    [Coding] update time from every 1 second to scheduled time
    21 Posts 2 Posters 4.5k Views 2 Watching
    • K Offline
      kent79
      updateLunarCal: function() {
      		var url1 =  ..... ;
      		var self = this;
      		var nextLoad = this.config.updateInterval;
      		fetch(url1)
      			.then((resp) => resp.json())
      			.then(function(data) {
      				self.lunar = data.LunarDate ;
      				self.updateDom();
      			.catch(function(error) {
      				// If there is any error you will catch them here
      		setTimeout(function() {
      			self.updateLunarCal();
      		}, 1000);
      I would like to change as above code of update time from every 1 second to scheduled time. For example: Everyday on 0:00. Please teach me. Thank you
        sdetweil @kent79
        @kent79 sadly there is no magic here… just grunt work…
        you have to calculate the ms til 0:0:0
        you can use the moment library (yes I know other folks its not the new library)
        // Your moment
        var now = moment();   // now
        // Your moment at midnight
        var Midnight = now.clone().startOf('day');  // 00:00:00 today earlier
        // Difference in milliseconds
        var milliseconds_passed_already = now.diff(Midnight, 'milliseconds'); // since 00:00:00
        then subtract
        var milliseconds_til_midnight_tonight = (24*60*60*1000)-milliseconds_passed_already
        • K Offline
          kent79 @sdetweil
          May be I explain it clearly.
          I am developing a lunar calender module. As my above coding, it will connect to json server to get the lunar information ervery 1 second.
          I would like to change it to connect server once on Everyday 00:00.
          Since I am a beginner of coding, I don’t know how to do edit it. Please teach me. Thanks
          • K Offline
            kent79 @kent79
            		var url1 = "https://abc ....";
            		var self = this;
            		fetch(url1)
            				// Here you get the data to modify as you please
            				self.lunar = data.LunarDate;
            				self.updateDom();
            			if (moment().hours() === 0 && moment().minutes() === 0 && moment().second() === 0) {
            			else{
            		}, 100);
            I have revised as above code. Is it achieve my goal?
              sdetweil @kent79
              @kent79 well, it will work, BUT you make a check every 100 ms… so LOTS of wasted work… let the system work for you
              fetchIt: function(self){
              		fetch(url1)
              				self.updateDom();
              		let MS_in_day = 24*60*60*1000;
              		let now = moment();
              		let MS_til_midnight = MS_in_day - (now.diff(now.clone().startOf('day'), 'milliseconds')
              		// start a one time timer to end of day
              		setTimeout((selft) =>{
              			//in one time timer(at  00:00:00), start interval for next start of day
              			setInterval((selfi)=>{
              				// fetch data, once per day at 00:00:00
              				self.fetchIt(selfi) // use 'this' pointer passed to the interval routine
              			},MS_in_day,
              			  selft)  // pass 'this' pointer passed to us
              			// fetch on the 1st start of day, one time
              			self.fecthIt(selft)
              		}, MS_til_midnight,
              		   this );  // pass 'this' to the timer routine
              		// fetch data now, 1st time
              		this.fetchIt(this);
              K 2 Replies Last reply Reply Quote 0
              • K Offline
                kent79 @sdetweil
                		let now = moment();
                		let MS_til_midnight = MS_in_day - (now.diff(now.clone().startOf('day'), 'milliseconds'));
                				selfi.fetchIt(selfi) // use 'this' pointer passed to the interval routine
                			},MS_in_day,
                			selft.fecthIt(selft)
                		}, MS_til_midnight,
                		this.fetchIt(this);
                Thank you so much for your reply. I got error while running above function. There may be some syntax error. But I can’t fix it. Please help me again. Thanks
                • K Offline
                  kent79 @sdetweil
                  It seems OK now. I will test it on tonight and will share it to all later. Thank you so much.
                    sdetweil @kent79
                    @kent79 error, yeh, sorry, forgot to change the self?.fetchIt() to use the right self pointer… fixed now
                    • K Offline
                      kent79 @sdetweil
                      @sdetweil said in [Coding] update time from every 1 second to scheduled time:
                      Would you like to tell me which line need to update since I don’t know how to do? I have tested the above code, no syntax error, but no working while on 00:00. Thanks
                        sdetweil @kent79
                        @kent79 I updated my prior post
                        • K Offline
                          kent79 @sdetweil
                          Sorry, it still not working. I would like to share the module as below. Would you please help to fix it? Many thanks.
                          https://www.dropbox.com/scl/fi/qxcbjuibaaaz7ojwr7ucs/MMM-Lunar.zip?rlkey=4zeyqxpp4ibchq2znb5mwpvjr&dl=0
                            sdetweil @kent79
                            @kent79 here you go
                            use this repo
                            git clone https://github.com/sdetweil/MMM-Lunar.git
                            then u can git init to wipe out my repo
                            the BIG cause was that your start routine
                            called
                            this.updateLunarCal();
                            not
                            this.updateLunarDate();
                            start also doesn’t need to call fetchIt as the updateLunarDate does that after setting up the timer
                            I cleaned up the rest…
                            you can test by setting the ‘end time’ in ms…
                            hour and minute and then see it fire the setTimeout handler
                            see comment in the code
                            • K Offline
                              kent79 @sdetweil
                              Thank you for your all effort. My dream is coming true soon.
                              I have tested. No Luck. Don’t know is it coding program or my testing method wrong.
                              I am using windows brower to connect MM server. Then, changing windows clock to 23:59. After 00:00, there is no any changing of Lunar date.
                                sdetweil @kent79
                                @kent79 said in [Coding] update time from every 1 second to scheduled time:
                                you have to set the clock BEFORE opening the MM page… it doesn’t reset when the clock changes…
                                the code only sets up ONCE when loaded, so the clock has to be set first…
                                learn to use the developers window, ctrl-shift-i , sources tab,
                                you can step thru the code
                                ohhhhhh
                                and I gave it set to trigger BEFORE midnight… see the code, comment out and restore the 24×60… so you could test without having to reset the clock
                                • K Offline
                                  kent79 @sdetweil
                                  I have tested again. But it is still not up to date while past 0:00 :(
                                    sdetweil @kent79
                                    @kent79 did u edit the code and change the constant back?
                                    • K Offline
                                      kent79 @sdetweil
                                      of course. I have still no idea
                                        sdetweil @kent79
                                        @kent79 if you edit the constant so it is 5 minutes from now, does it trigger?
                                        the fetch will still get today’s time
                                        • K Offline
                                          kent79 @sdetweil
                                          I find out line 41 coding is wrong, the correct value is “MS_in_day = 10006060*24”. I have tested and work fine now. Thanks.
                                          Orginal:
                                          let MS_in_day =
                                          20*60*60*1000+8*60*1000  //24*60*60*1000;
                                          New:
                                          let MS_in_day = 1000*60*60*24;
                                          • K Offline
                                            kent79 @sdetweil
                                            Combined the lunar script to default clock module. It looks great. Thank you again for your great help. :)
