    Default Weather Module Icon Position
    38 Posts 4 Posters 17.6k Views 4 Watching
      sdetweil @svenpisa
      @svenpisa awesome! thanks for the feedback.
      • G Offline
        greedyvegan
        I have this issue too, the dev window says they’re the same class
        but the classes are already different/labeled as forecast and weather in config
        when I open everything in the developer window,
        this is the one that highlights the icon I want to move “</span> == $0”
        the current weather “sun” icon in the top module is the one I want to move,
        but its labeled as the current weather condition, NOT the icon I want to move
        when I uncheck the one I need, both icons from current weather and “today” from forecast both change
        it’s labeled as “weather weather” , when I change that, they both change (current weather and forecast)
        what am I doing wrong?
        • G Offline
          greedyvegan
          (currently reading)
          https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1602611995137
            sdetweil @greedyvegan
            @greedyvegan yes, they are the same, that is why you need to add unique classes per my previous post, OR use the id value in custom css as the primary selector
            #module_{number}_module-name
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              greedyvegan @sdetweil
              ok, so since this isn’t working, do I change the item “classes” or “type” ?
              let’s say I change it to “weatherDAY” and “weatherWEEK”
              in the css do I change it to
              .weatherDAY .weathericon {
              .weatherWEEK .weathericon {
              so on and so forth?
              • G Offline
                @sdetweil said in Default Weather Module Icon Position:
                @greedyvegan yes, they are the same, that is why you need to add unique classes per my prvious post, OR use the id value in custom css as the primary selector
                I also saw you say IF you choose the module number, be careful when adding modules because the number will change.
                  @greedyvegan sorry i posted to an issue
                  • G Offline
                    @sdetweil thank you very much
                    • G Offline
                      greedyvegan @greedyvegan
                      that didn’t work, I’m going to try something else
                        @greedyvegan what didnt work?
                        remember the thing before the {
                        is the selector clause,
                        it selects the elements the stuff after the { will apply to
                        i use this cheatsheet to help me build the selector clause
                        https://www.w3schools.com/cssref/css_selectors.php
                        • G Offline
                          @sdetweil changing the classes name didn’t work for me, my custom name gets ignored
                          @sdetweil said remember the thing before the {
                          I’m going to try that
                          • bugsounetB bugsounet referenced this topic on
                            @greedyvegan said in Default Weather Module Icon Position:
                            you noticed the dot in front of the class name , right?
                            . means element class (html class="foo", .foo)
                            # means element id  (html id="module_0_clock", #module_o_clock)
                            nothing means html element (html img, body, div...)
                            in MM if you want to select elements in A module, then you would select the content starting with its id (#module_…) its classname (.modulename) or one of the classes specified in the classes:“xxx yyy”, property for that module
                            • G Offline
                              yes, other modules are easier to me because it’s only one focus
                              nothing means html element (html img, body, div…)
                              this confused me
                              believe me, I’m trying to understand.
                              I’m also trying everything I read/see for hours before reaching out for help
                              in config, I chose to uniquely identify the two weather “classes”
                              however the developer window mentions “class”
                              it also says “class=module weather weather” for both weather modules.
                              Screenshot 2024-03-31 at 5.31.20 PM.png I think THIS is why modifying one modifies both.
                              the weather.js file says .currentWeather & .forecastWeather
                              the weather.css file doesn’t differentiate current & forecast classes. I’ve even read the current & forecast njk files for individual class indicators…
                              in custom.css I’m trying any and everything I see to individually identify and separate #module_5_weather from #module_6_weather
                              I feel like my focus is in the wrong place(s) and i’m overlooking something extremely simple
                                @greedyvegan show me the config for the two modules , xxx out the api key
                                copy paste, dont change anything else
                                • G Offline
                                    @greedyvegan ok, the ‘classes’ property in this case is an mm config option NOT a module config option.
                                    so it goes outside of the config:{} section, along with position and header
                                    see these options in the doc
                                    https://docs.magicmirror.builders/modules/configuration.html#example
                                    • G Offline
                                      @sdetweil said
                                      the ‘classes’ property goes outside of the config:{} section, along with position and header
                                      I knew it
                                      thank you very much, I’ll play around with this in a few
                                        @greedyvegan note that modules can also define properties with the same names as we use for mm properties. so one has to check carefully. ive only made this mistake a hundred times…
                                        • G Offline
                                          @sdetweil lol noted
