    Modul CalendarExt3Agenda
    12 Posts 3 Posters 3.3k Views 3 Watching
    • O Offline
      Old_Death
      I would like to combine the two functions eventFilter and eventTransform.
      Here is the example:
      eventFilter: (ev) => {
      if (ev.title.search(“Natalia:”)) return false
      return true
      eventTransform: (ev) => {
      if (ev.title.search(“Natalia:”) > -1) ev.title=ev.title.replace(“Natalia:”,“”);
      return ev
      But only the first function (Filter) works, but not the second (Transform)
      Can someone please help me with this?
      • O Offline
        Old_Death @MMRIZE
        @MMRIZE Thank you very much, it works now!
          MMRIZE @Old_Death
          @Old_Death
          It is contradiction. You can’t do both thing - drop the event or replace the title at same time. What is your purpose? (And filtering is executed primarily than transforming)
          • O Offline
            Old_Death
            I only want the dates to be shown with the title “Natalia”. These titles should then be changed. The text “Natalia” should be removed here.
            M 4 Replies Last reply Reply Quote 0
              MMRIZE @Old_Death
              @Old_Death
              You want;
              1. Only events which have title “Natalia” would be shown, others should be filtered out.
              2. Then the event (with title “Natalia”) should change its title. Right?
                MMRIZE @Old_Death
                  MMRIZE @Old_Death
                  @Old_Death
                  Sorry, there was a bug that filtering or transforming performs twice, I’ll fix it soon.
                    MMRIZE @Old_Death
                    @Old_Death
                    I updated it to 1.4.4. Please update or reinstall the module.
                    I found a bug about twice applying the user event filter/transformer on the drawing miniMonth and agenda board.
                    However, that is not the real reason for your symptoms. You just made a mistake on your filtering. (You drop out “Natalia” events by filtering, so they were not able to be transformed.)
                    Anyway, here is my example.
                    	return (ev.title.search('Test') > -1)
                    eventTransformer: (ev) => {
                    	ev.title = ev.title.replace('Test', '@')
                    	return ev
                    This code means
                    1. Filter out all other events except the event which has Test in the title.
                    2. Then transform Test to @.
                    You can see the result below;
                    ORIGINAL
                    CONFIGURED
                    O 2 Replies Last reply Reply Quote 0
                    • O Offline
                      Old_Death @MMRIZE
                      @MMRIZE
                      thanks for the answer and the patch.
                      I installed this, but unfortunately there was no improvement in the result.
                      If I enter it like in the example, there are no more entries.
                      The points for the appointments are only displayed correctly in the mini calendar.
                      Here is my config for the module.
                            module: "MMM-CalendarExt3Agenda",
                            carouselId: "Seite2",
                            header: "Natalia",
                            instanceId: "basicCalendar",
                            locale: 'de-DE',
                            firstDayOfWeek: 1,
                            startDayIndex: -1,
                      		  endDayIndex: 15,
                            onlyEventDays: 15,
                      	         return (ev.title.search("Natalia:") > -1)
                      	         ev.title = ev.title.replace("Natalia:", "")
                      	         return ev
                      • O Offline
                        Old_Death @MMRIZE
                        @MMRIZE said in Modul CalendarExt3Agenda:
                        I also have a fundamental question of understanding.
                        The ’ character is used in the examples here.
                        I have to use the character " for it to work.
                        Why is that?
                          sdetweil @Old_Death
                          @Old_Death I’m javascript, both the single and double quotes are acceptable
                          note. sometimes in the forum if the text is not in a code block, these characters are shown as word processing form , curved, like this
                          or
                          Instead of the text form
                          ' or "
                            MMRIZE @Old_Death
                            @Old_Death
                            Sorry, there was still another hidden formatting-twice issue. (in onlyEventDays. I didn’t check that part on the previous update.)
                            I fixed it now.
                            • O Offline
                              Old_Death @MMRIZE
                              • O Old_Death referenced this topic on
