    MMM-IdF-Transport - Never Miss Your Train/Metro/Bus/Tram in Île-de-France(Paris)!
    14 Posts 5 Posters 7.2k Views 5 Watching
    • N Offline
      Nisnis39 @zarg404
      @zarg404 Also you can try the API following this link : https://prim.iledefrance-mobilites.fr/fr/donnees-dynamiques/idfm-ivtr-requete_unitaire in order to try your stoppoint ID
      • Z Offline
        zarg404 @Nisnis39
        • Z Offline
          zarg404 @Nisnis39
          @Nisnis39 Do you plan to add a filter to this module ? And maybe a way to order the results ?
          thanks
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zarg404 @zarg404
            @zarg404 I made a PR for filtering the number of Stops to show
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              Nisnis39 @zarg404
              @zarg404 It’s been added
                splaliv845
                Thanks for the work.
                I made a modification on my side to get number of minutes instead of ETA.
                Not super good at git nor dev so bellow is the modification I made if someone is interested and want to upadate the module.
                regards
                code update --> MMM-Idf-Transport.js
                replace all function --> createDataRow: function (routeObj)
                with :
                createDataRow: function (routeObj) {
                if (isNaN(routeObj.service.ExpectedDepartureTime))
                return null;
                // Calculate the difference in minutes between current time and departure time
                let currentTime = moment();
                let departureTime = moment(routeObj.service.ExpectedDepartureTime);
                let minutesDifference = departureTime.diff(currentTime, 'minutes');
                // Create the row
                let row = document.createElement("tr");
                let line = document.createElement("td");
                line.className = "line";
                line.innerHTML = routeObj.route.ID_Line;
                if (line.innerHTML)
                    line.innerHTML = routeObj.route.lineHtml;
                row.appendChild(line);
                let destination = document.createElement("td");
                destination.className = "destination";
                destination.innerHTML = this.getDisplayString(routeObj.service.DestinationDisplay[0].value);
                row.appendChild(destination);
                let departure = document.createElement("td");
                departure.className = "departure";
                // Display the difference in minutes
                departure.innerHTML = `${minutesDifference} min`;
                row.appendChild(departure);
                return row;
                H 1 Reply Last reply Reply Quote 1
                • H Offline
                  Horyzon @splaliv845
                  Hi everyone,
                  Thanks a lot for you guys’ work on this project, it will be quite helpful when I get it working on my machine.
                  I currently have two issues:
                  • I live in a city with two trainlines passing through the train station. I would be interested in seeing timetables for both lines, but I cannot get it working. One trainline or the other is fine, but not both.
                  • For some reason, the module displays past trains. I used @splaliv845 code to convert the time to minutes to departure, and now I have negative values because the trains displayed are already gone. Any idea as to why, and how to correct it ?
                  Thanks again guys !
                    sdetweil @Horyzon
                    @Horyzon are you using two module instances in config.js for the two trains.
                    for the negative times l if the time is negative don’t display that train
                    • H Offline
                      Horyzon
                      I was happily using the module for a while now, but unfortunatly since the last update, the module doesn’t load and stays stuck on “loading…”.
                      I didn’t touch anything within the module itself, and all other modules have resume working just fine after the update, so I’m a bit lost. The logs aren’t helping me, but I’m very noobish with coding so that doesn’t help either.
                      Can anybody advise ? I’ll share logs if need be.
                      Thanks !
                        sdetweil @Horyzon
                        @Horyzon said in MMM-IdF-Transport - Never Miss Your Train/Metro/Bus/Tram in Île-de-France(Paris)!:
                        can u post them here?
                          sdetweil @Horyzon
                          @Horyzon I posted a reply to your pending post. it contains private info. please correct it and resubmit
