    Modul CalendarExt3Agenda
    12 Posts 3 Posters 2.6k Views 3 Watching
      MMRIZE @Old_Death
        MMRIZE @Old_Death
        @Old_Death
        Sorry, there was a bug that filtering or transforming performs twice, I’ll fix it soon.
          MMRIZE @Old_Death
          @Old_Death
          I updated it to 1.4.4. Please update or reinstall the module.
          I found a bug about twice applying the user event filter/transformer on the drawing miniMonth and agenda board.
          However, that is not the real reason for your symptoms. You just made a mistake on your filtering. (You drop out “Natalia” events by filtering, so they were not able to be transformed.)
          Anyway, here is my example.
          eventFilter: (ev) => {
          	return (ev.title.search('Test') > -1)
          eventTransformer: (ev) => {
          	ev.title = ev.title.replace('Test', '@')
          	return ev
          This code means
          1. Filter out all other events except the event which has Test in the title.
          2. Then transform Test to @.
          You can see the result below;
          ORIGINAL
          CONFIGURED
          O 2 Replies Last reply Reply Quote 0
          • O Offline
            Old_Death @MMRIZE
            @MMRIZE
            thanks for the answer and the patch.
            I installed this, but unfortunately there was no improvement in the result.
            If I enter it like in the example, there are no more entries.
            The points for the appointments are only displayed correctly in the mini calendar.
            Here is my config for the module.
                  module: "MMM-CalendarExt3Agenda",
                  carouselId: "Seite2",
                  header: "Natalia",
                  instanceId: "basicCalendar",
                  locale: 'de-DE',
                  firstDayOfWeek: 1,
                  startDayIndex: -1,
            		  endDayIndex: 15,
                  onlyEventDays: 15,
            	         return (ev.title.search("Natalia:") > -1)
            	         ev.title = ev.title.replace("Natalia:", "")
            	         return ev
            • O Offline
              Old_Death @MMRIZE
              @MMRIZE said in Modul CalendarExt3Agenda:
              I also have a fundamental question of understanding.
              The ’ character is used in the examples here.
              I have to use the character " for it to work.
              Why is that?
                sdetweil @Old_Death
                @Old_Death I’m javascript, both the single and double quotes are acceptable
                note. sometimes in the forum if the text is not in a code block, these characters are shown as word processing form , curved, like this
                or
                Instead of the text form
                ' or "
                  MMRIZE @Old_Death
                  @Old_Death
                  Sorry, there was still another hidden formatting-twice issue. (in onlyEventDays. I didn’t check that part on the previous update.)
                  I fixed it now.
                  • O Offline
                    Old_Death @MMRIZE
                    @MMRIZE Thank you very much, it works now!
                    • O Old_Death referenced this topic on
