    MMM-NewsFeedTicker.
    21 Posts 4 Posters 8.7k Views 4 Watching
    • G Offline
      greedyvegan
      @sdetweil said
      request
      rrule-alt
      valid-url
      this still doesn’t work
        sdetweil @greedyvegan
        @greedyvegan show me the messages from mm npm start
        • G Offline
          greedyvegan @sdetweil
          @sdetweil show me the message from npm start
          after starting mm v2.26.0 it says
          loading config…
          [DEBUG] config template file not exists, no envsubst
          loading module helpers…
          no helper found… initializing new module helper
          then…
            @greedyvegan that says you have an instance running already, do
            pm2 status
            then
            pm2 stop all
            then
            pm2 start  xx
            xx is the number or name on the row
            • G Offline
              which row?
                @greedyvegan share the output of
                pm2 status
                • G Offline
                  │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                  │ 0 │ MagicMirror │ fork │ 29 │ stopped │ 0% │ 0b │
                  │ 2 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
                  │ 1 │ run-start │ fork │ 0 │ stopped │ 0% │ 0b │
                    @greedyvegan hm…
                    run this
                    ps -ef | grep  MagicMirror  | awk '{print $2}` | xargs sudo kill  -9
                    the. try. npm start
                    G 2 Replies Last reply Reply Quote 0
                    • G Offline
                      nothing happened after that, it returned “>” and the cursor
                      • G Offline
                        the module just says loading, I’m going to delete it and use the regular newsfeed instead, thanks.
                        by the way, is there a way that I can add an icon/image to the default newsfeed module?
                        • logo of the news source
                        • photo from the article
                          @greedyvegan I am not aware of those features in the default newsfeed module
                            @greedyvegan correct … Linux commands in general return nothing on success. they were designed in the old teletype terminal days
                              @greedyvegan you can try the MMMNewsfeedTicker module again…
                              at least it should work… I accepted the changes as I was a collaborator on that
                              G 1 Reply Last reply Reply Quote 1
                              • G Offline
                                thank you, I’m going to try it now
                                • G Offline
                                  greedyvegan @greedyvegan
                                  @greedyvegan said in MMM-NewsFeedTicker.:
                                  I tried it and didn’t like it, so I removed it.
                                  thank you.
                                  • K Offline
                                    KiaSohc
                                    Hi there,
                                    Sorry to jump in to this. I have the very same issue where the NFT module only shows “Loading” but never shows any feed. This was working perfectly fine for a long time before I ran an update (git pull) for the module today.
                                    A bit more info…
                                    • I am still on npm 6.14.11 and unable to upgrade due to the nodejs 10.24.0 compatibility issue.
                                    Could it be because I am still on an old npm version?
                                    Many Thanks!
                                      sdetweil @KiaSohc
                                      @KiaSohc well, you probably needed to do npm install in the module folder too after git pull
                                      • K Offline
                                        KiaSohc @sdetweil
                                        @sdetweil Sorry forgot to mention that. Yes, I did ran npm install after git pull but it just shows “Loading…”.
                                          sdetweil @KiaSohc
                                          @KiaSohc loading is the default message while waiting for data
                                          so we need to look at the output of npm start
                                          if you use pm2 to launch MagicMirror then you need to do
                                          pm2 logs --lines=50
