    MM startup problem after update
    42 Posts 3 Posters 10.0k Views 4 Watching
      sdetweil @manu85340
      @manu85340 so, after research. there is no way to get to the latest MagicMirror release on buster.
      unless there is some fix you NEED , I recommend staying where you were til you can plan to upgrade the os.
      now we’ve already tried going forward, so need to jump back.
      can you look in the upgrade log ~/MagicMirror/installers/upgrade.log
      for the string
      upgrading from version
      so we can get you back to that earlier release
      in prep for os migration, and general health backup your MagicMirror system
      see my backup restore
      https://github.com/sdetweil/MagicMirror-backup-restore
        manu85340 @sdetweil
        @sdetweil I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do
        restoring custom.css
        removing git alias
        Upgrade ended - mar. avril 2 10:35:49 CEST 2024
        Upgrade started - mar. avril 2 10:37:27 CEST 2024
        system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
        user requested to apply changes
        doing test run = false
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
        Minimum Node version: v18.18.0
        Installed Node version: v18.18.0
        Check current Node installation …
        No Node.js upgrade necessary.
        Check current NPM installation …
        Minimum npm version: V9.8.1
        Installed npm version: V9.8.1
        No npm upgrade necessary.
        saving custom.css
        remote name = origin
        upgrading from version 2.26.0 to 2.27.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.
        (use “git pull” to update your local branch)
        Untracked files:
        (use “git add …” to include in what will be committed)
        core
        css/icons/
        css/save_custom.css
        modules/default/currentweather/
        nohup.out
        nothing added to commit but untracked files present (use “git add” to track)
        no files different from github version
        test merge result rc=‘’ , if empty, no conflicts
        executing merge, apply specified
        merge result rc= 0
        Updating 118e2123…5ea8a346 Fast-forward .eslintignore
        3 ± .eslintrc.json
        18 ± .github/codecov.yaml
        10 - .github/dependabot.yaml
        15 + .github/workflows/depsreview.yaml
        2 ± .github/workflows/electronRebuild.yaml
        20 + .github/workflows/enforce-pullrequest-rules.yaml
        2 ± .gitignore
        6 ± .husky/pre-commit
        2 - .npmrc
        1 + .prettierignore
        2 + CHANGELOG.md
        199 ± Collaboration.md
        24 ± LICENSE.md
        2 ± README.md
        10 ± clientonly/index.js
        4 ± config/config.js.sample
        5 ± css/custom.css.sample
        8 ± fonts/package-lock.json
        18 ± fonts/package.json
        11 ± js/animateCSS.js
        7 - js/app.js
        42 ± js/check_config.js
        23 ± js/defaults.js
        8 ± js/deprecated.js
        8 - js/electron.js
        1 + js/loader.js
        6 - js/logger.js
        43 ± js/main.js
        6 - js/module.js
        6 ± js/node_helper.js
        6 - js/server.js
        16 ± js/server_functions.js
        4 ± js/socketclient.js
        6 - js/translator.js
        6 - js/utils.js
        Bin 0 -> 6947 bytes modules/default/alert/alert.js
        6 - modules/default/calendar/calendar.js
        33 ± modules/default/calendar/calendarfetcher.js
        9 ± modules/default/calendar/calendarfetcherutils.js
        268 ± modules/default/calendar/calendarutils.js
        6 - modules/default/calendar/debug.js
        3 - modules/default/calendar/node_helper.js
        15 ± modules/default/clock/clock.js
        11 ± modules/default/compliments/compliments.js
        8 ± modules/default/defaultmodules.js
        5 ± modules/default/helloworld/helloworld.js
        6 - modules/default/newsfeed/newsfeed.js
        43 ± modules/default/newsfeed/newsfeedfetcher.js
        13 ± modules/default/newsfeed/node_helper.js
        7 - modules/default/updatenotification/git_helper.js
        10 ± …/default/updatenotification/update_helper.js
        57 ± …/updatenotification/updatenotification.js
        10 ± modules/default/weather/current.njk
        56 ± modules/default/weather/providers/envcanada.js
        8 ± modules/default/weather/providers/openmeteo.js
        12 ± …/default/weather/providers/openweathermap.js
        9 ± modules/default/weather/providers/pirateweather.js
        11 ± modules/default/weather/providers/smhi.js
        12 ± modules/default/weather/providers/ukmetoffice.js
        9 ± …/weather/providers/ukmetofficedatahub.js
        9 ± modules/default/weather/providers/weatherbit.js
        11 ± modules/default/weather/providers/weatherflow.js
        10 ± modules/default/weather/providers/weathergov.js
        10 ± modules/default/weather/providers/yr.js
        10 ± modules/default/weather/weather.js
        14 ± modules/default/weather/weatherobject.js
        12 - modules/default/weather/weatherprovider.js
        9 ± modules/default/weather/weatherutils.js
        6 - package-lock.json
        4180 ++++++++++++±------ package.json
        60 ± serveronly/index.js
        2 ± tests/configs/default.js
        5 - tests/configs/empty_ipWhiteList.js
        5 - tests/configs/modules/alert/default.js
        5 - tests/configs/modules/calendar/auth-default.js
        5 - tests/configs/modules/calendar/bad_rrule.js
        5 - tests/configs/modules/calendar/basic-auth.js
        5 - tests/configs/modules/calendar/changed-port.js
        5 - tests/configs/modules/calendar/custom.js
        6 ± tests/configs/modules/calendar/default.js
        5 - …/{exdate.js => exdate_la_at_midnight_dst.js}
        13 ± …/modules/calendar/exdate_la_at_midnight_std.js
        37 + …/modules/calendar/exdate_la_before_midnight.js
        37 + …/modules/calendar/exdate_syd_at_midnight_dst.js
        37 + …/modules/calendar/exdate_syd_at_midnight_std.js
        37 + …/modules/calendar/exdate_syd_before_midnight.js
        37 + tests/configs/modules/calendar/fail-basic-auth.js
        7 - …/configs/modules/calendar/long-fullday-event.js
        28 + tests/configs/modules/calendar/old-basic-auth.js
        5 - tests/configs/modules/calendar/recurring.js
        5 - tests/configs/modules/calendar/rrule_until.js
        30 + …/calendar/show-duplicates-in-calendar.js
        5 - …/modules/calendar/single-fullday-event.js
        28 + tests/configs/modules/clock/clock_12hr.js
        5 - tests/configs/modules/clock/clock_24hr.js
        5 - tests/configs/modules/clock/clock_analog.js
        4 - …/modules/clock/clock_displaySeconds_false.js
        5 - …/configs/modules/clock/clock_showDateAnalog.js
        5 - …/configs/modules/clock/clock_showPeriodUpper.js
        5 - tests/configs/modules/clock/clock_showSunMoon.js
        5 - tests/configs/modules/clock/clock_showTime.js
        5 - tests/configs/modules/clock/clock_showWeek.js
        5 - tests/configs/modules/clock/es/clock_12hr.js
        5 - tests/configs/modules/clock/es/clock_24hr.js
        5 - …/modules/clock/es/clock_showPeriodUpper.js
        5 - tests/configs/modules/clock/es/clock_showWeek.js
        6 - …/modules/compliments/compliments_animateCSS.js
        6 - …/compliments_animateCSS_fallbackToDefault.js
        7 - …compliments_animateCSS_invertedAnimationName.js
        6 - …/modules/compliments/compliments_anytime.js
        5 - …/modules/compliments/compliments_date.js
        5 - …/compliments/compliments_only_anytime.js
        5 - …/modules/compliments/compliments_parts_day.js
        5 - …/modules/compliments/compliments_remote.js
        5 - tests/configs/modules/display.js
        5 - tests/configs/modules/helloworld/helloworld.js
        5 - …/modules/helloworld/helloworld_default.js
        5 - tests/configs/modules/newsfeed/default.js
        5 - tests/configs/modules/newsfeed/ignore_items.js
        4 - tests/configs/modules/newsfeed/incorrect_url.js
        4 - tests/configs/modules/newsfeed/prohibited_words.js
        4 - tests/configs/modules/positions.js
        5 - …/modules/weather/currentweather_compliments.js
        5 - …/modules/weather/currentweather_default.js
        6 ± …/modules/weather/currentweather_options.js
        7 ± …/modules/weather/currentweather_units.js
        7 ± …/modules/weather/forecastweather_absolute.js
        5 - …/modules/weather/forecastweather_default.js
        5 - …/modules/weather/forecastweather_options.js
        5 - …/modules/weather/forecastweather_units.js
        5 - …/modules/weather/hourlyweather_default.js
        5 - …/modules/weather/hourlyweather_options.js
        5 - …/weather/hourlyweather_showPrecipitation.js
        5 - tests/configs/noIpWhiteList.js
        5 - tests/configs/port_8090.js
        5 - tests/configs/port_variable.js.template
        5 - tests/configs/without_modules.js
        5 - tests/e2e/animateCSS_spec.js
        7 - tests/e2e/fonts_spec.js
        2 ± tests/e2e/helpers/basic-auth.js
        2 ± tests/e2e/modules/calendar_spec.js
        31 + tests/e2e/modules/weather_current_spec.js
        16 ± tests/e2e/serveronly_spec.js
        2 ± tests/e2e/template_spec.js
        2 ± tests/e2e/translations_spec.js
        4 ± tests/electron/env_spec.js
        2 ± tests/electron/helpers/global-setup.js
        6 ± tests/electron/modules/calendar_spec.js
        105 ± tests/mocks/calendar_test_exdate.ics
        34 - tests/mocks/calendar_test_full_day_events.ics
        33 + …/calendar_test_multi_day_starting_today.ics
        33 + tests/mocks/exdate_la_at_midnight_dst.ics
        15 + tests/mocks/exdate_la_at_midnight_std.ics
        15 + tests/mocks/exdate_la_before_midnight.ics
        15 + tests/mocks/exdate_syd_at_midnight_dst.ics
        15 + tests/mocks/exdate_syd_at_midnight_std.ics
        15 + tests/mocks/exdate_syd_before_midnight.ics
        15 + tests/mocks/rrule_until.ics
        24 + tests/unit/classes/class_spec.js
        2 ± tests/unit/classes/translator_spec.js
        2 ± tests/unit/classes/utils_spec.js
        35 ± tests/unit/functions/cmp_versions_spec.js
        2 ± tests/unit/functions/updatenotification_spec.js
        22 ± tests/unit/global_vars/defaults_modules_spec.js
        4 ± tests/unit/global_vars/root_path_spec.js
        4 ± tests/utils/weather_mocker.js
        13 ± translations/et.json
        31 ± translations/translations.js
        7 - vendor/package-lock.json
        10 ± vendor/package.json
        9 ± vendor/vendor.js
        6 - 173 files changed, 4108 insertions(+), 2557 deletions(-) delete mode 100644 .github/codecov.yaml
        create mode 100644 .github/workflows/electronRebuild.yaml
        create mode 100644 mm2.png rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
        create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
        create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
        create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
        create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
        create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
        create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
        create mode 100644 tests/configs/modules/calendar/rrule_until.js
        create mode 100644 tests/configs/modules/calendar/single-fullday-event.js delete mode 100644 tests/mocks/calendar_test_exdate.ics
        create mode 100644 tests/mocks/calendar_test_full_day_events.ics
        create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
        create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
        create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
        create mode 100644 tests/mocks/exdate_la_before_midnight.ics
        create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
        create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
        create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
        create mode 100644 tests/mocks/rrule_until.ics
        processor architecture is armv7l
        magicmirror@2.27.0 postinstall
        npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        magicmirror@2.27.0 install-vendor
        echo "Installing vendor files …
        " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 1 package in 3s
        magicmirror@2.27.0 install-fonts
        echo "Installing fonts …
        " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        Installing fonts …
        changed 2 packages in 6s
        magicmirror@2.27.0 prepare
        [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
        no husky installed.
        added 483 packages in 2m
        112 packages are looking for funding
        run npm fund for details
        npm install completed - mar. avril 2 10:39:31 CEST 2024 on base
        fixing sandbox permissions
        downloading dumpactivemodules script
        updating dependencies for active modules with package.json files
        processing for module MMM-OneCallWeather please wait
        added 1 package, and audited 2 packages in 4s
        found 0 vulnerabilities
        processing complete for module MMM-OneCallWeather
        processing for module MMM-ISS-Map please wait
        added 1 package, and audited 2 packages in 7s
        processing complete for module MMM-ISS-Map
        processing for module MMM-ISS-Live please wait
        up to date, audited 1 package in 2s
        processing complete for module MMM-ISS-Live
        removing git alias
        Upgrade ended - mar. avril 2 10:39:54 CEST 2024
          sdetweil @manu85340
          @manu85340 ok, we need to back up to version 2.27 and node 18
          so, first lets go back to node 18
          sudo n 18
          verify
          node -v
          should return something like this
          ~/MagicMirror$ node -v
          v18.20.3
          if that is successful, then on to MagicMirror
          git fetch --tags
          git checkout -b temp v.2.27.0
          rm package-lock.json
          rm -rf node_modules
          npm run install-mm
          then MagicMirror should start and run
          npm start
          and not for startup
          sudo reboot
            manu85340 @sdetweil
            @sdetweil Sam I have an error when I pass the line
            pi@MagicMirror:~ $ node -v
            v18.20.3
            pi@MagicMirror:~ $ cd ~/MagicMirror
            pi@MagicMirror:~/MagicMirror $ git fetch --tags
            remote: Enumerating objects: 4, done.
            remote: Counting objects: 100% (4/4), done.
            remote: Compressing objects: 100% (4/4), done.
            remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
            D▒paquetage des objets: 100% (4/4), fait.
            Depuis https://github.com/MagicMirrorOrg/MagicMirror
            • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
              ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
              pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
              fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
            so I’m not going any further, I’m waiting for your instructions
              sdetweil @manu85340
              @manu85340 said in MM startup problem after update:
              my fault (that little dot after the v!..) sorry
              git checkout -b temp v2.27.0
                manu85340 @sdetweil
                @sdetweil I have an error see below, thanks Sam
                pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
                Basculement sur la nouvelle branche ‘temp’
                pi@MagicMirror:~/MagicMirror $ rm package-lock.json
                pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
                pi@MagicMirror:~/MagicMirror $ npm run install-mm
                magicmirror@2.27.0 install-mm
                npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                <— Last few GCs —>
                [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
                [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
                <— JS stacktrace —>
                FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                Aborted
                • BKeyportB Offline
                  BKeyport Module Developer @manu85340
                  You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                    manu85340 @BKeyport
                    @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                      sdetweil @manu85340
                      @manu85340 see this post (and the one before it) in an issue w the same problem
                      https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                        manu85340 @sdetweil
                        @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                          sdetweil @manu85340
                          @manu85340 I don’t understand.
                          we have restored back to 2.27
                          2.28 will not run on buster
                          you need the next at least bullseye
                          bur if you are upgrading, go to current, bookworm
                            manu85340 @sdetweil
                            @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                            so I didn't pass the other command lines
                            rm -rf node_modules
                            npm run install-mm
                              sdetweil @manu85340
                              @manu85340 yes and I replied with the corrected command
                              https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042
                                manu85340 @sdetweil
                                @sdetweil Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```
                                npm run install-mm
                                <— Last few GCs —>
                                [12543:0x5273870] 17046 ms: Mark-sweep (reduce) 226.7 (234.0) -> 226.5 (234.0 ) MB, 147.4 / 0.0 ms (+ 65.0 ms in 7 steps since start of marking, biggest step 17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m u = 0.346) allo[12543:0x5273870] 17258 ms: Mark-sweep (reduce) 226.9 (234.0) -> 226.9 (234.5) MB, 207.1 / 0.0 ms (average mu = 0.705, current mu = 0.026) al location failure; scavenge might not succeed
                                <— JS stacktrace —>
                                FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor y
                                Aborted
                                  sdetweil @manu85340
                                  @manu85340 and then i posted another link with instructions for that problem
                                    manu85340 @sdetweil
                                    @sdetweil Sam thanks for your help, but I think I’m going to give up… nothing works, I have another MM I’m going to copy the sd card and copy it to that of my MM and not do an update, if I understood correctly that it is the operating system that does not support updating? if this is it on which system should I install MM please?
                                      sdetweil @manu85340
                                      @manu85340 the latest raspi OS is bookworm…
                                      if this is a pi3 Id do the 32 bit version to save memory space.
                                      I have updated the installer and upgrader to fail if trying to install or upgrade now on buster
                                      • 2 / 3
