    [Coding] update time from every 1 second to scheduled time
    21 Posts 2 Posters 4.4k Views 2 Watching
    • K Offline
      kent79 @sdetweil
      May be I explain it clearly.
      I am developing a lunar calender module. As my above coding, it will connect to json server to get the lunar information ervery 1 second.
      I would like to change it to connect server once on Everyday 00:00.
      Since I am a beginner of coding, I don’t know how to do edit it. Please teach me. Thanks
      • K Offline
        kent79 @kent79
        updateLunarCal: function() {
        		var url1 = "https://abc ....";
        		var self = this;
        		fetch(url1)
        			.then((resp) => resp.json())
        			.then(function(data) {
        				// Here you get the data to modify as you please
        				self.lunar = data.LunarDate;
        				self.updateDom();
        			.catch(function(error) {
        				// If there is any error you will catch them here
        		setTimeout(function() {
        			if (moment().hours() === 0 && moment().minutes() === 0 && moment().second() === 0) {
        				self.updateLunarCal();
        			else{
        		}, 100);
        I have revised as above code. Is it achieve my goal?
          sdetweil @kent79
          @kent79 well, it will work, BUT you make a check every 100 ms… so LOTS of wasted work… let the system work for you
          fetchIt: function(self){
          		fetch(url1)
          				self.updateDom();
          		let MS_in_day = 24*60*60*1000;
          		let now = moment();
          		let MS_til_midnight = MS_in_day - (now.diff(now.clone().startOf('day'), 'milliseconds')
          		// start a one time timer to end of day
          		setTimeout((selft) =>{
          			//in one time timer(at  00:00:00), start interval for next start of day
          			setInterval((selfi)=>{
          				// fetch data, once per day at 00:00:00
          				self.fetchIt(selfi) // use 'this' pointer passed to the interval routine
          			},MS_in_day,
          			  selft)  // pass 'this' pointer passed to us
          			// fetch on the 1st start of day, one time
          			self.fecthIt(selft)
          		}, MS_til_midnight,
          		   this );  // pass 'this' to the timer routine
          		// fetch data now, 1st time
          		this.fetchIt(this);
          K 2 Replies Last reply Reply Quote 0
          • K Offline
            kent79 @sdetweil
            		let now = moment();
            		let MS_til_midnight = MS_in_day - (now.diff(now.clone().startOf('day'), 'milliseconds'));
            				selfi.fetchIt(selfi) // use 'this' pointer passed to the interval routine
            			},MS_in_day,
            			selft.fecthIt(selft)
            		}, MS_til_midnight,
            		this.fetchIt(this);
            Thank you so much for your reply. I got error while running above function. There may be some syntax error. But I can’t fix it. Please help me again. Thanks
            • K Offline
              kent79 @sdetweil
              It seems OK now. I will test it on tonight and will share it to all later. Thank you so much.
                sdetweil @kent79
                @kent79 error, yeh, sorry, forgot to change the self?.fetchIt() to use the right self pointer… fixed now
                • K Offline
                  kent79 @sdetweil
                  @sdetweil said in [Coding] update time from every 1 second to scheduled time:
                  Would you like to tell me which line need to update since I don’t know how to do? I have tested the above code, no syntax error, but no working while on 00:00. Thanks
                    sdetweil @kent79
                    @kent79 I updated my prior post
                    • K Offline
                      kent79 @sdetweil
                      Sorry, it still not working. I would like to share the module as below. Would you please help to fix it? Many thanks.
                      https://www.dropbox.com/scl/fi/qxcbjuibaaaz7ojwr7ucs/MMM-Lunar.zip?rlkey=4zeyqxpp4ibchq2znb5mwpvjr&dl=0
                        sdetweil @kent79
                        @kent79 here you go
                        use this repo
                        git clone https://github.com/sdetweil/MMM-Lunar.git
                        then u can git init to wipe out my repo
                        the BIG cause was that your start routine
                        called
                        this.updateLunarCal();
                        not
                        this.updateLunarDate();
                        start also doesn’t need to call fetchIt as the updateLunarDate does that after setting up the timer
                        I cleaned up the rest…
                        you can test by setting the ‘end time’ in ms…
                        hour and minute and then see it fire the setTimeout handler
                        see comment in the code
