    In which operating system it work
    8 Posts 3 Posters 6.8k Views 2 Watching
      acrylicmfg
      hello all i am beginner of mm. i am not getting in which software it work i.e. windows / lenux.
      Thankyou in Advance
        PindaPower
        If you use a Raspberry Pi then the OS is (most off the time) Raspbian and that is a Linux base system. As an application MM run’s on it.
        A 2 Replies Last reply Reply Quote 0
          acrylicmfg @PindaPower
          which one
          Thanks in advance
            Dear PindaPower ,
                 Thank you for helping me i tried to download zip file.
            The zip files but after downloading- astrict the file- it show emty folder if you can upload a file on net and sent me desire link. so i can down load from that.
            Thankyou
            • brobergB Offline
              broberg Project Sponsor @acrylicmfg
              @acrylicmfg
              https://www.raspberrypi.org/downloads/raspbian/
              Choose raspbian lite, follow the instruction on how to install it to the SD card.
              Then you go to : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
              And follow that guide to install the mirror and adjust your raspberry pi to the default mirror setttings.
                acrylicmfg
                iAM GETTING THIS EARROR BY DOWNLOAD THE EXTRACT.
                brobergB P 2 Replies Last reply Reply Quote 0
                • brobergB Offline
                  @acrylicmfg the img file is there, it’s as it should be. Unzip the img file to wherever you like and then follow this guide :
                  https://www.raspberrypi.org/documentation/installation/installing-images/
                    PindaPower @acrylicmfg
                    @acrylicmfg I don’t mind you asking around, after a few post it seems that you don’t have that background that other forum people have. My answer would be that a video would be a good guide for you, try youtube
