    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 135.7k Views 25 Watching
    • FoziF
      Fozi Project Sponsor @MickyVi
      @mickyvi Ususally those sensors a quite sensitiv and detect motions even through walls. That was also my case, why I added the trimmer to reduce sensitivity. Maybe the sensor is from a bad lot. You could try anotherone if you have a spare. Those sensors are pretty cheap.
        MickyVi
        Goodmorning everyone,
        after several attempts I have resigned myself to the fact that the doppler sensor cannot pass the 6 mm of glass.
        I also tried to buy a slightly more “expensive” sensor but the result is always the same.
        https://www.amazon.it/gp/product/B089NKGWQQ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
        unfortunately the result is always the same: it detects well from behind but from the front there is no way to pass the signal.
        Even trying to make a window in the plywood the result does not change (same result with “inexpensive” sensor and with “very expensive” sensor.
        Very disappointed and dejected about this. :-(
        I think I’ll try again with simple PIRs maybe with the 2mm hole tutorial. And let’s see what happens.
        Hello everybody
        uros76U 1 Reply Last reply
        • uros76U
          uros76 @MickyVi
          @mickyvi that is sad to hear. The glass you are using must have some special coating that prevents signal go through.
          Did you try to rotate the sensor? I know these sensors are sensing around 360degree but I think the actual antenna is stronger on one side.
          Also, what’s the distance from mirrir you are trying to get the sensor to pick up movement? Does it work fine when using without glass?
          For me PIR was not an option. I tried cheap and expensive PIR sensors and all of them had too many false positives. Plus it needs to be ouside visible.
          M 1 Reply Last reply
            MickyVi @uros76
            @uros76
            Yes, in my opinion it’s the mirror, damn it, if you only knew how much I paid for it …
            Yes, I tried in every way, even putting the sensor behind the monitor (… when you are desperate you try everything …: -) …), turning it, putting it sideways but nothing, it does not detect.
            If I move it outside, it detects everything, but even with the “cheap” sensors I had noticed the same functionality.
            I don’t know, maybe I will also give up motion detection: maybe a button that takes it out of stand by and then stays on for 20 minutes … I know … it’s shit … but I don’t want to continue to have the mirror resting on the floor without being able to install it and continue testing.
            I have to think about it for a while.
            Hello and thanks for the support everyone!
            uros76U FoziF 2 Replies Last reply
            • uros76U
              uros76 @MickyVi
              @mickyvi as the last option maybe install the sensor on top or bottom of the mirror frame. Hide it in a small enclosure (wooden or hard paper or 3D printed extension to the frame) and paint the same color as the frame. If done nicely it won’t even look that bad. And it will for sure work :)
              • FoziF
                @mickyvi That’s indeed really strange, and I can only guess that the mirror has a reflecting coating which prevents the signal from passing through the mirror. The thickness of the glass itself is not the limiting factor, as the signal usually passes even stone walls and can detect motion in adjacent rooms. I operated my sensor first behind the mirror, too, and it worked. It is a 4mm Pilkington. Later I moved it under the frame, because it was easier to trim the sensor and hid it behind a 3D-printed cover. Thus, I’d second @uros76 proposal to mount the sensor on top or on the bottom of the frame where it is not visible. Don’t give up!
                  MickyVi
                  Hello everybody,
                  I’m taking the path of the classic infrared PIR sensor.
                  I made two shells that can be attached under the two arms of the lamps above the mirrors.
                  Here still in the assembly / painting phase:
                  I’m gonna give a nice coat of chrome today and we should be there. :-)
                  FoziF 1 Reply Last reply
                  Reply Quote 2
                  • FoziF
                    @mickyvi That’s a totally awsome solution! Really cool!
                      MickyVi @Fozi
                      @fozi
                      Thanks, the compliments from such experienced people are always very welcome !!
                      • D dkhorse74 referenced this topic on
                        jordan1200
                        Thank you for this awesome solution! I just got mine up and running with MMM-PIR-Sensor. I was wondering if any of you have got this microwave sensor to also work with MMM-NearCompliments? I was thinking since it was also inspired by PIR sensor, I could get it to work, but no luck yet.
                        • L
                          Lipax
                          hello,
                          i tried this with the microwave sensor, but im out of ideas. i get wrong positives every minute. (i check every 5 sec).
                          i added also the ferrite, tried another raspberry, different of these sensors (bought a 5 pack) and placed it in a different room. anyone got any ideas what else i could try?
                          or maybe similar microwave sensors i could try?
                          any help would be great, tyvm
                          • uros76U
                            uros76 @Lipax
                            @Lipax said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                            hello,
                            Did you try and limit the range as described in beginning of this thread? For me option 2 helped to limit oversensitivity.
                            L 1 Reply Last reply
                            • L
                              Lipax @uros76
                              @uros76
                              the range is not the problem. i get positives when nothing is moving near it
                              uros76U kayakbabeK 2 Replies Last reply
                              • uros76U
                                uros76 @Lipax
                                @Lipax this sensor is very sensitive and catches any movement 360 around from several meters away. I had same problem… If you don’t dial down the sensitivity-range you will keep getting false positives.
                                • kayakbabeK
                                  kayakbabe @Lipax
                                  @Lipax try dialing down the sensitivity, it’s probably picking up dust or something small you can’t see.
                                  • L
                                    Lipax
                                    thanks for the help, but i doubt its some kind of movement since its exactly every minute. i tried a different room and its the same.
                                      sdetweil @Lipax
                                      @Lipax please don’t submit duplicate posts…
                                      all users with reputation below 2 have their posts reviewed… this eliminates all the porn, advertising and trash posts from the forum.
                                      it just takes time for (me) to get to review the posts…
                                      • uros76U
                                        uros76
                                        Can you share your python code? Perhaps there’s something there
                                        • L
                                          Lipax @sdetweil
                                          @sdetweil sry about that
                                          @uros76 i hope thats not the problem
                                          import RPi.GPIO as GPIO
                                          import time
                                          import datetime
                                          switch=11
                                          GPIO.setmode(GPIO.BOARD)
                                          GPIO.setup(switch, GPIO.IN)
                                          try:
                                              while True:
                                                  if GPIO.input(switch) == 1:
                                                      now = datetime.datetime.now()
                                                      print(now.strftime("%Y-%m-%d %H:%M:%S"), "something")
                                                  time.sleep(5)
                                          except KeyboardInterrupt:
                                              print("Bye Bye")
                                          finally:
                                              GPIO.cleanup()
                                          thanks for the help
                                          • uros76U
                                            uros76 @Lipax
                                            @Lipax try different gpio pin, like a pin 18 which is a GPIO 5. It’s default set to input function. Don’t forget to adjust the python code, change switch to 18.
                                            You might check the GPIO 0 (your pin 11) if it is set to input. Use command: raspi-gpio get 0 or raspi-gpio get to check all GPIO’s.
                                            Also, use a multimeter to measure the voltage coming out from sensor. It should be around 3.3V for few seconds when sensing detected. This way you can monitor if actual detection / voltage is coming from sensor.
                                            • 5 / 6
