    MMM-CalendarExt2 not working
    8 Posts 3 Posters 1.5k Views 3 Watching
      MMRIZE @veny
      @veny
      That error log doesn’t help. No idea.
      • BKeyportB Offline
        BKeyport Module Developer @veny
        @veny I see you’re using google. They may have discontinued the access methods used within Ext2. You should upgrade to Ext3.
        • V Offline
          veny @BKeyport
          @BKeyport
          Can i use Yahoo Calendar or ohters?
          I’d like use plagin MMM-CalendarExtMinimonth because i like his appearance
            MMRIZE @veny
            @veny
            I tested but nothing special wrong.
            This is my config for my Google Calendar ics.
              module: 'MMM-CalendarExt2',
                calendars : [
                    url: "https://calendar.google.com/calendar/ical/4b9c...6390%40group.calendar.google.com/private-e481c...c7cc/basic.ics",
            		scenes: [
            		views: [
            				mode: "daily",
            I used Secret address URL for ical format, you looks also use that URL too.
            [2024-05-18 13:27:05.414] [LOG]   [CALEXT2] calendar:0 >> Scanned: 1, Selected: 1
            Your log says the parsing completed successfully for your ics. It may have 1 event.
            However, I have no idea why the module doesn’t appear. Maybe other module may interrupt something.
            To make things simple, you can test a new config without other modules except MMM-CalendarExt2 and clock module. You can focus the issue only.
              MMRIZE
              Anyway, I stopped to maintain CX2.
              You can use MMM-CalendarExt3Agenda instead. It could have similar looks, though not identical.
              • BKeyportB Offline
                @veny Ahh, ext3agenda has a minimonth display, or if you’d like another take on it, my module, MMM-Multimonth does another style of mini calendar display. Both use the very same calendar base, and both will be supported.
                Lots of options for better supported calendar operations. Please take a look at the 3rd Party modules in the title bar above. The List icon "Screenshot 2024-05-19 at 12.55.55.png " will lead the way.
                • V Offline
                  veny @BKeyport
                  @BKeyport
                  Hello. Thank you very much for the hint about the module. I installed it and am using it. Please tell me how I can increase the font size in the name of the month and numbers. Thank you in advance!
