    MMM-CalendarWeek doesn't display
    22 Posts 2 Posters 3.3k Views 2 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 in THAT module’s folder
        sdetweil @DarrenO 0
        @DarrenO-0 and look at the log output again
          DarrenO 0 @sdetweil
          Last 50 lines :
          0|MagicMir | at Module._resolveFilename (/home/serveradmin/MagicMirror/node_modules/module-alias/index.js:49:29)
          0|MagicMir | at Module._load (node:internal/modules/cjs/loader:908:27)
          0|MagicMir | at c._load (node:electron/js2c/node_init:2:13672)
          0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1122:19)
          0|MagicMir | at require (node:internal/modules/helpers:130:18)
          0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js:2:15)
          0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1256:14)
          0|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
          0|MagicMir | at Module.load (node:internal/modules/cjs/loader:1098:32)
          0|MagicMir | at Module._load (node:internal/modules/cjs/loader:945:12)
          0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js:3:12)
          0|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
          0|MagicMir | [2024-04-30 10:22:06.362] [ERROR] (node:69620) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          0|MagicMir | MESA-INTEL: warning: Bay Trail Vulkan support is incomplete
          0|MagicMir | libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
          0|MagicMir | /home/serveradmin/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|MagicMir | [2024-04-30 12:07:20.093] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
          0|MagicMir | Require stack:
          0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js
          0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js
          0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/calendarfetcher.js
          0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
          0|MagicMir | - /home/serveradmin/MagicMirror/js/app.js
          0|MagicMir | - /home/serveradmin/MagicMirror/js/electron.js
          0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
          0|MagicMir | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
          0|MagicMir | [2024-04-30 12:07:20.094] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
            sdetweil @DarrenO 0
            @DarrenO-0 said in MMM-CalendarWeek doesn't display:
            yep repeat as before.
            don’t do the npm init
            see
              DarrenO 0 @sdetweil
              re-ran “npm install valid-url” in the /modules/ folder and then restarted MM with pm2 restart MagicMIrror.
              re-ran pm2 logs --lines=50
              /home/serveradmin/.pm2/logs/MagicMirror-error.log last 50 lines:
              0|MagicMir | [2024-04-30 12:40:31.257] [ERROR] (node:71169) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              0|MagicMir | [2024-04-30 12:40:46.686] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
              0|MagicMir | [2024-04-30 12:40:46.687] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                sdetweil @DarrenO 0
                no…
                in the module folder
                MMM-CalendarWeek
                  DarrenO 0 @sdetweil
                  appears to be the same result :
                  0|MagicMir | [2024-04-30 12:56:17.257] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                  0|MagicMir | [2024-04-30 12:56:17.258] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    sdetweil @DarrenO 0
                    now
                    npm install request
                    In the folder of the module complaining
                    and continue to repeat this process until the cannot find errors are gone
                    this is not a MagicMirror problem. it is a module problem.
                      DarrenO 0 @sdetweil
                      run how many times?
                      have run “npm install valid-url” ~20 times… no change in the error-log
                      even run “sudo npm install valid-url” and was prompted to update version of npm from 10.2.5 to 10.6.0, so updated accordingly, then re-ran “npm install valid-url” several more times and no change.
                        sdetweil @DarrenO 0
                        @DarrenO-0 what folder where you in when you ran the command npm install
                        and if you followed the instructions correctly, then only once for each missing library
