    MMM-NewsFeedTicker.
    21 Posts 4 Posters 6.7k Views 4 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      Is there a missing component in the MMM-NewsFeedTicker. I’ve installed it twice, one two different machines and it stopped MM in its tracks. Put in modules folder as required, copied config.js module block and put in config folder.
      No settings changes, launched MM and got black screen. Pulled section of config.js back out, restarted, black screen.
      Deleted MMM-NewsFeedTicker from modules folder. Everything back to normal.
      Tried to launch dev tools but while window came up, there was an error message where normally would be css code, etc.
        sdetweil @ankonaskiff17
        @ankonaskiff17 remember that we deleted old libraries in 2.16 , many modules didn’t document that they were needed, and SO, we end up with a crash
        see the messages where u start MM, and look for ‘module not found’ and then npm install those in the MM folder …
        probably one of
        request
        rrule-alt
        valid-url
        • G Offline
          greedyvegan
          @sdetweil said
          request
          rrule-alt
          valid-url
          this still doesn’t work
            sdetweil @greedyvegan
            @greedyvegan show me the messages from mm npm start
            • G Offline
              greedyvegan @sdetweil
              @sdetweil show me the message from npm start
              after starting mm v2.26.0 it says
              loading config…
              [DEBUG] config template file not exists, no envsubst
              loading module helpers…
              no helper found… initializing new module helper
              then…
                @greedyvegan that says you have an instance running already, do
                pm2 status
                then
                pm2 stop all
                then
                pm2 start  xx
                xx is the number or name on the row
                • G Offline
                  which row?
                    @greedyvegan share the output of
                    pm2 status
                    • G Offline
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 0 │ MagicMirror │ fork │ 29 │ stopped │ 0% │ 0b │
                      │ 2 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
                      │ 1 │ run-start │ fork │ 0 │ stopped │ 0% │ 0b │
                        @greedyvegan hm…
                        run this
                        ps -ef | grep  MagicMirror  | awk '{print $2}` | xargs sudo kill  -9
                        the. try. npm start
                        G 2 Replies Last reply Reply Quote 0
