    Module for MagicMirror forum
    8 Posts 3 Posters 2.2k Views 3 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer
      The forum has an API. Has anyone built a module for it? One could display unread messages (https://forum.magicmirror.builders/api/unread) and/or notifications (https://forum.magicmirror.builders/api/notifications) for example.
      bugsounetB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @KristjanESPERANTO
        @KristjanESPERANTO you need a token, you can’t do something without it
        Only admin can send it
        karsten13K 1 Reply Last reply
        • karsten13K
          karsten13 @bugsounet
          some api urls seem to work without authentication, e.g.
          ❯ curl -s https://forum.magicmirror.builders/api/recent/posts/day | jq -r '.[].topic.title'
          Default Weather Module Icon Position
          MMM-Formula1 updates
          Live phone location
          Refresh Magic Mirror after custom css changes
          MMM-QuotesFromReddit
          • karsten13K
            karsten13 @karsten13
            the use of a csrf token is restricted to admins (as already mentioned by @bugsounet), there is a hack described here to open this for all users but I don’t think we should do this.
            For accessing the read(-only) api you can use a cookie from your browser, e.g.
            curl --cookie "express.sid=xxxxxxx" https://forum.magicmirror.builders/api/unread
            but this would be challenging to use in a module for mm …
            • bugsounetB
              bugsounet Banned @karsten13
              best way is using RSS
              like this
              KristjanESPERANTOK 1 Reply Last reply
                KristjanESPERANTO Module Developer @bugsounet
                @bugsounet Okay, that’s nice. But is it possible to get unread messages or notifications using RSS?
                • bugsounetB
                  nop it’s not possible
                  read api doc
                  The API key is managed from the admin panel
                  It is given so that the user has access to it for external use
                  I don’t think that Veeck and @karsten13 will send it ;)
                  That why best way is using recent only by rss
                  my first js approach:
                  let Parser = require('rss-parser');
                  let parser = new Parser();
                  let rss = "https://forum.magicmirror.builders/recent.rss";
                  (async () => {
                    let feed = await parser.parseURL(rss);
                    feed.items.forEach(item => {
                      console.log(item.title + ' --> ' + item.link)
                  Result:
                  bugsounet@Kubuntu:~/test$ node test
                  Module for MagicMirror forum --> https://forum.magicmirror.builders/topic/18611/module-for-magicmirror-forum
                  MMM-Formula1 updates --> https://forum.magicmirror.builders/topic/18608/mmm-formula1-updates
                  Default Weather Module Icon Position --> https://forum.magicmirror.builders/topic/18484/default-weather-module-icon-position
                  Live phone location --> https://forum.magicmirror.builders/topic/18612/live-phone-location
                  Ability to display certain modules at certain times of the year? --> https://forum.magicmirror.builders/topic/18613/ability-to-display-certain-modules-at-certain-times-of-the-year
                  Yahoo Fantasy Sports? --> https://forum.magicmirror.builders/topic/18614/yahoo-fantasy-sports
                  A shopping list model that is integrated with Google Assistant --> https://forum.magicmirror.builders/topic/18606/a-shopping-list-model-that-is-integrated-with-google-assistant
                  MMM-DHT22 --> https://forum.magicmirror.builders/topic/17978/mmm-dht22
                  Refresh Magic Mirror after custom css changes --> https://forum.magicmirror.builders/topic/18609/refresh-magic-mirror-after-custom-css-changes
                  MMM-QuotesFromReddit --> https://forum.magicmirror.builders/topic/4440/mmm-quotesfromreddit
                  set the calendar day to a short version --> https://forum.magicmirror.builders/topic/18610/set-the-calendar-day-to-a-short-version
                  New icons not showing up - default MM-Weather modules --> https://forum.magicmirror.builders/topic/17983/new-icons-not-showing-up-default-mm-weather-modules
                  [MMM-OnThisDayWikiApi] - Get Wikipedia's OnThisDay using the Wikimedia API --> https://forum.magicmirror.builders/topic/18261/mmm-onthisdaywikiapi-get-wikipedia-s-onthisday-using-the-wikimedia-api
                  MMM-CalendarExt3 --> https://forum.magicmirror.builders/topic/16690/mmm-calendarext3
                  August-Lock Module Stuck on Loading --> https://forum.magicmirror.builders/topic/18607/august-lock-module-stuck-on-loading
                  MMM-CalendarExt3 not syncing automatically with icloud --> https://forum.magicmirror.builders/topic/18598/mmm-calendarext3-not-syncing-automatically-with-icloud
                  delete account --> https://forum.magicmirror.builders/topic/18341/delete-account
                  Ecobee --> https://forum.magicmirror.builders/topic/701/ecobee
                  PiHole-Info Modul --> https://forum.magicmirror.builders/topic/18603/pihole-info-modul
                  My custom mirror --> https://forum.magicmirror.builders/topic/18600/my-custom-mirror
                  • bugsounetB bugsounet referenced this topic on
                    I’ve done it! 🥳 Checkout https://forum.magicmirror.builders/topic/19133/mmm-forum.
                    @karsten13 Thank you! That was the hint that led me to the solution 🙏
                    • KristjanESPERANTOK KristjanESPERANTO has marked this topic as solved on
