    MMM-CalendarWeek doesn't display
    22 Posts 2 Posters 3.4k Views 2 Watching
      DarrenO 0
      I have installed the module as per instructions and added the required basic information to the config.js file but when MM restarts, it is not displayed and I am just left with a blank screen.
      It doesn’t matter if I use my calendar’s private or public URL, or if I make the calendar public, I get the same result.
      When I add the calendar to MM’s default Calendar module, the events are displayed as expected.
      My config for the module is as follows : (I have listed both the private and public url: links and commented out one)
      module: “MMM-CalendarWeek”,
      position: “bottom_bar”,
      allowDuplicate: false, // true, false
      animationSpeed: 2000, // 0 - 5000
      calendarTitle: “Network Maintenance Schedule”,
      colored: true, // true, false
      coloredSymbolOnly: true, // true, false
      dateFormat: “ddd Do MMM”, // Wed 21st Aug
      displaySymbol: true, // true, false
      fetchInterval: 300000, // 1000 - 86400000
      hideEmptyDays: true, // true, false
      hideOngoing: false, // true, false
      hidePrivate: false, // true, false
      maximumEntries: 20, // 0 - 100
      maximumNumberOfDays: 7, // 4
      maxTitleLength: 25, // 10 - 50
      showEndDate: true, // true, false
      timeFormat: “dateheaders”, // absolute, relative, dateheaders
      wrapEvents: false, // true, false
      // private .ics link
      //url: “URL to my private Google calendar”,
      // public .ics link
      url: “URL to my public Google calendar”,
      symbol: ‘network-wired’,
      color: “#FFFFFF”, // white
      Is anyone able to assist?
      I’ve also posted to the MagicMirror page on FB but havent been able to resolve the issue from the suggestions given there.
        sdetweil @DarrenO 0
        @DarrenO-0 can you show the output of npm start?
        if you use pm2 to launch at boot, then
        pm2 logs --lines=50
          DarrenO 0 @sdetweil
          The output of the MagicMirror-error.log is as follows :
          /home/serveradmin/.pm2/logs/MagicMirror-error.log last 50 lines:
          0|MagicMir | at require (node:internal/modules/helpers:130:18)
          0|MagicMir | at loadConfig (/home/serveradmin/MagicMirror/js/app.js:117:14)
          0|MagicMir | at App.start (/home/serveradmin/MagicMirror/js/app.js:250:18)
          0|MagicMir | at Object. (/home/serveradmin/MagicMirror/js/electron.js:193:7)
          0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1256:14)
          0|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
          0|MagicMir | at Module.load (node:internal/modules/cjs/loader:1098:32)
          0|MagicMir | at Module._load (node:internal/modules/cjs/loader:945:12)
          0|MagicMir | MESA-INTEL: warning: Bay Trail Vulkan support is incomplete
          0|MagicMir | libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
          0|MagicMir | /home/serveradmin/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|MagicMir | [2024-04-29 22:15:24.769] [ERROR] (node:65585) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘valid-url’
          0|MagicMir | Require stack:
          0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
          0|MagicMir | - /home/serveradmin/MagicMirror/js/app.js
          0|MagicMir | - /home/serveradmin/MagicMirror/js/electron.js
          0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
          0|MagicMir | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
          0|MagicMir | at Module._resolveFilename (/home/serveradmin/MagicMirror/node_modules/module-alias/index.js:49:29)
          0|MagicMir | at Module._load (node:internal/modules/cjs/loader:908:27)
          0|MagicMir | at c._load (node:electron/js2c/node_init:2:13672)
          0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1122:19)
          0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js:9:16)
          0|MagicMir | at loadModule (/home/serveradmin/MagicMirror/js/app.js:183:19)
          0|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
          0|MagicMir | [2024-04-29 22:15:24.769] [ERROR] (node:65585) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          0|MagicMir | [66191:0429/230235.459040:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/230235.561159:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/230235.572084:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/230235.577044:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/234504.968361:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/234505.073793:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/234505.089665:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
          0|MagicMir | [66191:0429/234505.092215:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
            sdetweil @DarrenO 0
            @DarrenO-0 said in MMM-CalendarWeek doesn't display:
            yes, this module did not document using a library that we have deleted as no longer needed by the builtin support
            oops
            fix by loading it in the module folder
            BUT this module also does not provide the file to document use either soo, in the module folder do
            npm init -y
            npm install valid-url
              DarrenO 0 @sdetweil
              Run those commands in the folder for the MMM-CalendarWeek folder, or in the modules folder itself?
              I ran it in both folders and restarted MM but nothing changed. Still just a blank screen.
                sdetweil @DarrenO 0
                @DarrenO-0 in THAT module’s folder
                  sdetweil @DarrenO 0
                  @DarrenO-0 and look at the log output again
                    DarrenO 0 @sdetweil
                    Last 50 lines :
                    0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js:2:15)
                    0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js:3:12)
                    0|MagicMir | [2024-04-30 10:22:06.362] [ERROR] (node:69620) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    0|MagicMir | [2024-04-30 12:07:20.093] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                    0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js
                    0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js
                    0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/calendarfetcher.js
                    0|MagicMir | [2024-04-30 12:07:20.094] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      sdetweil @DarrenO 0
                      yep repeat as before.
                      don’t do the npm init
                      see
                        DarrenO 0 @sdetweil
                        re-ran “npm install valid-url” in the /modules/ folder and then restarted MM with pm2 restart MagicMIrror.
                        re-ran pm2 logs --lines=50
                        0|MagicMir | [2024-04-30 12:40:31.257] [ERROR] (node:71169) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                        0|MagicMir | [2024-04-30 12:40:46.686] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                        0|MagicMir | [2024-04-30 12:40:46.687] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
