    Default Weather Module Icon Position
    38 Posts 4 Posters 18.1k Views 4 Watching
    • Z
      ZiggidyZ
      Personally I use putty and do everything over command line. On my PC I use Notepad++ for working on files as well, then will copy and paste over to the ssh session.
        sdetweil @ZiggidyZ
        @ZiggidyZ yeh, I used to do that too.
        then I have 10 systems I work on, got to be too much copying.
          svenpisa
          Thank you guys for your tips and help. Now I only have one issue left.
          How do I get the icons in the right place?
            sdetweil @svenpisa
            @svenpisa I don’t understand. you have mmm-wallpaoer selected, but weather icons in class list
              svenpisa @sdetweil
              @sdetweil I had taken the section to see the Custom.css and weather.css on the right side. Shouldn’t the wallpaper actually be displayed?
                sdetweil @svenpisa
                @svenpisa as I said, confused.
                in custom.css do
                html {
                   cursor: default;
                to turn on the mouse pointer over the mm content
                then easier to see to select correct content
                  svenpisa @sdetweil
                  @sdetweil said in Default Weather Module Icon Position:
                  html {
                  cursor: default;
                  Is the screenshot better?
                    sdetweil @svenpisa
                    @svenpisa yes, better.
                    so that stuff for .weathericon from custom.css, I would click off each and see the effect.
                    as you mouse over the settings in the right column a checkbox will appear, that u can check to disable a setting
                    note .weather-icon applies to ALL of the icons.
                    the css selector clause (stuff before the {) WILL ALWAYS match every such item on the page. you can make it more specific to get fewer elements.
                      svenpisa
                      Thank you very much for your help.
                      I first had to read through your messages at my leisure and at the same time I tried to understand the messages parallel to the developer tool.
                      And lo and behold, it worked.
                      I have now split the weather module into two classes.
                      			module: "weather",
                      			classes: "forecast",
                      			header: "Wettervorschau",
                      				type: "forecast",
                      				locationID: "2911xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      				apiKey: "c64bb3321848fe4e76163xxxxxxxxxc"
                      			module: "weather",
                      			classes: "wetter",
                      			position: "top_center",
                      				type: "current",
                      				apiKey: "c64bb3321848fe4e76163xxxxxxxxx"
                      You could then play around really well with each class in the developer tool and then find the right position.
                      For those who are interested. I have now made the following entries in the Custom.css so that it looks like this:
                      .forecast .weathericon {
                      position:absolute;	// absolute
                      z-index: 0;
                      height: 200px;
                      right: 120px;
                      margin-top: -65px;
                      padding-left: 60px;
                      padding-top: 50px;
                      height: 35px;
                      .forecast .wi-day-sunny {
                      content: url("/css/icons/day.svg");
                      .forecast .wi-day-cloudy {
                      content: url("/css/icons/cloudy-day-1.svg");
                      .forecast .wi-rain {
                      content: url("/css/icons/rainy-6.svg");
                      forecast .wi-night-clear {
                      content: url("/css/icons/night.svg");
                      .forecast .wi-night-cloudy {
                      content: url("/css/icons/cloudy-night-2.svg");
                      padding-right: 15px;
                      padding-top: 10px;
                      .forecast .wi-cloudy {
                      content: url("/css/icons/cloudy.svg");
                      .forecast .wi-showers {
                      content: url("/css/icons/rainy-7.svg");
                      .forecast .wi-thunderstorm {
                      content: url("/css/icons/thunder.svg");
                      .forecast .wi-snow {
                      content: url("/css/icons/snowy-6.svg");
                      .forecast .wi-cloudy-windy {
                      content: url("/css/icons/cloudy-day-3.svg");
                      .forescast.wi-night-rain {
                      .forecast .wi-night-snow {
                      .forecast .wi-night-thunderstorm {
                      .forecast .wi-night-showers {
                      .forecast .wi-fog {
                      .forecast .wi-night-alt-cloudy-windy {
                      content: url("/css/icons/cloudy-night-1.svg");
                      /* Aenderungen Wettervorhersage */
                      .wetter .weathericon {
                      position: absolute;
                      z-index: 1;
                      margin-top: -33px;
                      padding-top: 20px;
                      left: 60px;
                      .wetter .wi-day-sunny {
                      padding-left: 6px;
                      padding-top: 5px;
                      height: 50px;
                      .wetter .wi-day-cloudy {
                      .wetter .wi-rain {
                      padding-left: 8px;
                      padding-top: 5px;
                      height: 45px;
                      .wetter .wi-night-clear {
                      .wetter .wi-night-cloudy {
                      height: 50px;
                      padding-left: 5px;
                      padding-top: 7px;
                      .wetter .wi-cloudy {
                      .wetter .wi-showers {
                      .wetter .wi-thunderstorm {
                      .wetter .wi-snow {
                      .wetter .wi-cloudy-windy {
                      height: 45px;
                      padding-left: 8px;
                      padding-top: 7px;
                      .wetter .wi-night-rain {
                      padding-left: 8px;
                      padding-top: 5px;
                      height: 45px;
                      .wetter .wi-night-snow {
                      .wetter .wi-night-thunderstorm {
                      .wetter .wi-night-showers {
                      .wetter .wi-fog {
                      .wetter .wi-night-alt-cloudy-windy {
                      height: 50px;
                      padding-left: 5px;
                      padding-top: 7px;
                      We can therefore close the entry here
                      Thanks all again
                        sdetweil @svenpisa
                        @svenpisa awesome! thanks for the feedback.
                        • G
                          greedyvegan
                          I have this issue too, the dev window says they’re the same class
                          but the classes are already different/labeled as forecast and weather in config
                          when I open everything in the developer window,
                          this is the one that highlights the icon I want to move “</span> == $0”
                          the current weather “sun” icon in the top module is the one I want to move,
                          but its labeled as the current weather condition, NOT the icon I want to move
                          when I uncheck the one I need, both icons from current weather and “today” from forecast both change
                          it’s labeled as “weather weather” , when I change that, they both change (current weather and forecast)
                          what am I doing wrong?
                          • G
                            greedyvegan
                            (currently reading)
                            https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1602611995137
                              sdetweil @greedyvegan
                              @greedyvegan yes, they are the same, that is why you need to add unique classes per my previous post, OR use the id value in custom css as the primary selector
                              #module_{number}_module-name
                              G 2 Replies Last reply Reply Quote 0
                              • G
                                greedyvegan @sdetweil
                                ok, so since this isn’t working, do I change the item “classes” or “type” ?
                                let’s say I change it to “weatherDAY” and “weatherWEEK”
                                in the css do I change it to
                                .weatherDAY .weathericon {
                                .weatherWEEK .weathericon {
                                so on and so forth?
                                • G
                                  @greedyvegan yes, they are the same, that is why you need to add unique classes per my prvious post, OR use the id value in custom css as the primary selector
                                  I also saw you say IF you choose the module number, be careful when adding modules because the number will change.
                                    @greedyvegan sorry i posted to an issue
                                    • G
                                      @sdetweil thank you very much
                                      • G
                                        greedyvegan @greedyvegan
                                        that didn’t work, I’m going to try something else
                                          @greedyvegan what didnt work?
                                          remember the thing before the {
                                          is the selector clause,
                                          it selects the elements the stuff after the { will apply to
                                          i use this cheatsheet to help me build the selector clause
                                          https://www.w3schools.com/cssref/css_selectors.php
                                          • G
                                            @sdetweil changing the classes name didn’t work for me, my custom name gets ignored
                                            @sdetweil said remember the thing before the {
                                            I’m going to try that
                                            • bugsounetB bugsounet referenced this topic on
