    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 15.9k Views 3 Watching
      drx1984 @sdetweil
      @sdetweil So you mean?
      …unbelievable does it require so much power? of the stottort anyway.
      the IntelNuc is powerful enough, right?
      S B 2 Replies Last reply
        sdetweil @drx1984
        @drx1984 yes, set ELECTRON_ENABLE_GPU=1
        powerful enough? I do not know…
        drawing lots of things on the screen takes lots of power. the screen is very slow compared to the processor…
        I don’t run either of those module.
        D 1 Reply Last reply
          drx1984 @sdetweil
          @sdetweil yes certainly more than a Raspi 4 or 5.
          then are the script and path correct?
          I don’t notice any difference and it still stutters.
            sdetweil @drx1984
            @drx1984 yes, looks OK.
            I would try to run one module at a time
            to disable the other, add
            disabled: true,
            after the module: line
            so you don’t have to redo config.js
            we don’t officially support Windows, so I don’t know if you have to do something else to enable gpu for electron.
            you could try running under edge, at
            http://localhost:8080
              drx1984 @sdetweil
              @sdetweil yes, I have already tried the exact same configuration under Linux. > unfortunately it stutters there too.
              That’s why I thought I’d try it on Windows level.
              I will probably install Ubuntu on the Intelnuc again >because Windwos is not official, as you say.
              But I don’t think it will stutter anymore, unfortunately.
                sdetweil @drx1984
                @drx1984 well, you tried before enabling the GPU on linux so I still think the best approach is to test with one module at a time… globe alone, rain alone. see what they do
                then enable the other…
                  bhepler Module Developer @drx1984
                  @drx1984 said in MagicMirror stutters and doesn't run smoothly:
                  I don’t think so. It’s the MMM-Globe module. It’s pure javascript and doesn’t make use of the graphics hardware at all. You might get away with turning off the MMM-Rain and running just the globe module. Might.
                  I really should get around to rewriting it.
                    drx1984 @bhepler
                    @bhepler
                    Good morning, I have now deactivated MMM Rain. The Globle module is still shaking/stuttering a bit.
                    I have already set the parameter “export ELECTRON_ENABLE_GPU=1” in the mm.sh file.
                    But yes then the Globle module should also have GPU support.
                    Can you fix that?
                    B 1 Reply Last reply
                      @drx1984 - Yeah, I can. It’s on the list of projects. I don’t know when I’ll get to it. For you I’ll bump it up the priority list a bit. But I don’t have an estimate.
                        drx1984 @bhepler
                        @bhepler said in MagicMirror stutters and doesn't run smoothly:
                        Good morning,
                        aha ok, thank you very much, yes that would be very good.
