    MM startup problem after update
    42 Posts 3 Posters 11.7k Views 4 Watching
      sdetweil @manu85340
      @manu85340 ok, we need to back up to version 2.27 and node 18
      so, first lets go back to node 18
      sudo n 18
      verify
      node -v
      should return something like this
      ~/MagicMirror$ node -v
      v18.20.3
      if that is successful, then on to MagicMirror
      git fetch --tags
      git checkout -b temp v.2.27.0
      rm package-lock.json
      rm -rf node_modules
      npm run install-mm
      then MagicMirror should start and run
      npm start
      and not for startup
      sudo reboot
      M 1 Reply Last reply
        manu85340 @sdetweil
        @sdetweil Sam I have an error when I pass the line
        pi@MagicMirror:~ $ node -v
        v18.20.3
        pi@MagicMirror:~ $ cd ~/MagicMirror
        pi@MagicMirror:~/MagicMirror $ git fetch --tags
        remote: Enumerating objects: 4, done.
        remote: Counting objects: 100% (4/4), done.
        remote: Compressing objects: 100% (4/4), done.
        remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
        D▒paquetage des objets: 100% (4/4), fait.
        Depuis https://github.com/MagicMirrorOrg/MagicMirror
        • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
          ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
          pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
          fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
        so I’m not going any further, I’m waiting for your instructions
          sdetweil @manu85340
          @manu85340 said in MM startup problem after update:
          my fault (that little dot after the v!..) sorry
          git checkout -b temp v2.27.0
            manu85340 @sdetweil
            @sdetweil I have an error see below, thanks Sam
            pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
            Basculement sur la nouvelle branche ‘temp’
            pi@MagicMirror:~/MagicMirror $ rm package-lock.json
            pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
            pi@MagicMirror:~/MagicMirror $ npm run install-mm
            magicmirror@2.27.0 install-mm
            npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            <— Last few GCs —>
            [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
            [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
            <— JS stacktrace —>
            FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
            Aborted
            BKeyportB 1 Reply Last reply
            • BKeyportB
              BKeyport Module Developer @manu85340
              You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                manu85340 @BKeyport
                @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                  sdetweil @manu85340
                  @manu85340 see this post (and the one before it) in an issue w the same problem
                  https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                    manu85340 @sdetweil
                    @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                      sdetweil @manu85340
                      @manu85340 I don’t understand.
                      we have restored back to 2.27
                      2.28 will not run on buster
                      you need the next at least bullseye
                      bur if you are upgrading, go to current, bookworm
                        manu85340 @sdetweil
                        @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                        so I didn't pass the other command lines
                        rm -rf node_modules
                        npm run install-mm
                          sdetweil @manu85340
                          @manu85340 yes and I replied with the corrected command
                          https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042
                            manu85340 @sdetweil
                            @sdetweil Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```
                            npm run install-mm
                            <— Last few GCs —>
                            [12543:0x5273870] 17046 ms: Mark-sweep (reduce) 226.7 (234.0) -> 226.5 (234.0 ) MB, 147.4 / 0.0 ms (+ 65.0 ms in 7 steps since start of marking, biggest step 17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m u = 0.346) allo[12543:0x5273870] 17258 ms: Mark-sweep (reduce) 226.9 (234.0) -> 226.9 (234.5) MB, 207.1 / 0.0 ms (average mu = 0.705, current mu = 0.026) al location failure; scavenge might not succeed
                            <— JS stacktrace —>
                            FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor y
                            Aborted
                              sdetweil @manu85340
                              @manu85340 and then i posted another link with instructions for that problem
                                manu85340 @sdetweil
                                @sdetweil Sam thanks for your help, but I think I’m going to give up… nothing works, I have another MM I’m going to copy the sd card and copy it to that of my MM and not do an update, if I understood correctly that it is the operating system that does not support updating? if this is it on which system should I install MM please?
                                  sdetweil @manu85340
                                  @manu85340 the latest raspi OS is bookworm…
                                  if this is a pi3 Id do the 32 bit version to save memory space.
                                  I have updated the installer and upgrader to fail if trying to install or upgrade now on buster
                                  • 2 / 3
