    MMM-NewsFeedTicker.
    21 Posts 4 Posters 6.8k Views 4 Watching
    • G Offline
      greedyvegan
      @sdetweil said
      request
      rrule-alt
      valid-url
      this still doesn’t work
        sdetweil @greedyvegan
        @greedyvegan show me the messages from mm npm start
        • G Offline
          greedyvegan @sdetweil
          @sdetweil show me the message from npm start
          after starting mm v2.26.0 it says
          loading config…
          [DEBUG] config template file not exists, no envsubst
          loading module helpers…
          no helper found… initializing new module helper
          then…
            @greedyvegan that says you have an instance running already, do
            pm2 status
            then
            pm2 stop all
            then
            pm2 start  xx
            xx is the number or name on the row
            • G Offline
              which row?
                @greedyvegan share the output of
                pm2 status
                • G Offline
                  │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                  │ 0 │ MagicMirror │ fork │ 29 │ stopped │ 0% │ 0b │
                  │ 2 │ mm │ fork │ 0 │ stopped │ 0% │ 0b │
                  │ 1 │ run-start │ fork │ 0 │ stopped │ 0% │ 0b │
                    @greedyvegan hm…
                    run this
                    ps -ef | grep  MagicMirror  | awk '{print $2}` | xargs sudo kill  -9
                    the. try. npm start
                    G 2 Replies Last reply Reply Quote 0
                    • G Offline
                      nothing happened after that, it returned “>” and the cursor
                      • G Offline
                        the module just says loading, I’m going to delete it and use the regular newsfeed instead, thanks.
                        by the way, is there a way that I can add an icon/image to the default newsfeed module?
                        • logo of the news source
                        • photo from the article
