    MM startup problem after update
    42 Posts 3 Posters 11.4k Views 4 Watching
      manu85340 @sdetweil
      pi@MagicMirror:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      pi@MagicMirror:~ $
        manu85340 @sdetweil
        @sdetweil do you need installers/update.log by email?
          sdetweil @manu85340
          @manu85340 ok. script forces node 18 on buster. hang on. I’ll debug
          could u give me output of command n
          it might say unknown
          or give a list
            manu85340 @sdetweil
            @sdetweil I typed “n” and there is nothing
              sdetweil @manu85340
              @manu85340 ok,
              do
              sudo npm I-g n
              sudo n 20
              then node -v
                manu85340 @sdetweil
                pi@MagicMirror:~ $ sudo npm I-g n
                Unknown command: "I-g"
                To see a list of supported npm commands, run:
                  npm help
                pi@MagicMirror:~ $ sudo n 20
                  installing : node-v20.15.0
                       mkdir : /usr/local/n/versions/node/20.15.0
                       fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
                     copying : node/20.15.0
                node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
                /usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
                   installed :  (with npm )
                pi@MagicMirror:~ $ node -v
                pi@MagicMirror:~ $ node-v
                -bash: node-v : commande introuvable
                pi@MagicMirror:~ $
                  sdetweil @manu85340
                  @manu85340 grr… that was the problem finding the c++ lib for buster.
                  let me research, be a couple hours
                    manu85340 @sdetweil
                    @sdetweil OK thanks to you
                      sdetweil @manu85340
                      @manu85340 so, after research. there is no way to get to the latest MagicMirror release on buster.
                      unless there is some fix you NEED , I recommend staying where you were til you can plan to upgrade the os.
                      now we’ve already tried going forward, so need to jump back.
                      can you look in the upgrade log ~/MagicMirror/installers/upgrade.log
                      for the string
                      upgrading from version
                      so we can get you back to that earlier release
                      in prep for os migration, and general health backup your MagicMirror system
                      see my backup restore
                      https://github.com/sdetweil/MagicMirror-backup-restore
                        manu85340 @sdetweil
                        @sdetweil I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do
                        restoring custom.css
                        removing git alias
                        Upgrade ended - mar. avril 2 10:35:49 CEST 2024
                        Upgrade started - mar. avril 2 10:37:27 CEST 2024
                        system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                        user requested to apply changes
                        doing test run = false
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                        Minimum Node version: v18.18.0
                        Installed Node version: v18.18.0
                        Check current Node installation …
                        No Node.js upgrade necessary.
                        Check current NPM installation …
                        Minimum npm version: V9.8.1
                        Installed npm version: V9.8.1
                        No npm upgrade necessary.
                        saving custom.css
                        remote name = origin
                        upgrading from version 2.26.0 to 2.27.0
                        fetching latest revisions
                        git fetch rc=0
                        current branch = master
                        On branch master
                        Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.
                        (use “git pull” to update your local branch)
                        Untracked files:
                        (use “git add …” to include in what will be committed)
                        core
                        css/icons/
                        css/save_custom.css
                        modules/default/currentweather/
                        nohup.out
                        nothing added to commit but untracked files present (use “git add” to track)
                        no files different from github version
                        test merge result rc=‘’ , if empty, no conflicts
                        executing merge, apply specified
                        merge result rc= 0
                        Updating 118e2123…5ea8a346 Fast-forward .eslintignore
                        3 ± .eslintrc.json
                        18 ± .github/codecov.yaml
                        10 - .github/dependabot.yaml
                        15 + .github/workflows/depsreview.yaml
                        2 ± .github/workflows/electronRebuild.yaml
                        20 + .github/workflows/enforce-pullrequest-rules.yaml
                        2 ± .gitignore
                        6 ± .husky/pre-commit
                        2 - .npmrc
                        1 + .prettierignore
                        2 + CHANGELOG.md
                        199 ± Collaboration.md
                        24 ± LICENSE.md
                        2 ± README.md
                        10 ± clientonly/index.js
                        4 ± config/config.js.sample
                        5 ± css/custom.css.sample
                        8 ± fonts/package-lock.json
                        18 ± fonts/package.json
                        11 ± js/animateCSS.js
                        7 - js/app.js
                        42 ± js/check_config.js
                        23 ± js/defaults.js
                        8 ± js/deprecated.js
                        8 - js/electron.js
                        1 + js/loader.js
                        6 - js/logger.js
                        43 ± js/main.js
                        6 - js/module.js
                        6 ± js/node_helper.js
                        6 - js/server.js
                        16 ± js/server_functions.js
                        4 ± js/socketclient.js
                        6 - js/translator.js
                        6 - js/utils.js
                        Bin 0 -> 6947 bytes modules/default/alert/alert.js
                        6 - modules/default/calendar/calendar.js
                        33 ± modules/default/calendar/calendarfetcher.js
                        9 ± modules/default/calendar/calendarfetcherutils.js
                        268 ± modules/default/calendar/calendarutils.js
                        6 - modules/default/calendar/debug.js
                        3 - modules/default/calendar/node_helper.js
                        15 ± modules/default/clock/clock.js
                        11 ± modules/default/compliments/compliments.js
                        8 ± modules/default/defaultmodules.js
                        5 ± modules/default/helloworld/helloworld.js
                        6 - modules/default/newsfeed/newsfeed.js
                        43 ± modules/default/newsfeed/newsfeedfetcher.js
                        13 ± modules/default/newsfeed/node_helper.js
                        7 - modules/default/updatenotification/git_helper.js
                        10 ± …/default/updatenotification/update_helper.js
                        57 ± …/updatenotification/updatenotification.js
                        10 ± modules/default/weather/current.njk
                        56 ± modules/default/weather/providers/envcanada.js
                        8 ± modules/default/weather/providers/openmeteo.js
                        12 ± …/default/weather/providers/openweathermap.js
                        9 ± modules/default/weather/providers/pirateweather.js
                        11 ± modules/default/weather/providers/smhi.js
                        12 ± modules/default/weather/providers/ukmetoffice.js
                        9 ± …/weather/providers/ukmetofficedatahub.js
                        9 ± modules/default/weather/providers/weatherbit.js
                        11 ± modules/default/weather/providers/weatherflow.js
                        10 ± modules/default/weather/providers/weathergov.js
                        10 ± modules/default/weather/providers/yr.js
                        10 ± modules/default/weather/weather.js
                        14 ± modules/default/weather/weatherobject.js
                        12 - modules/default/weather/weatherprovider.js
                        9 ± modules/default/weather/weatherutils.js
                        6 - package-lock.json
                        4180 ++++++++++++±------ package.json
                        60 ± serveronly/index.js
                        2 ± tests/configs/default.js
                        5 - tests/configs/empty_ipWhiteList.js
                        5 - tests/configs/modules/alert/default.js
                        5 - tests/configs/modules/calendar/auth-default.js
                        5 - tests/configs/modules/calendar/bad_rrule.js
                        5 - tests/configs/modules/calendar/basic-auth.js
                        5 - tests/configs/modules/calendar/changed-port.js
                        5 - tests/configs/modules/calendar/custom.js
                        6 ± tests/configs/modules/calendar/default.js
                        5 - …/{exdate.js => exdate_la_at_midnight_dst.js}
                        13 ± …/modules/calendar/exdate_la_at_midnight_std.js
                        37 + …/modules/calendar/exdate_la_before_midnight.js
                        37 + …/modules/calendar/exdate_syd_at_midnight_dst.js
                        37 + …/modules/calendar/exdate_syd_at_midnight_std.js
                        37 + …/modules/calendar/exdate_syd_before_midnight.js
                        37 + tests/configs/modules/calendar/fail-basic-auth.js
                        7 - …/configs/modules/calendar/long-fullday-event.js
                        28 + tests/configs/modules/calendar/old-basic-auth.js
                        5 - tests/configs/modules/calendar/recurring.js
                        5 - tests/configs/modules/calendar/rrule_until.js
                        30 + …/calendar/show-duplicates-in-calendar.js
                        5 - …/modules/calendar/single-fullday-event.js
                        28 + tests/configs/modules/clock/clock_12hr.js
                        5 - tests/configs/modules/clock/clock_24hr.js
                        5 - tests/configs/modules/clock/clock_analog.js
                        4 - …/modules/clock/clock_displaySeconds_false.js
                        5 - …/configs/modules/clock/clock_showDateAnalog.js
                        5 - …/configs/modules/clock/clock_showPeriodUpper.js
                        5 - tests/configs/modules/clock/clock_showSunMoon.js
                        5 - tests/configs/modules/clock/clock_showTime.js
                        5 - tests/configs/modules/clock/clock_showWeek.js
                        5 - tests/configs/modules/clock/es/clock_12hr.js
                        5 - tests/configs/modules/clock/es/clock_24hr.js
                        5 - …/modules/clock/es/clock_showPeriodUpper.js
                        5 - tests/configs/modules/clock/es/clock_showWeek.js
                        6 - …/modules/compliments/compliments_animateCSS.js
                        6 - …/compliments_animateCSS_fallbackToDefault.js
                        7 - …compliments_animateCSS_invertedAnimationName.js
                        6 - …/modules/compliments/compliments_anytime.js
                        5 - …/modules/compliments/compliments_date.js
                        5 - …/compliments/compliments_only_anytime.js
                        5 - …/modules/compliments/compliments_parts_day.js
                        5 - …/modules/compliments/compliments_remote.js
                        5 - tests/configs/modules/display.js
                        5 - tests/configs/modules/helloworld/helloworld.js
                        5 - …/modules/helloworld/helloworld_default.js
                        5 - tests/configs/modules/newsfeed/default.js
                        5 - tests/configs/modules/newsfeed/ignore_items.js
                        4 - tests/configs/modules/newsfeed/incorrect_url.js
                        4 - tests/configs/modules/newsfeed/prohibited_words.js
                        4 - tests/configs/modules/positions.js
                        5 - …/modules/weather/currentweather_compliments.js
                        5 - …/modules/weather/currentweather_default.js
                        6 ± …/modules/weather/currentweather_options.js
                        7 ± …/modules/weather/currentweather_units.js
                        7 ± …/modules/weather/forecastweather_absolute.js
                        5 - …/modules/weather/forecastweather_default.js
                        5 - …/modules/weather/forecastweather_options.js
                        5 - …/modules/weather/forecastweather_units.js
                        5 - …/modules/weather/hourlyweather_default.js
                        5 - …/modules/weather/hourlyweather_options.js
                        5 - …/weather/hourlyweather_showPrecipitation.js
                        5 - tests/configs/noIpWhiteList.js
                        5 - tests/configs/port_8090.js
                        5 - tests/configs/port_variable.js.template
                        5 - tests/configs/without_modules.js
                        5 - tests/e2e/animateCSS_spec.js
                        7 - tests/e2e/fonts_spec.js
                        2 ± tests/e2e/helpers/basic-auth.js
                        2 ± tests/e2e/modules/calendar_spec.js
                        31 + tests/e2e/modules/weather_current_spec.js
                        16 ± tests/e2e/serveronly_spec.js
                        2 ± tests/e2e/template_spec.js
                        2 ± tests/e2e/translations_spec.js
                        4 ± tests/electron/env_spec.js
                        2 ± tests/electron/helpers/global-setup.js
                        6 ± tests/electron/modules/calendar_spec.js
                        105 ± tests/mocks/calendar_test_exdate.ics
                        34 - tests/mocks/calendar_test_full_day_events.ics
                        33 + …/calendar_test_multi_day_starting_today.ics
                        33 + tests/mocks/exdate_la_at_midnight_dst.ics
                        15 + tests/mocks/exdate_la_at_midnight_std.ics
                        15 + tests/mocks/exdate_la_before_midnight.ics
                        15 + tests/mocks/exdate_syd_at_midnight_dst.ics
                        15 + tests/mocks/exdate_syd_at_midnight_std.ics
                        15 + tests/mocks/exdate_syd_before_midnight.ics
                        15 + tests/mocks/rrule_until.ics
                        24 + tests/unit/classes/class_spec.js
                        2 ± tests/unit/classes/translator_spec.js
                        2 ± tests/unit/classes/utils_spec.js
                        35 ± tests/unit/functions/cmp_versions_spec.js
                        2 ± tests/unit/functions/updatenotification_spec.js
                        22 ± tests/unit/global_vars/defaults_modules_spec.js
                        4 ± tests/unit/global_vars/root_path_spec.js
                        4 ± tests/utils/weather_mocker.js
                        13 ± translations/et.json
                        31 ± translations/translations.js
                        7 - vendor/package-lock.json
                        10 ± vendor/package.json
                        9 ± vendor/vendor.js
                        6 - 173 files changed, 4108 insertions(+), 2557 deletions(-) delete mode 100644 .github/codecov.yaml
                        create mode 100644 .github/workflows/electronRebuild.yaml
                        create mode 100644 mm2.png rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
                        create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
                        create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
                        create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
                        create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
                        create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
                        create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
                        create mode 100644 tests/configs/modules/calendar/rrule_until.js
                        create mode 100644 tests/configs/modules/calendar/single-fullday-event.js delete mode 100644 tests/mocks/calendar_test_exdate.ics
                        create mode 100644 tests/mocks/calendar_test_full_day_events.ics
                        create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
                        create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
                        create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
                        create mode 100644 tests/mocks/exdate_la_before_midnight.ics
                        create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
                        create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
                        create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
                        create mode 100644 tests/mocks/rrule_until.ics
                        processor architecture is armv7l
                        magicmirror@2.27.0 postinstall
                        npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                        magicmirror@2.27.0 install-vendor
                        echo "Installing vendor files …
                        " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        changed 1 package in 3s
                        magicmirror@2.27.0 install-fonts
                        echo "Installing fonts …
                        " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        Installing fonts …
                        changed 2 packages in 6s
                        magicmirror@2.27.0 prepare
                        [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                        no husky installed.
                        added 483 packages in 2m
                        112 packages are looking for funding
                        run npm fund for details
                        npm install completed - mar. avril 2 10:39:31 CEST 2024 on base
                        fixing sandbox permissions
                        downloading dumpactivemodules script
                        updating dependencies for active modules with package.json files
                        processing for module MMM-OneCallWeather please wait
                        added 1 package, and audited 2 packages in 4s
                        found 0 vulnerabilities
                        processing complete for module MMM-OneCallWeather
                        processing for module MMM-ISS-Map please wait
                        added 1 package, and audited 2 packages in 7s
                        processing complete for module MMM-ISS-Map
                        processing for module MMM-ISS-Live please wait
                        up to date, audited 1 package in 2s
                        processing complete for module MMM-ISS-Live
                        removing git alias
                        Upgrade ended - mar. avril 2 10:39:54 CEST 2024
                          sdetweil @manu85340
                          @manu85340 ok, we need to back up to version 2.27 and node 18
                          so, first lets go back to node 18
                          sudo n 18
                          verify
                          node -v
                          should return something like this
                          ~/MagicMirror$ node -v
                          v18.20.3
                          if that is successful, then on to MagicMirror
                          git fetch --tags
                          git checkout -b temp v.2.27.0
                          rm package-lock.json
                          rm -rf node_modules
                          npm run install-mm
                          then MagicMirror should start and run
                          npm start
                          and not for startup
                          sudo reboot
                            manu85340 @sdetweil
                            @sdetweil Sam I have an error when I pass the line
                            v18.20.3
                            pi@MagicMirror:~ $ cd ~/MagicMirror
                            pi@MagicMirror:~/MagicMirror $ git fetch --tags
                            remote: Enumerating objects: 4, done.
                            remote: Counting objects: 100% (4/4), done.
                            remote: Compressing objects: 100% (4/4), done.
                            remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
                            D▒paquetage des objets: 100% (4/4), fait.
                            Depuis https://github.com/MagicMirrorOrg/MagicMirror
                            • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
                              ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
                              pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
                              fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
                            so I’m not going any further, I’m waiting for your instructions
                              sdetweil @manu85340
                              @manu85340 said in MM startup problem after update:
                              my fault (that little dot after the v!..) sorry
                              git checkout -b temp v2.27.0
                                manu85340 @sdetweil
                                @sdetweil I have an error see below, thanks Sam
                                pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
                                Basculement sur la nouvelle branche ‘temp’
                                pi@MagicMirror:~/MagicMirror $ rm package-lock.json
                                pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
                                pi@MagicMirror:~/MagicMirror $ npm run install-mm
                                magicmirror@2.27.0 install-mm
                                npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                <— Last few GCs —>
                                [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
                                [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
                                <— JS stacktrace —>
                                FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                Aborted
                                • BKeyportB
                                  BKeyport Module Developer @manu85340
                                  You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                                    manu85340 @BKeyport
                                    @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                                      sdetweil @manu85340
                                      @manu85340 see this post (and the one before it) in an issue w the same problem
                                      https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                                        manu85340 @sdetweil
                                        @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                                          sdetweil @manu85340
                                          @manu85340 I don’t understand.
                                          we have restored back to 2.27
                                          2.28 will not run on buster
                                          you need the next at least bullseye
                                          bur if you are upgrading, go to current, bookworm
                                            manu85340 @sdetweil
                                            @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                                            so I didn't pass the other command lines
                                            rm -rf node_modules
                                            npm run install-mm
                                            • 2 / 3
