    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 107.7k Views 25 Watching
    • FoziF Offline
      Fozi Project Sponsor @MickyVi
      @mickyvi That’s a totally awsome solution! Really cool!
        MickyVi @Fozi
        @fozi
        Thanks, the compliments from such experienced people are always very welcome !!
        • D dkhorse74 referenced this topic on
          jordan1200
          Thank you for this awesome solution! I just got mine up and running with MMM-PIR-Sensor. I was wondering if any of you have got this microwave sensor to also work with MMM-NearCompliments? I was thinking since it was also inspired by PIR sensor, I could get it to work, but no luck yet.
          • L Offline
            Lipax
            hello,
            i tried this with the microwave sensor, but im out of ideas. i get wrong positives every minute. (i check every 5 sec).
            i added also the ferrite, tried another raspberry, different of these sensors (bought a 5 pack) and placed it in a different room. anyone got any ideas what else i could try?
            or maybe similar microwave sensors i could try?
            any help would be great, tyvm
            uros76U 1 Reply Last reply Reply Quote 0
            • uros76U Offline
              uros76 @Lipax
              @Lipax said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
              hello,
              Did you try and limit the range as described in beginning of this thread? For me option 2 helped to limit oversensitivity.
              • L Offline
                Lipax @uros76
                @uros76
                the range is not the problem. i get positives when nothing is moving near it
                uros76U kayakbabeK 2 Replies Last reply Reply Quote 0
                • uros76U Offline
                  uros76 @Lipax
                  @Lipax this sensor is very sensitive and catches any movement 360 around from several meters away. I had same problem… If you don’t dial down the sensitivity-range you will keep getting false positives.
                  • kayakbabeK Offline
                    kayakbabe @Lipax
                    @Lipax try dialing down the sensitivity, it’s probably picking up dust or something small you can’t see.
                    • L Offline
                      Lipax
                      thanks for the help, but i doubt its some kind of movement since its exactly every minute. i tried a different room and its the same.
                        sdetweil @Lipax
                        @Lipax please don’t submit duplicate posts…
                        all users with reputation below 2 have their posts reviewed… this eliminates all the porn, advertising and trash posts from the forum.
                        it just takes time for (me) to get to review the posts…
                        • 10
                        • 11
                        • 9 / 11
