    MMM-CalendarWeek doesn't display
    22 Posts 2 Posters 3.3k Views 2 Watching
      DarrenO 0 @sdetweil
      The output of the MagicMirror-error.log is as follows :
      /home/serveradmin/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir | at require (node:internal/modules/helpers:130:18)
      0|MagicMir | at loadConfig (/home/serveradmin/MagicMirror/js/app.js:117:14)
      0|MagicMir | at App.start (/home/serveradmin/MagicMirror/js/app.js:250:18)
      0|MagicMir | at Object. (/home/serveradmin/MagicMirror/js/electron.js:193:7)
      0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1256:14)
      0|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
      0|MagicMir | at Module.load (node:internal/modules/cjs/loader:1098:32)
      0|MagicMir | at Module._load (node:internal/modules/cjs/loader:945:12)
      0|MagicMir | MESA-INTEL: warning: Bay Trail Vulkan support is incomplete
      0|MagicMir | libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
      0|MagicMir | /home/serveradmin/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | [2024-04-29 22:15:24.769] [ERROR] (node:65585) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘valid-url’
      0|MagicMir | Require stack:
      0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
      0|MagicMir | - /home/serveradmin/MagicMirror/js/app.js
      0|MagicMir | - /home/serveradmin/MagicMirror/js/electron.js
      0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
      0|MagicMir | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
      0|MagicMir | at Module._resolveFilename (/home/serveradmin/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir | at Module._load (node:internal/modules/cjs/loader:908:27)
      0|MagicMir | at c._load (node:electron/js2c/node_init:2:13672)
      0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1122:19)
      0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js:9:16)
      0|MagicMir | at loadModule (/home/serveradmin/MagicMirror/js/app.js:183:19)
      0|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
      0|MagicMir | [2024-04-29 22:15:24.769] [ERROR] (node:65585) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      0|MagicMir | [66191:0429/230235.459040:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/230235.561159:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/230235.572084:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/230235.577044:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/234504.968361:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/234505.073793:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/234505.089665:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
      0|MagicMir | [66191:0429/234505.092215:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion ‘GDK_IS_MONITOR (monitor)’ failed
        sdetweil @DarrenO 0
        @DarrenO-0 said in MMM-CalendarWeek doesn't display:
        yes, this module did not document using a library that we have deleted as no longer needed by the builtin support
        oops
        fix by loading it in the module folder
        BUT this module also does not provide the file to document use either soo, in the module folder do
        npm init -y
        npm install valid-url
          DarrenO 0 @sdetweil
          Run those commands in the folder for the MMM-CalendarWeek folder, or in the modules folder itself?
          I ran it in both folders and restarted MM but nothing changed. Still just a blank screen.
            sdetweil @DarrenO 0
            @DarrenO-0 in THAT module’s folder
              sdetweil @DarrenO 0
              @DarrenO-0 and look at the log output again
                DarrenO 0 @sdetweil
                Last 50 lines :
                0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js:2:15)
                0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js:3:12)
                0|MagicMir | [2024-04-30 10:22:06.362] [ERROR] (node:69620) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                0|MagicMir | [2024-04-30 12:07:20.093] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js
                0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js
                0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/calendarfetcher.js
                0|MagicMir | [2024-04-30 12:07:20.094] [ERROR] (node:70593) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                  sdetweil @DarrenO 0
                  yep repeat as before.
                  don’t do the npm init
                  see
                    DarrenO 0 @sdetweil
                    re-ran “npm install valid-url” in the /modules/ folder and then restarted MM with pm2 restart MagicMIrror.
                    re-ran pm2 logs --lines=50
                    0|MagicMir | [2024-04-30 12:40:31.257] [ERROR] (node:71169) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    0|MagicMir | [2024-04-30 12:40:46.686] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                    0|MagicMir | [2024-04-30 12:40:46.687] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      sdetweil @DarrenO 0
                      no…
                      MMM-CalendarWeek
                        DarrenO 0 @sdetweil
                        appears to be the same result :
                        0|MagicMir | [2024-04-30 12:56:17.257] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                        0|MagicMir | [2024-04-30 12:56:17.258] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
