    MP3 Player
    59 Posts 5 Posters 32.8k Views 4 Watching
      @bachoo786 i looked thru the code and see we used a routine to create the elements so my comments above were misleading. sorry.
      my newer routine also adds parent and value
      from the birthdayList module referenced above
      	// create document element worker
      	createEl : function (type, id, className, parent, value) {
      		var el= document.createElement(type)
      		if(id)
      			el.id = id
      		if(className)
      			el.className = className
      		if(parent)
      			parent.appendChild(el)
      		if(value) {
      			var e = document.createTextNode(value)
      			el.appendChild(e)
      		return el
      and how its used
      	getDom: function() {
      		var wrapper = this.createEl("div",null,null,null,null);
      		if(this.suspended==false){
      			if(Object.keys(this.active_birthdays).length > 0) {
      				let counter = 0
      				// create your table here
      				var table = this.createEl("table", "birthday-table","TABLE", wrapper, null);
      				// create table header here, array of column names
      				var table_header = this.createTableHeader(table, null, [" "," "])
      				// create looped row section
      				var tBody = this.createEl('tbody', "birthday-tbody", "TBODY", table, null);
      this makes the main code smaller and more readable.
      just like the html indentation, the elements have parent/child relationships
      you have to build them either way
      B 1 Reply Last reply
        bachoo786 @sdetweil
        Sam I appreciate you are a teacher and honestly I know that you help and teach everyone around here. I believe I am nearly there with this mp3 player module but its just the ui is not that aesthetic, hence why I thought of changing it.
        however I did build another module some what a religious one but it can be used as an mp3 player if one wishes. here are the files:
        MMM-QuranPlayer.js:
        Module.register("MMM-QuranPlayer", {
            // Default module config.
            defaults: {},
            // start method
            start: function() {
                this.reciters = [];
                this.selectedReciter = null;
                this.surahs = [];
                this.selectedSurah = null;
                this.sendSocketNotification("GET_RECITERS");
                this.currentIndex = 0;
            getStyles: function() {
                return ["MMM-QuranPlayer.css"];
            // Override dom generator to build the UI
                wrapper.className = "MMM-QuranPlayer";
                var leftPanel = document.createElement("div");
                leftPanel.className = "left-panel";
                var rightPanel = document.createElement("div");
                rightPanel.className = "right-panel";
                this.audioPlayer = document.createElement("audio");
                this.audioPlayer.className = "audio-player";
                this.audioPlayer.controls = true;
                rightPanel.appendChild(this.audioPlayer);
                this.reciters.forEach((reciter) => {
                    var folderElement = document.createElement("div");
                    folderElement.innerHTML = reciter;
                    folderElement.className = "folder";
                    folderElement.onclick = () => {
                        this.selectedReciter = reciter;
                        this.sendSocketNotification("GET_SURAH_LIST", reciter);
                    leftPanel.appendChild(folderElement);
                var surahListElement = document.createElement("div");
                surahListElement.className = "surah-list";
                leftPanel.appendChild(surahListElement);
        var controls = ["Play", "Pause", "Stop", "Next", "Previous"];
        controls.forEach((control) => {
            var controlElement = document.createElement("div");
            controlElement.innerHTML = control;
            controlElement.className = "control";
            // Bind the actual functionalities here, inside the loop
            controlElement.onclick = () => {
                if (control === "Play") {
                    this.playSurah(this.selectedSurah); // Assumes this.selectedSurah is the surah to play
                } else if (control === "Pause") {
                    this.pauseAudio();
                } else if (control === "Stop") {
                    this.stopAudio();
                } else if (control === "Next") {
                    this.nextSurah();
                } else if (control === "Previous") {
                    this.previousSurah();
                // Implement Next and Previous based on your app logic
            rightPanel.appendChild(controlElement);
                wrapper.appendChild(leftPanel);
                wrapper.appendChild(rightPanel);
                return wrapper;
                if (notification === "RECITERS_RESULT") {
                    this.reciters = payload;
                    this.updateDom();
                } else if (notification === "SURAH_LIST_RESULT") {
                    var surahListElement = document.querySelector(".surah-list");
                    surahListElement.innerHTML = "";
                    payload.forEach((surah) => {
                        var surahElement = document.createElement("div");
                        surahElement.innerHTML = surah;
                        surahElement.className = "surah";
                        surahElement.onclick = () => {
                            this.selectedSurah = surah;
                            this.playSurah(surah);
                        surahListElement.appendChild(surahElement);
        playSurah: function(surah) {
            let index = this.surahs.indexOf(surah); // Find the index of the surah
            if (index !== -1) {
                this.currentIndex = index; // Update the current index
            if (this.selectedReciter && surah) {
                this.audioPlayer.src = this.getFileUrl(this.selectedReciter, surah);
                this.audioPlayer.play();
                this.selectedSurah = surah; // Update the selected surah
            pauseAudio: function() {
                this.audioPlayer.pause();
            stopAudio: function() {
                this.audioPlayer.currentTime = 0;
        nextSurah: function() {
            if (this.currentIndex < this.surahs.length - 1) {
                this.currentIndex++;
                this.selectedSurah = this.surahs[this.currentIndex];
            } else {
                // Loop to the start or handle as desired if you're at the end of the list
        previousSurah: function() {
            if (this.currentIndex > 0) {
                this.currentIndex--;
            } else {
                // Loop to the end or handle as desired if you're at the start of the list
                this.currentIndex = this.surahs.length - 1;
            // Helper function to construct the URL to the MP3 file
            getFileUrl: function(reciter, surah) {
                return `/modules/MMM-QuranPlayer/public/${reciter}/${surah}.mp3`;
        node_helper.js:
        var NodeHelper = require("node_helper");
        const fs = require("fs");
        const path = require("path");
            start: function() {
                this.expressApp.get('/MMM-QuranPlayer/play', (req, res) => {
                    res.send("Playing...");
                if (notification === "GET_RECITERS") {
                    this.sendReciters();
                } else if (notification === "GET_SURAH_LIST") {
                    this.sendSurahList(payload);
                } else if (notification === "PLAY_SURAH") {
                    console.log(`Playing ${payload.surah} by ${payload.reciter}`);
            sendReciters: function() {
                const recitersDir = path.join(this.path, "public");
                fs.readdir(recitersDir, (err, files) => {
                    if (err) {
                        this.sendSocketNotification("RECITERS_RESULT", []);
                        return;
                    this.sendSocketNotification("RECITERS_RESULT", files);
            sendSurahList: function(reciter) {
                const surahDir = path.join(this.path, "public", reciter);
                fs.readdir(surahDir, (err, files) => {
                    if (err) {
                        this.sendSocketNotification("SURAH_LIST_RESULT", []);
                        return;
                    this.sendSocketNotification("SURAH_LIST_RESULT", files.map(file => file.replace('.mp3', '')));
        and the css:
        .MMM-QuranPlayer {
            position: absolute; /* Absolute positioning relative to the nearest positioned ancestor or to the body */
            top: 70%; /* Start at half the height of the screen */
            left: 0; /* Align the left of the module to the left of the screen */
            width: 100vw; /* Full width of the viewport */
            height: 50vh; /* Half the height of the viewport */
            display: flex;
            flex-direction: row; /* Align children horizontally */
            transform: translateY(-50%); /* Shift upwards by half the module's height */
            justify-content: space-around; /* Even space around items */
        .MMM-QuranPlayer .left-panel,
        .MMM-QuranPlayer .right-panel {
            flex-basis: 50%; /* Each panel will take up to 50% of the module's width */
            display: flex;
            flex-direction: column;
            justify-content: start; /* Align items to the start of the column */
            align-items: center; /* Center items horizontally */
            overflow-y: auto; /* Allows scrolling for overflowing content */
            margin-top: 20px; /* Adds some space at the top inside the panel */
        .MMM-QuranPlayer .left-panel {
            display: flex;
            justify-content: center; /* Center items vertically within the panel */
            align-items: flex-start; /* Align items to the start (left side) of the panel */
            height: 100vh; /* Set the height to match the right panel or as needed */
            margin-top: 0; /* Reset any additional margin */
            padding-top: 60%; /* Adjust this value to push the content down */
        body .MMM-QuranPlayer .right-panel {
            align-items: flex-end;
            height: 100vh;
        body .MMM-QuranPlayer .folder,
        body .MMM-QuranPlayer .control {
            margin: 10px;
            padding: 10px;
            border: 1px solid #ccc;
            border-radius: 5px;
            background-color: #60DD8E;
            cursor: pointer;
            width: auto;
        body .MMM-QuranPlayer .audio-player {
            width: 100%;
            max-width: 400px; /* Set a max-width if necessary */
        I am trying to achieve something similar to the mp3-player module but just make it nicer and also have the module full screen on the 7 inch display like a dashboard, in which the module is split in the middle with the left hand side being the playlist i.e. all the mp3 files as per the folders. and the right hand side being the actual mp3 player with all the controls and functions etc.
          bachoo786 @KristjanESPERANTO
          @KristjanESPERANTO
          ok i got somewhere added buttons but man when i press the buttons the mp3 files are not played and I cannot see any errors anywhere. also the notifications are sent but they are not received by the module I verified that:
          here is the updated code of MMM-MP3Player module
          MMM-MP3Player.js:
          var arrPlayed = [];
          Module.register("MMM-MP3Player",{
          	defaults: {
          		musicPath: "modules/MMM-MP3Player/music/",
          		autoPlay: true,
          		random: false,
          		loopList: true,
          		return ["style.css"];
              var self = this;
              wrapper.id = self.identifier + "_wrapper";
              var player = document.createElement("div");
              player.className = "player";
              self.info = document.createElement("div");
              self.info.className = "info";
              self.artist = document.createElement("span");
              self.artist.className = "artist";
              self.artist.innerHTML = "MMM-MP3Player";
              self.song = document.createElement("span");
              self.song.className = "name";
              self.song.innerHTML = self.config.autoPlay ? "AutoPlay Enabled" : "AutoPlay Disabled";
              self.song.innerHTML += self.config.random ? "<br />Random Enabled" : "<br />Random Disabled";
              var progress = document.createElement("div");
              progress.className = "progress-bar";
              self.bar = document.createElement("div");
              self.bar.className = "bar";
              progress.appendChild(self.bar);
              self.info.appendChild(self.artist);
              self.info.appendChild(self.song);
              self.info.appendChild(progress);
              self.album_art = document.createElement("div");
              self.album_art.className = "album-art";
              player.appendChild(self.album_art);
              player.appendChild(self.info);
              // Controls container
              var controls = document.createElement("div");
              controls.className = "controls";
              // Define buttons and associated notifications
              var buttons = {
                  "Play": 'PLAY_MUSIC',
                  "Stop": 'STOP_MUSIC',
                  "Next": 'NEXT_TRACK',
                  "Previous": 'PREVIOUS_TRACK',
                  "Random On": 'RANDOM_ON',
                  "Random Off": 'RANDOM_OFF'
              Object.keys(buttons).forEach(function(key) {
                  var button = document.createElement("button");
                  button.innerHTML = key;
                  button.addEventListener("click", function() {
              console.log("Sending notification:", buttons[key]);
                      self.sendNotification(buttons[key], 'some_info'); // Sending notification when button is clicked
                  controls.appendChild(button);
              player.appendChild(controls); // Adding controls to the player
              // Initialize the audio element and attach it to 'self' to make it globally accessible within the module
          		audioElement = document.createElement("audio");
          		audioElement.id = self.identifier+"_player";
          		wrapper.appendChild(audioElement);
          		wrapper.appendChild(player);
              setTimeout(function() {
                  self.sendSocketNotification("INITIATEDEVICES", self.config);
              }, 3000);
              return wrapper;
          	socketNotificationReceived: function(notification, payload){
          		var self = this;
          		switch(notification){
          			case "Error": // Universal error handler
          				self.musicFound = false;
          				console.log("[MMM-MP3Player] Error! ", payload);
          				break;
          			case "Music_Files": // this populates the songs list (array)
          				self.songs = payload;
          				self.current = 0;
          				self.musicFound = true;
          				console.log("[MMM-MP3Player] Music Found");
          				arrPlayed = Array(self.songs.length).fill(false);
          				if (self.config.autoPlay){
          					if (self.config.random){
          						ind = Math.floor(Math.random() * self.songs.length); //(self.current + 1) % self.songs.length;
          						arrPlayed[ind] = true;
          						self.current = ind;
          					self.sendSocketNotification("LOADFILE", self.songs[self.current]);
          				break;
          			case "Music_File": // this is called everytime a song is sent from the server
          				//console.log(payload[3]);
          				if (payload[3] == 'music.png') {
          					self.album_art.classList.add('active');
          				else {
          					self.album_art.classList.toggle('active');
          					self.album_art.className = "album-art-found";
          					var chngstyle = document.querySelector('.album-art-found').style;
          					chngstyle.setProperty("--backgroundImage", "url('" + payload[3] + "')");
          					//var mystr = window.getComputedStyle(document.querySelector('.album-art-found'), '::before').getPropertyValue('background-image');
          					//console.log(mystr);
          				// create url of the raw data received and play it
          				audioElement=document.getElementById(self.identifier+"_player");
          				var binaryData = [];
          				binaryData.push(payload[0]);
          				if ((payload[2] = 'mp3') || (payload[2] = 'flac')){
          					var url = window.URL.createObjectURL(new Blob(binaryData, {type: "audio/mpeg"}));
          				/*else if (payload[2] = 'ogg'){
          					var url = window.URL.createObjectURL(new Blob(binaryData, {type: "audio/ogg"}));
          				else if (payload[2] = 'wav'){
          					var url = window.URL.createObjectURL(new Blob(binaryData, {type: "audio/wav"}));
          				audioElement.load();
          				audioElement.setAttribute('src', url);
          				audioElement.volume = 1;
          				audioElement.play();
          				self.artist.innerHTML = payload[1][0];
          				self.song.innerHTML = payload[1][1];
          				//self.album_art.classList.add('active');
          				// progress bar (thanks to Michael Foley @ https://codepen.io/mdf/pen/ZWbvBv)
          				var timer;
          				var percent = 0;
          				audioElement.addEventListener("playing", function(_event) {
          					advance(_event.target.duration, audioElement);
          				audioElement.addEventListener("pause", function(_event) {
          					clearTimeout(timer);
          				var advance = function(duration, element) {
          					increment = 10/duration
          					percent = Math.min(increment * element.currentTime * 10, 100);
          					self.bar.style.width = percent+'%'
          					startTimer(duration, element);
          				var startTimer = function(duration, element){
          					if(percent < 100) {
          						timer = setTimeout(function (){advance(duration, element)}, 100);
          				// next track & loop
          				audioElement.onended = function() {
          					if(!self.musicFound){
          						return;
          						if (!arrPlayed.includes(false)){ // if all files are played
          							if (!self.config.loopList) {
          								self.artist.innerHTML = "Playlist ended";
          								self.song.innerHTML = "";
          								console.log("[MMM-MP3Player] Playlist ended");
          								return;
          							arrPlayed.fill(false);
          						do {
          						} while ( (arrPlayed[ind]) || ((ind == self.current) && (self.songs.length>1)) ); //ind == self.current: not to play one song twice - in the end of list and in the beginning of newly created list)
          						self.current = ind;
          					else {
          						if(self.current==(self.songs.length-1)){ // if all files are played
          							if (!self.config.loopList){
          								return;
          							self.current = -1;
          						self.current++;
          				console.log("[MMM-MP3Player] Music Played");
          				break;
          	notificationReceived: function(notification, payload){
          		var self = this;
          		if (self.musicFound){
          				case "PLAY_MUSIC":
          					if (audioElement.paused){
          					else {
          					break;
          				case "STOP_MUSIC":
          					audioElement.pause();
          					break;
          				case "NEXT_TRACK":
          						return;
          						do {
          							ind = Math.floor(Math.random() * self.songs.length); // (self.current + 1) % self.songs.length;
          						} while (arrPlayed[ind] || ind == self.current); // ind == self.current: not to play one song twice - in the end of list and in the beginning of newly created list)
          						self.current = ind;
          					else {
          						if(self.current==(self.songs.length-1)){ // this assures the loop
          							self.current = -1;
          						self.current++;
          					break;
          				case "PREVIOUS_TRACK":
          					if(self.current==0){ // this assures the loop
          							self.current = (self.songs.length);
          					self.current--;
          					break;
          				case "RANDOM_ON":
          					self.config.random = true;
          					break;
          				case "RANDOM_OFF":
          					self.config.random = false;
          					break;
          and the css:
           * player css is amdended version of Shayan's player @ https://codepen.io/shayanea/pen/yvvjya
           * Version 1.2.0 - 2020.09.14
          @import url("https://fonts.googleapis.com/css?family=Fira+Sans");
          .player {
            font-family: "Fira Sans", Helvetica, Arial, sans-serif;
            -webkit-font-smoothing: antialiased;
            -moz-osx-font-smoothing: grayscale;
            position: relative;
            background-color: #fff;
            border-radius: 15px;
            width: 300px;
            height: 80px;
            z-index: 5;
            -webkit-box-shadow: 0px 0px 117px -6px rgba(255,255,255,1);
            -moz-box-shadow: 0px 0px 117px -6px rgba(255,255,255,1);
            display: flex;
            /*justify-content: flex-end;  */
          .player .info {
            padding: 15px 0px 0px 90px;
            width:65%;
          .player .info .artist,
          .player .info .name {
          	display: block;
          	line-height: 1.0em;
          .player .info .artist {
            color: #222;
            font-size: 16px;
            margin-bottom: 4px;
            color: #808080; /*#999*/
            font-size: 16px; /*13px*/
            margin-bottom: 8px;
          .player .info .progress-bar {
            background-color: #ddd;
            height: 3px;
            width: 100%;
            position: relative;
          .controls {
            display: flex;
            justify-content: space-around; /* Distributes space between buttons */
            padding: 10px;
          .controls button {
            padding: 5px 10px;
            font-size: 14px;
            color: white;
            background-color: #666; /* Dark grey button background */
            border: none;
            border-radius: 5px;
            cursor: pointer;
            transition: background-color 0.3s;
          .controls button:hover {
            background-color: #777; /* Lighten button on hover */
          .controls button:active {
            background-color: #555; /* Darken button on active/click */
          .player .info .progress-bar .bar {
            position: absolute;
            left: 0;
            top: 0;
            bottom: 0;
            transition: all 0.2s ease;
          .player .album-art-found {
            position: absolute;
            left: -10px;
            height: 80px;
            width: 80px;
            /* background-color:white; */
            box-shadow: 0px 0px 20px 5px rgba(0, 0, 0, 0.2);
            transform: scale(1.2);
            transition: all 0.5s ease;
          .player .album-art-found::before {
            content: "";
            position: absolute;
            top: 0;
            left: 0;
            right: 0;
            bottom: 0;
            background-position: center;
            background-repeat: no-repeat;
            background-size: 80px;
            background-image: var(--backgroundImage);
          .player .album-art {
            position: absolute;
            left: -10px;
            height: 80px;
            width: 80px;
            border-radius: 50%;
          .player .album-art::before {
            content: "";
            position: absolute;
            top: 0;
            left: 0;
            right: 0;
            bottom: 0;
            border-radius: 50%;
            background-size: 50px;
            background-image: url("music.png");
          .player .album-art.active {
            box-shadow: 0px 0px 20px 5px rgba(0, 0, 0, 0.4);
            transition: all 1s ease;
            background: linear-gradient(270deg, #2f987d, #4190bd, #d29b2d, #4bd22d, #d2692d, #9e2dd2, #d22daf, #3f2dd2);
            background-size: 1600% 1600%;
            -webkit-animation: ColorChanger 20s ease infinite;
            -moz-animation: ColorChanger 20s ease infinite;
          .player .album-art.active::before {
            animation: rotation 3s infinite linear;
            -webkit-animation: rotation 3s infinite linear;
            animation-fill-mode: forwards;
          @-webkit-keyframes ColorChanger {
              0%{background-position:0% 50%}
              50%{background-position:100% 50%}
              100%{background-position:0% 50%}
          @-moz-keyframes ColorChanger {
          @keyframes ColorChanger {
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          and the node_helper:
          /* Magic Mirror Node Helper: MMM-MP3Player
           * By asimhsidd
           * Remade by Pavel Smelov.
           * GPLv3 License
          const NodeHelper = require("node_helper");
          const ID3 = require('node-id3');
          const path = require('path')
          const fs = require('fs');
          var music_files_list = [];
          		var self = this;
          		switch(notification) {
          			case "INITIATEDEVICES":
          				var self = this;
          				self.searchMP3(payload.musicPath);
          				if(music_files_list.length){
          					console.log("[MMM-MP3Player] Found ", music_files_list.length, "track(s)");
          					self.sendSocketNotification("Music_Files",music_files_list);
          				else {
          					console.log("[MMM-MP3Player] Music may not be found");
          				break;
          			case "LOADFILE":
          				//console.log('[MMM-MP3Player] trying to play next track');
          				if (fs.existsSync(payload)){
          					fs.readFile(payload, function(err, data) {
          						extension = path.basename(payload).split('.').pop(); //extension = path.extname(payload); //returns ext with dot
          						var cover = '';
          						if (extension == "mp3") {
          							tags = ID3.read(data);
          							if (typeof tags.image != "undefined") {
          								/*var base64String = "";
          								for (var i = 0; i < tags.image.imageBuffer.length; i++) {
          									base64String += String.fromCharCode(tags.image.imageBuffer[i]);
          								cover = "data:image/" + tags.image.mime + ";base64," + Buffer.from(base64String).toString('base64'); */
          								cover = "data:image/" + tags.image.mime + ";base64," + tags.image.imageBuffer.toString('base64');
          							if (typeof tags.artist == "undefined" && typeof tags.title == "undefined"){ tags.title = path.basename(payload); }
          						else {
          							tags = {artist:'', title:path.basename(payload)};
          						if (cover == '') {
          							if (fs.existsSync(path.join(path.dirname(payload),'cover.jpg'))){
          								cover = path.join('/', path.dirname(payload), 'cover.jpg');
          							else {
          								cover = "music.png";
          						self.sendSocketNotification("Music_File",[data,[tags.artist,tags.title], extension, cover]);
          				else {
          					self.sendSocketNotification("Error","File can not be opened");
          				break;
          	searchMP3(startPath){ // thanks to Lucio M. Tato at https://stackoverflow.com/questions/25460574/find-files-by-extension-html-under-a-folder-in-nodejs
          		var self = this;
          		var filter_mp3 = RegExp('.mp3'); // var filter = /.mp3/;
          		var filter_flac = RegExp('.flac');
          		//var filter_ogg = RegExp('.ogg');
          		var filter_wav = RegExp('.wav');
          		if (!fs.existsSync(startPath)){
          			console.log("[MMM-MP3Player] no dir ",startPath);
          			return;
          		var files=fs.readdirSync(startPath);
          		for(var i=0;i<files.length;i++){
          			var filename=path.join(startPath,files[i]);
          			var stat = fs.lstatSync(filename);
          			if (stat.isDirectory()){
          				self.searchMP3(filename); //recurse
          			}else if ( (filter_mp3.test(filename)) || (filter_flac.test(filename)) /*|| (filter_ogg.test(filename))*/ || (filter_wav.test(filename)) ){
          				music_files_list.push(filename.replace(/\/\/+/g, '/')); // to avoid double slashes (https://stackoverflow.com/questions/23584117/replace-multiple-slashes-in-text-with-single-slash-with-javascript/23584219)
          can someone please point me to the right direction ? thanks
          S mumblebajM 2 Replies Last reply
            sdetweil @bachoo786
            @bachoo786 i don’t know from the code u posted. i would use the developers window, sources tab to debug the browser code.
            ctrl-shift-i to open the developers window. select the sources tab, find your module in the left nav,
            select your js file and put a stop on the button handler function… I suspect the ‘this’ pointer was lost, and couldn’t call sendSocketNotification
            this is because the function to be called is labeled w the word function(parms){…}
            the arrow notation (parms)=>{…} preserves the ‘this’ pointer
            • mumblebajM
              mumblebaj Module Developer @bachoo786
              @bachoo786 I am a little confused, which module are you building? MMM-Mp3Player or MMM-QuranPlayer? Can you share the Github link to it?
                bachoo786 @mumblebaj
                @mumblebaj well I am trying to implement a “module” which satisfies my needs of playing any mp3 file. I do want to play the Quran but like I said initially it could play any mp3 file.
                I do not have a Github link as of now sorry.
                  bachoo786 @sdetweil
                  @sdetweil I added some logs and I can see that the notification is sent however its not received, see my updated code below with the result from developer console:
                  updated MMM-MP3Player.js:
                  var arrPlayed = [];
                  var audioElement = null; // Define it here globally
                  	defaults: {
                  		autoPlay: true,
                  		random: false,
                  		loopList: true,
                      var self = this;
                      var buttons = {
                      console.log("Button clicked: " + key);
                      console.log("Sending notification:", buttons[key], 'some_info');
                      self.sendNotification('buttons[key]', 'some_info');
                      }, 3000);
                      return wrapper;
                  		var self = this;
                  				break;
                  				self.current = 0;
                  						self.current = ind;
                  				break;
                  				else {
                  				var timer;
                  				var percent = 0;
                  					if(percent < 100) {
                  						return;
                  								return;
                  						do {
                  						self.current = ind;
                  					else {
                  								return;
                  							self.current = -1;
                  						self.current++;
                  				break;
                      console.log("Notification received:", notification);
                  		var self = this;
                  				case "PLAY_MUSIC":
                  					else {
                  					break;
                  				case "STOP_MUSIC":
                  					break;
                  				case "NEXT_TRACK":
                  						return;
                  						do {
                  						self.current = ind;
                  					else {
                  							self.current = -1;
                  						self.current++;
                  					break;
                  					self.current--;
                  					break;
                  				case "RANDOM_ON":
                  					break;
                  				case "RANDOM_OFF":
                  					break;
                    sdetweil @bachoo786
                    @bachoo786 said in MP3 Player:
                    button.addEventListener(“click”, function() {
                    change that to
                    button.addEventListener(“click”,()=>{
                    and change the self.sendNotification
                    to this.sendNotification
                    at the time the click event happens, you are not in the module code, but in the browser.
                    and the getDom() function has long since ended. you want the runtime to remember the context before it executes any code.
                    the arrow invocation ()=>{} does that, while the function(){} type invocation does not
                      bachoo786 @sdetweil
                      @sdetweil Hey Sam
                      I did the changes but when i click on the “Play” or any button the mp3 file isnt played and I get this error on the developer console:
                      Button clicked: Play
                      MMM-MP3Player.js:71 Sending notification: PLAY_MUSIC some_info
                      MMM-MP3Player.js:72 Uncaught TypeError: this.sendNotification is not a function
                      at HTMLButtonElement. (MMM-MP3Player.js:72:10)
                      here is the updated code:
                      var arrPlayed = [];
                      	defaults: {
                      		autoPlay: true,
                      		random: false,
                      		loopList: true,
                          var self = this;
                          var buttons = {
                      button.addEventListener("click",()=>{
                          this.sendNotification('buttons[key]', 'some_info');
                          }, 3000);
                          return wrapper;
                      		var self = this;
                      				break;
                      				self.current = 0;
                      						self.current = ind;
                      				break;
                      				else {
                      				var timer;
                      				var percent = 0;
                      					if(percent < 100) {
                      						return;
                      								return;
                      						do {
                      						self.current = ind;
                      					else {
                      								return;
                      							self.current = -1;
                      						self.current++;
                      				break;
                      		var self = this;
                      				case "PLAY_MUSIC":
                      					else {
                      					break;
                      				case "STOP_MUSIC":
                      					break;
                      				case "NEXT_TRACK":
                      						return;
                      						do {
                      						self.current = ind;
                      					else {
                      							self.current = -1;
                      						self.current++;
                      					break;
                      					self.current--;
                      					break;
                      				case "RANDOM_ON":
                      					break;
                      				case "RANDOM_OFF":
                      					break;
                        sdetweil @bachoo786
                        @bachoo786 hmm…change the this. to self. weird… because it says not a member of htmlElement .
                          bachoo786 @sdetweil
                          Nope doesn’t work.
                          I feel like going back to the old MP3 Player module that you helped.set up and just changing the css from the disc to something more modern and futuristic with better buttons etc.
                          Oh and also adding a playlist of mp3s which should be read from the mp3 folder. Display the module in half where the half on the left displays the playlist and the one on the right displays the player buttons etc.
                          Is that possible you think?
                            sdetweil @bachoo786
                            @bachoo786 no idea really. need to think.
                            do you have a git repo I can clone to look at
                              bachoo786 @sdetweil
                              @sdetweil I dont I am afraid.
                              Do you think posting the codes on here would be suffice? the node-helper, js and the css files?
                              MMM-MP3Player.js:
                              var arrPlayed = [];
                              	defaults: {
                              		autoPlay: true,
                              		random: false,
                              		loopList: true,
                                  var self = this;
                                  var buttons = {
                                  }, 3000);
                                  return wrapper;
                              		var self = this;
                              				break;
                              				self.current = 0;
                              						self.current = ind;
                              				break;
                              				else {
                              				var timer;
                              				var percent = 0;
                              					if(percent < 100) {
                              						return;
                              								return;
                              						do {
                              						self.current = ind;
                              					else {
                              								return;
                              							self.current = -1;
                              						self.current++;
                              				break;
                              		var self = this;
                              				case "PLAY_MUSIC":
                              					else {
                              					break;
                              				case "STOP_MUSIC":
                              					break;
                              				case "NEXT_TRACK":
                              						return;
                              						do {
                              						self.current = ind;
                              					else {
                              							self.current = -1;
                              						self.current++;
                              					break;
                              					self.current--;
                              					break;
                              				case "RANDOM_ON":
                              					break;
                              				case "RANDOM_OFF":
                              					break;
                              node_helper.js:
                               * By asimhsidd
                               * GPLv3 License
                              		var self = this;
                              				var self = this;
                              				else {
                              				break;
                              			case "LOADFILE":
                              						var cover = '';
                              						else {
                              						if (cover == '') {
                              							else {
                              				else {
                              				break;
                              		var self = this;
                              			return;
                              style.css:
                              .player {
                                position: relative;
                                width: 300px;
                                height: 80px;
                                z-index: 5;
                                display: flex;
                              .player .info {
                                width:65%;
                              	display: block;
                              	line-height: 1.0em;
                                color: #222;
                                font-size: 16px;
                                margin-bottom: 4px;
                                margin-bottom: 8px;
                                height: 3px;
                                width: 100%;
                                position: relative;
                              .controls {
                                display: flex;
                                padding: 10px;
                              .controls button {
                                padding: 5px 10px;
                                font-size: 14px;
                                color: white;
                                border: none;
                                border-radius: 5px;
                                cursor: pointer;
                                position: absolute;
                                left: 0;
                                top: 0;
                                bottom: 0;
                                position: absolute;
                                left: -10px;
                                height: 80px;
                                width: 80px;
                                content: "";
                                position: absolute;
                                top: 0;
                                left: 0;
                                right: 0;
                                bottom: 0;
                                position: absolute;
                                left: -10px;
                                height: 80px;
                                width: 80px;
                                border-radius: 50%;
                                content: "";
                                position: absolute;
                                top: 0;
                                left: 0;
                                right: 0;
                                bottom: 0;
                                border-radius: 50%;
                                0% {
                                100% {
                                sdetweil @bachoo786
                                @bachoo786 better if you make a github repo
                                but the main problem is you cannot sendNotification to yourself…
                                BUT you CAN call the notificationReceived function instead
                                  bachoo786 @sdetweil
                                  @sdetweil what do I do then ?
                                    sdetweil @bachoo786
                                    @bachoo786 change the one line of code
                                    mumblebajM 1 Reply Last reply
                                    • mumblebajM
                                      @sdetweil and @bachoo786 There is a lot wrong with that code snippets. Can’t make it work the way it stands.
                                        sdetweil @mumblebaj
                                        @mumblebaj @bachoo786 here is a repo for this module
                                        it is built with name sensitive constructs, so if you rename the files it will adjust automatically… (except for the css file… today it has no module prefix on its selectors)
                                        https://github.com/sdetweil/new-MP3Player
                                        (as I already have a module repo with MMM)
                                        put some music files in the music folder
                                        install instructions
                                        cd ~/MagicMirror/modules
                                        git clone https://github.com/sdetweil/new-MP3Player
                                        cd new-MP3Player
                                        npm install
                                        change the modulename in config.js if u had the prior code
                                          I updated the player to get rid of as many global variables as possible
                                            bachoo786 @sdetweil
                                            Hi Sam thanks for that I will try it out soon.
                                            I am currently working on the existing mp3 player module and have added another songList i.e. songList2 as per my get dom function. Trouble is I get this error when I restart the MagicMirror, the error is from the developer console. I am scratching my head to resolve it but it doesnt work.
                                            here is the code:
                                            MMM-MP3Player.js:
                                            var MP3;
                                            var substr;
                                            Module.register("MMM-MP3Player", {
                                              defaults: {
                                                songs: [],
                                                songs2: [],  // Add this line for the second song list
                                                musicPath: "modules/MMM-MP3Player/music",
                                                musicPath2: "modules/MMM-MP3Player/music2",
                                                extensions: ["mp3", "wma", "acc", "ogg"],
                                            //    songs: null,
                                                autoPlay: false,
                                                random: false,
                                              audio: null,
                                              songTitle: null,
                                              mediaPlayer: null,
                                              dataAvailable: true,
                                              curSong :0,
                                              curLength : 0,
                                              time: null,
                                              play: null,
                                              firstTime: true,
                                              substr: null,
                                              getStyles: function(){
                                                return ["MMM-MP3Player.css", "font-awesome.css"];
                                            start: function() {
                                              MP3 = this;
                                              console.log("Starting module:", MP3.name);
                                              this.sendSocketNotification('SOURCE_MUSIC', {musicPath: this.config.musicPath, extensions: this.config.extensions});
                                              this.sendSocketNotification('SOURCE_MUSIC2', {musicPath: this.config.musicPath2, extensions: this.config.extensions}); // Send notification to load songs from the second directory
                                            getDom: function(){
                                                if(MP3.config.songs != null) {
                                                    // Display the list of MP3 files
                                                    var songList = MP3.createElement("ul", "songList", "songList");
                                                    for(var i = 0; i < MP3.config.songs.length; i++) {
                                                        var listItem = MP3.createElement("li", "songItem", "songItem" + i);
                                                        listItem.innerHTML = MP3.config.songs[i].substr(0, MP3.config.songs[i].length - 4);
                                                        listItem.addEventListener("click", function(index) {
                                                            return function() {
        MP3.setCurrentSong(index);
        MP3.audio.play();
        MP3.play.getElementsByTagName('i')[0].className = "fa fa-pause";
        MP3.mediaPlayer.classList.add("play");
        MP3.updateDurationLabel();
                                                        }(i));
                                                        songList.appendChild(listItem);
                                                    wrapper.appendChild(songList);
                                              if (MP3.config.songs2 != null) {
                                                var songList2 = MP3.createElement("ul", "songList2", "songList2");
                                                for (var i = 0; i < MP3.config.songs2.length; i++) {
                                                  var listItem = MP3.createElement("li", "songItem2", "songItem2-" + i);
                                                  listItem.innerHTML = MP3.config.songs2[i].substr(0, MP3.config.songs2[i].length - 4);
                                                    return function() {
                                                      MP3.setCurrentSong(index, 'music2');
                                                      MP3.audio.play();
                                                  }(i));
                                                  songList2.appendChild(listItem);
                                                wrapper.appendChild(songList2);
                                                    // Add the rest of the existing code...
                                                    MP3.mediaPlayer = MP3.createElement("div", "mediaPlayer", "mediaPlayer");
                                                    MP3.audio = MP3.createElement("audio", "audioPlayer", "audioPlayer");
                                                    MP3.audio.addEventListener("loadeddata", () => {
                                                        MP3.dataAvailable = true;
                                                        MP3.curLength = MP3.audio.duration;
                                                    MP3.audio.addEventListener("ended", () => {
                                                        Log.log(" play ended")
                                                        MP3.audio.currentTime = 0;
                                                        if(MP3.config.autoPlay)
                                                            MP3.loadNext(MP3.config.random)
                                                        else
                                                            MP3.mediaPlayer.classList.toggle("play");
                                            MP3.audio.addEventListener("timeupdate", () => {
                                                    MP3.mediaPlayer.appendChild(MP3.audio);
                                                    // Add the rest of the controls to MP3.mediaPlayer
                                                    var controls = MP3.createElement("div", "controls", false);
                                                    MP3.songTitle = MP3.createElement("span", "title", "songTitle");
                                                    MP3.setCurrentSong(MP3.curSong);
                                                    controls.appendChild(MP3.songTitle);
                                                    var discArea = MP3.createElement("div", "discarea", false);
                                                    discArea.appendChild(MP3.createElement("div", "disc", false));
                                                    var stylus = MP3.createElement("div", "stylus", false);
                                                    stylus.appendChild(MP3.createElement("div", "pivot", false));
                                                    stylus.appendChild(MP3.createElement("div", "arm", false));
                                                    stylus.appendChild(MP3.createElement("div", "head", false));
                                                    discArea.appendChild(stylus);
                                                    MP3.mediaPlayer.appendChild(discArea);
                                                  var buttons = MP3.createElement("div", "buttons", false);
                                                  //  Previous Button
                                                  var prev = MP3.createButton("back", "prevButton", "fa fa-backward");
                                                  prev.addEventListener("click", () => {
                                                    MP3.dataAvailable = false;
                                                    MP3.loadNext(MP3.config.random);
                                                    MP3.audio.play();
                                                  }, false),
                                                  buttons.appendChild(prev);
                                                  //  Play Button
                                                  MP3.play = MP3.createButton("play", "playButton", "fa fa-play");
                                                  MP3.play.addEventListener("click", () => {
                                                    if (MP3.audio.paused) {
                                                      setTimeout(() => {
                                                        MP3.audio.play();
                                                      }, 300);
                                                      MP3.timer = setInterval(MP3.updateDurationLabel, 100);
                                                    } else {
                                                      //MP3.loadNext(MP3.config.random);
                                                      MP3.play.getElementsByTagName('i')[0].className = "fa fa-play";
                                                      clearInterval(MP3.timer);
                                                      MP3.audio.pause();
                                                  }, false);
                                                  buttons.appendChild(MP3.play);
                                                  //  Stop Button
                                                  var stop = MP3.createButton("stop", "stopButton", "fa fa-stop");
                                                  stop.addEventListener("click", () => {
                                                    MP3.mediaPlayer.classList.remove("play");
                                                    MP3.audio.pause();
                                                  }, false);
                                                  buttons.appendChild(stop);
                                                  //  Next Button
                                                  var next = MP3.createButton("next", "nextButton", "fa fa-forward");
                                                  next.addEventListener("click", () => {
                                                  }, false);
                                                  buttons.appendChild(next);
                                                    controls.appendChild(buttons);
                                                    var subControls = MP3.createElement("div", "subControls", false);
                                                    var duration = MP3.createElement("span", "duration", "currentDuration");
                                                    duration.innerHTML = "00:00" + "&nbsp&nbsp&nbsp";
                                                    subControls.appendChild(duration);
                                                    var volumeSlider = MP3.createElement("input", "volumeSlider", "volumeSlider");
                                                    volumeSlider.type = "range";
                                                    volumeSlider.min = "0";
                                                    volumeSlider.max = "1";
                                                    volumeSlider.step = "0.01";
                                                    volumeSlider.addEventListener("input", () => {
                                                        MP3.audio.volume = parseFloat(volumeSlider.value);
                                                    }, false);
                                                    subControls.appendChild(volumeSlider);
                                                    controls.appendChild(subControls);
                                                    MP3.mediaPlayer.appendChild(controls);
                                                    wrapper.appendChild(MP3.mediaPlayer);
                                                if(MP3.firstTime && MP3.config.autoPlay){
                                                    console.log("First time and autoPlay are true. Setting firstTime to false.");
                                                    MP3.firstTime=false;
                                                return wrapper;
                                              createElement: function(type, className, id){
                                                var elem = document.createElement(type);
                                                if(className) elem.className = className;
                                                if(id)  elem.id = id;
                                                return elem;
                                              createButton: function(className, id, icon){
                                                var button = document.createElement('button');
                                                button.className = className;
                                                button.id = id;
                                                var ico = document.createElement("i");
                                                ico.className = icon;
                                                button.appendChild(ico);
                                                return button;
                                            updateDurationLabel: function() {
                                              var duration = document.getElementById('currentDuration');
                                              if (MP3.dataAvailable && MP3.audio.duration > 0) {
                                                duration.innerText = MP3.parseTime(MP3.audio.currentTime) + " / " + MP3.parseTime(MP3.audio.duration);
                                              } else {
                                                duration.innerText = "00:00 / 00:00";
                                              parseTime: function(time){
                                                const minutes = Math.floor(time / 60)
                                                const seconds = Math.floor(time - minutes * 60)
                                                const secondsZero = seconds < 10 ? "0" : ""
                                                const minutesZero = minutes < 10 ? "0" : ""
                                                return minutesZero + minutes.toString() + ":" + secondsZero + seconds.toString()
                                            setCurrentSong: function(index, type='music1') {
                                              var path = type === 'music1' ? MP3.config.musicPath : MP3.config.musicPath2;  // Use musicPath2 from config
                                              MP3.audio.src = path + '/' + MP3.config['songs' + (type === 'music1' ? '' : '2')][index];
                                              MP3.songTitle.innerHTML = MP3.config['songs' + (type === 'music1' ? '' : '2')][index].substr(0, MP3.config['songs' + (type === 'music1' ? '' : '2')][index].length - 4);
                                              MP3.curSong = index;
                                              loadNext: function(next){
                                               let index=0;
                                                  console.log("loadNext: Autoplay:", MP3.config.autoPlay); // Add this line for logging
                                                  MP3.audio.pause();
                                                  if(next)  index= (MP3.curSong + 1) % MP3.config.songs.length;
                                                  else      index = (MP3.curSong - 1) < 0 ? MP3.config.songs.length - 1 : MP3.curSong - 1;
                                                  MP3.audio.play();
                                              notificationReceived: function (notification, payload) {
                                                if(notification === "ALL_MODULES_STARTED")
                                            		  MP3.sendSocketNotification('SOURCE_MUSIC', MP3.config);
                                              if (notification === "RETURNED_MUSIC") {
                                                if (payload.type === 'music1') {
                                                  MP3.config.songs = payload.songs;
                                                } else if (payload.type === 'music2') {
                                                  MP3.config.songs2 = payload.songs;
                                                MP3.setCurrentSong(0); // set initial song for each list
                                                MP3.updateDom();
                                            node-helper.js:
                                            var NodeHelper = require('node_helper');
                                            const Fs = require('fs');
                                              start: function() {
                                                console.log("Loaded MP3Player node_helper");
                                              var self = this;
                                              if (notification === 'SOURCE_MUSIC') {
                                                var songs = this.getSongs(payload.musicPath, payload.extensions);
                                                self.sendSocketNotification("RETURNED_MUSIC", {songs: songs, type: 'music1'});
                                              } else if (notification === 'SOURCE_MUSIC2') {
                                                self.sendSocketNotification("RETURNED_MUSIC", {songs: songs, type: 'music2'});
                                            getSongs: function(path, ext){
                                              var songs = [];
                                              var contents = Fs.readdirSync(path);
                                              contents.forEach(file => {
                                                if (this.checkExt(file, ext)) {  // Use the checkExt function to filter files
                                                  songs.push(file);
                                              console.log("mp3 player returning song list="+ songs);
                                              return songs;
                                            the error I get is:
                                            Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:196:2)
                                            which is this
