did everything correctly, as you described it.
          @drx1984 DISPLAY… you didn’t follow all the instructions …
          see https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
          LSR (you can install the linux system runtime under windows too) …
            sdetweil @drx1984
            @drx1984 said in MagicMirror stutters and doesn't run smoothly:
            i don’t understand your question…
            MM is a browser app.
            it runs in Electron, (default), Chromium, Firefox, Edge, Safari, Midori, …
              drx1984 @sdetweil
              @sdetweil oh yes sry, I saw it, ok now I have adapted the Package.jason and it is now running.
              Did I do that correctly with the mm.cmd file so that the GPU is active? It still stutters or the clock module is also lagging behind :-(
              Do you speak German too?
                sdetweil @drx1984
                @drx1984 I don’t speak German, but can use translators to read/reply.
                I mislead you, for Windows to set the env variable you have to use set
                set ELECTRON_ENABLE_GPU=1
                  drx1984 @sdetweil
                  @sdetweil So you mean?
                  …unbelievable does it require so much power? of the stottort anyway.
                  the IntelNuc is powerful enough, right?
                  S B 2 Replies Last reply
                    sdetweil @drx1984
                    @drx1984 yes, set ELECTRON_ENABLE_GPU=1
                    powerful enough? I do not know…
                    drawing lots of things on the screen takes lots of power. the screen is very slow compared to the processor…
                    I don’t run either of those module.
                      drx1984 @sdetweil
                      @sdetweil yes certainly more than a Raspi 4 or 5.
                      then are the script and path correct?
                      I don’t notice any difference and it still stutters.
                        sdetweil @drx1984
                        @drx1984 yes, looks OK.
                        I would try to run one module at a time
                        to disable the other, add
                        disabled: true,
                        after the module: line
                        so you don’t have to redo config.js
                        we don’t officially support Windows, so I don’t know if you have to do something else to enable gpu for electron.
                        you could try running under edge, at
                        http://localhost:8080
                          drx1984 @sdetweil
                          @sdetweil yes, I have already tried the exact same configuration under Linux. > unfortunately it stutters there too.
                          That’s why I thought I’d try it on Windows level.
                          I will probably install Ubuntu on the Intelnuc again >because Windwos is not official, as you say.
                          But I don’t think it will stutter anymore, unfortunately.
                            sdetweil @drx1984
                            @drx1984 well, you tried before enabling the GPU on linux so I still think the best approach is to test with one module at a time… globe alone, rain alone. see what they do
                            then enable the other…
                              bhepler Module Developer @drx1984
                              I don’t think so. It’s the MMM-Globe module. It’s pure javascript and doesn’t make use of the graphics hardware at all. You might get away with turning off the MMM-Rain and running just the globe module. Might.
                              I really should get around to rewriting it.
                                drx1984 @bhepler
                                @bhepler
                                Good morning, I have now deactivated MMM Rain. The Globle module is still shaking/stuttering a bit.
                                I have already set the parameter “export ELECTRON_ENABLE_GPU=1” in the mm.sh file.
                                But yes then the Globle module should also have GPU support.
                                Can you fix that?
                                B 1 Reply Last reply
                                  @drx1984 - Yeah, I can. It’s on the list of projects. I don’t know when I’ll get to it. For you I’ll bump it up the priority list a bit. But I don’t have an estimate.
                                    drx1984 @bhepler
                                    @bhepler said in MagicMirror stutters and doesn't run smoothly:
                                    Good morning,
                                    aha ok, thank you very much, yes that would be very good.
