    MM startup problem after update
    42 Posts 3 Posters 11.4k Views 4 Watching
      manu85340 @sdetweil
      @sdetweil ok sorry for the screenshots
      pi@MagicMirror:~ $ pm2 stop all
      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
      [PM2] [mm](0) ✓
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ mm                 │ fork     │ 685  │ stopped   │ 0%       │ 0b       │
      pi@MagicMirror:~ $ cd ~/MagicMirror
      pi@MagicMirror:~/MagicMirror $ npm install electron@31.1.0
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.28.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.28.0
      npm ERR! notsup Required: {"node":">=20"}
      npm ERR! notsup Actual:   {"npm":"9.8.1","node":"v18.18.0"}
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-07        -01T13_05_28_653Z-debug-0.log
        sdetweil @manu85340
        @manu85340 ok, upgrade didn’t upgrade nodejs…
          @manu85340 also show output of
          lsb_release -a
          bet it shows buster
            manu85340 @sdetweil
            pi@MagicMirror:~ $ lsb_release -a
            No LSB modules are available.
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            pi@MagicMirror:~ $
              manu85340 @sdetweil
              @sdetweil do you need installers/update.log by email?
                sdetweil @manu85340
                @manu85340 ok. script forces node 18 on buster. hang on. I’ll debug
                could u give me output of command n
                it might say unknown
                or give a list
                  manu85340 @sdetweil
                  @sdetweil I typed “n” and there is nothing
                    sdetweil @manu85340
                    @manu85340 ok,
                    do
                    sudo npm I-g n
                    sudo n 20
                    then node -v
                      manu85340 @sdetweil
                      pi@MagicMirror:~ $ sudo npm I-g n
                      Unknown command: "I-g"
                      To see a list of supported npm commands, run:
                        npm help
                      pi@MagicMirror:~ $ sudo n 20
                        installing : node-v20.15.0
                             mkdir : /usr/local/n/versions/node/20.15.0
                             fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
                           copying : node/20.15.0
                      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
                      /usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
                         installed :  (with npm )
                      pi@MagicMirror:~ $ node -v
                      pi@MagicMirror:~ $ node-v
                      -bash: node-v : commande introuvable
                      pi@MagicMirror:~ $
                        sdetweil @manu85340
                        @manu85340 grr… that was the problem finding the c++ lib for buster.
                        let me research, be a couple hours
                          manu85340 @sdetweil
                          @sdetweil OK thanks to you
                            sdetweil @manu85340
                            @manu85340 so, after research. there is no way to get to the latest MagicMirror release on buster.
                            unless there is some fix you NEED , I recommend staying where you were til you can plan to upgrade the os.
                            now we’ve already tried going forward, so need to jump back.
                            can you look in the upgrade log ~/MagicMirror/installers/upgrade.log
                            for the string
                            upgrading from version
                            so we can get you back to that earlier release
                            in prep for os migration, and general health backup your MagicMirror system
                            see my backup restore
                            https://github.com/sdetweil/MagicMirror-backup-restore
                              manu85340 @sdetweil
                              @sdetweil I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do
                              restoring custom.css
                              removing git alias
                              Upgrade ended - mar. avril 2 10:35:49 CEST 2024
                              Upgrade started - mar. avril 2 10:37:27 CEST 2024
                              system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                              user requested to apply changes
                              doing test run = false
                              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                              Minimum Node version: v18.18.0
                              Installed Node version: v18.18.0
                              Check current Node installation …
                              No Node.js upgrade necessary.
                              Check current NPM installation …
                              Minimum npm version: V9.8.1
                              Installed npm version: V9.8.1
                              No npm upgrade necessary.
                              saving custom.css
                              remote name = origin
                              upgrading from version 2.26.0 to 2.27.0
                              fetching latest revisions
                              git fetch rc=0
                              current branch = master
                              On branch master
                              Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.
                              (use “git pull” to update your local branch)
                              Untracked files:
                              (use “git add …” to include in what will be committed)
                              core
                              css/icons/
                              css/save_custom.css
                              modules/default/currentweather/
                              nohup.out
                              nothing added to commit but untracked files present (use “git add” to track)
                              no files different from github version
                              test merge result rc=‘’ , if empty, no conflicts
                              executing merge, apply specified
                              merge result rc= 0
                              Updating 118e2123…5ea8a346 Fast-forward .eslintignore
                              3 ± .eslintrc.json
                              18 ± .github/codecov.yaml
                              10 - .github/dependabot.yaml
                              15 + .github/workflows/depsreview.yaml
                              2 ± .github/workflows/electronRebuild.yaml
                              20 + .github/workflows/enforce-pullrequest-rules.yaml
                              2 ± .gitignore
                              6 ± .husky/pre-commit
                              2 - .npmrc
                              1 + .prettierignore
                              2 + CHANGELOG.md
                              199 ± Collaboration.md
                              24 ± LICENSE.md
                              2 ± README.md
                              10 ± clientonly/index.js
                              4 ± config/config.js.sample
                              5 ± css/custom.css.sample
                              8 ± fonts/package-lock.json
                              18 ± fonts/package.json
                              11 ± js/animateCSS.js
                              7 - js/app.js
                              42 ± js/check_config.js
                              23 ± js/defaults.js
                              8 ± js/deprecated.js
                              8 - js/electron.js
                              1 + js/loader.js
                              6 - js/logger.js
                              43 ± js/main.js
                              6 - js/module.js
                              6 ± js/node_helper.js
                              6 - js/server.js
                              16 ± js/server_functions.js
                              4 ± js/socketclient.js
                              6 - js/translator.js
                              6 - js/utils.js
                              Bin 0 -> 6947 bytes modules/default/alert/alert.js
                              6 - modules/default/calendar/calendar.js
                              33 ± modules/default/calendar/calendarfetcher.js
                              9 ± modules/default/calendar/calendarfetcherutils.js
                              268 ± modules/default/calendar/calendarutils.js
                              6 - modules/default/calendar/debug.js
                              3 - modules/default/calendar/node_helper.js
                              15 ± modules/default/clock/clock.js
                              11 ± modules/default/compliments/compliments.js
                              8 ± modules/default/defaultmodules.js
                              5 ± modules/default/helloworld/helloworld.js
                              6 - modules/default/newsfeed/newsfeed.js
                              43 ± modules/default/newsfeed/newsfeedfetcher.js
                              13 ± modules/default/newsfeed/node_helper.js
                              7 - modules/default/updatenotification/git_helper.js
                              10 ± …/default/updatenotification/update_helper.js
                              57 ± …/updatenotification/updatenotification.js
                              10 ± modules/default/weather/current.njk
                              56 ± modules/default/weather/providers/envcanada.js
                              8 ± modules/default/weather/providers/openmeteo.js
                              12 ± …/default/weather/providers/openweathermap.js
                              9 ± modules/default/weather/providers/pirateweather.js
                              11 ± modules/default/weather/providers/smhi.js
                              12 ± modules/default/weather/providers/ukmetoffice.js
                              9 ± …/weather/providers/ukmetofficedatahub.js
                              9 ± modules/default/weather/providers/weatherbit.js
                              11 ± modules/default/weather/providers/weatherflow.js
                              10 ± modules/default/weather/providers/weathergov.js
                              10 ± modules/default/weather/providers/yr.js
                              10 ± modules/default/weather/weather.js
                              14 ± modules/default/weather/weatherobject.js
                              12 - modules/default/weather/weatherprovider.js
                              9 ± modules/default/weather/weatherutils.js
                              6 - package-lock.json
                              4180 ++++++++++++±------ package.json
                              60 ± serveronly/index.js
                              2 ± tests/configs/default.js
                              5 - tests/configs/empty_ipWhiteList.js
                              5 - tests/configs/modules/alert/default.js
                              5 - tests/configs/modules/calendar/auth-default.js
                              5 - tests/configs/modules/calendar/bad_rrule.js
                              5 - tests/configs/modules/calendar/basic-auth.js
                              5 - tests/configs/modules/calendar/changed-port.js
                              5 - tests/configs/modules/calendar/custom.js
                              6 ± tests/configs/modules/calendar/default.js
                              5 - …/{exdate.js => exdate_la_at_midnight_dst.js}
                              13 ± …/modules/calendar/exdate_la_at_midnight_std.js
                              37 + …/modules/calendar/exdate_la_before_midnight.js
                              37 + …/modules/calendar/exdate_syd_at_midnight_dst.js
                              37 + …/modules/calendar/exdate_syd_at_midnight_std.js
                              37 + …/modules/calendar/exdate_syd_before_midnight.js
                              37 + tests/configs/modules/calendar/fail-basic-auth.js
                              7 - …/configs/modules/calendar/long-fullday-event.js
                              28 + tests/configs/modules/calendar/old-basic-auth.js
                              5 - tests/configs/modules/calendar/recurring.js
                              5 - tests/configs/modules/calendar/rrule_until.js
                              30 + …/calendar/show-duplicates-in-calendar.js
                              5 - …/modules/calendar/single-fullday-event.js
                              28 + tests/configs/modules/clock/clock_12hr.js
                              5 - tests/configs/modules/clock/clock_24hr.js
                              5 - tests/configs/modules/clock/clock_analog.js
                              4 - …/modules/clock/clock_displaySeconds_false.js
                              5 - …/configs/modules/clock/clock_showDateAnalog.js
                              5 - …/configs/modules/clock/clock_showPeriodUpper.js
                              5 - tests/configs/modules/clock/clock_showSunMoon.js
                              5 - tests/configs/modules/clock/clock_showTime.js
                              5 - tests/configs/modules/clock/clock_showWeek.js
                              5 - tests/configs/modules/clock/es/clock_12hr.js
                              5 - tests/configs/modules/clock/es/clock_24hr.js
                              5 - …/modules/clock/es/clock_showPeriodUpper.js
                              5 - tests/configs/modules/clock/es/clock_showWeek.js
                              6 - …/modules/compliments/compliments_animateCSS.js
                              6 - …/compliments_animateCSS_fallbackToDefault.js
                              7 - …compliments_animateCSS_invertedAnimationName.js
                              6 - …/modules/compliments/compliments_anytime.js
                              5 - …/modules/compliments/compliments_date.js
                              5 - …/compliments/compliments_only_anytime.js
                              5 - …/modules/compliments/compliments_parts_day.js
                              5 - …/modules/compliments/compliments_remote.js
                              5 - tests/configs/modules/display.js
                              5 - tests/configs/modules/helloworld/helloworld.js
                              5 - …/modules/helloworld/helloworld_default.js
                              5 - tests/configs/modules/newsfeed/default.js
                              5 - tests/configs/modules/newsfeed/ignore_items.js
                              4 - tests/configs/modules/newsfeed/incorrect_url.js
                              4 - tests/configs/modules/newsfeed/prohibited_words.js
                              4 - tests/configs/modules/positions.js
                              5 - …/modules/weather/currentweather_compliments.js
                              5 - …/modules/weather/currentweather_default.js
                              6 ± …/modules/weather/currentweather_options.js
                              7 ± …/modules/weather/currentweather_units.js
                              7 ± …/modules/weather/forecastweather_absolute.js
                              5 - …/modules/weather/forecastweather_default.js
                              5 - …/modules/weather/forecastweather_options.js
                              5 - …/modules/weather/forecastweather_units.js
                              5 - …/modules/weather/hourlyweather_default.js
                              5 - …/modules/weather/hourlyweather_options.js
                              5 - …/weather/hourlyweather_showPrecipitation.js
                              5 - tests/configs/noIpWhiteList.js
                              5 - tests/configs/port_8090.js
                              5 - tests/configs/port_variable.js.template
                              5 - tests/configs/without_modules.js
                              5 - tests/e2e/animateCSS_spec.js
                              7 - tests/e2e/fonts_spec.js
                              2 ± tests/e2e/helpers/basic-auth.js
                              2 ± tests/e2e/modules/calendar_spec.js
                              31 + tests/e2e/modules/weather_current_spec.js
                              16 ± tests/e2e/serveronly_spec.js
                              2 ± tests/e2e/template_spec.js
                              2 ± tests/e2e/translations_spec.js
                              4 ± tests/electron/env_spec.js
                              2 ± tests/electron/helpers/global-setup.js
                              6 ± tests/electron/modules/calendar_spec.js
                              105 ± tests/mocks/calendar_test_exdate.ics
                              34 - tests/mocks/calendar_test_full_day_events.ics
                              33 + …/calendar_test_multi_day_starting_today.ics
                              33 + tests/mocks/exdate_la_at_midnight_dst.ics
                              15 + tests/mocks/exdate_la_at_midnight_std.ics
                              15 + tests/mocks/exdate_la_before_midnight.ics
                              15 + tests/mocks/exdate_syd_at_midnight_dst.ics
                              15 + tests/mocks/exdate_syd_at_midnight_std.ics
                              15 + tests/mocks/exdate_syd_before_midnight.ics
                              15 + tests/mocks/rrule_until.ics
                              24 + tests/unit/classes/class_spec.js
                              2 ± tests/unit/classes/translator_spec.js
                              2 ± tests/unit/classes/utils_spec.js
                              35 ± tests/unit/functions/cmp_versions_spec.js
                              2 ± tests/unit/functions/updatenotification_spec.js
                              22 ± tests/unit/global_vars/defaults_modules_spec.js
                              4 ± tests/unit/global_vars/root_path_spec.js
                              4 ± tests/utils/weather_mocker.js
                              13 ± translations/et.json
                              31 ± translations/translations.js
                              7 - vendor/package-lock.json
                              10 ± vendor/package.json
                              9 ± vendor/vendor.js
                              6 - 173 files changed, 4108 insertions(+), 2557 deletions(-) delete mode 100644 .github/codecov.yaml
                              create mode 100644 .github/workflows/electronRebuild.yaml
                              create mode 100644 mm2.png rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
                              create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
                              create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
                              create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
                              create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
                              create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
                              create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
                              create mode 100644 tests/configs/modules/calendar/rrule_until.js
                              create mode 100644 tests/configs/modules/calendar/single-fullday-event.js delete mode 100644 tests/mocks/calendar_test_exdate.ics
                              create mode 100644 tests/mocks/calendar_test_full_day_events.ics
                              create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
                              create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
                              create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
                              create mode 100644 tests/mocks/exdate_la_before_midnight.ics
                              create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
                              create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
                              create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
                              create mode 100644 tests/mocks/rrule_until.ics
                              processor architecture is armv7l
                              magicmirror@2.27.0 postinstall
                              npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                              magicmirror@2.27.0 install-vendor
                              echo "Installing vendor files …
                              " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              changed 1 package in 3s
                              magicmirror@2.27.0 install-fonts
                              echo "Installing fonts …
                              " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              Installing fonts …
                              changed 2 packages in 6s
                              magicmirror@2.27.0 prepare
                              [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                              no husky installed.
                              added 483 packages in 2m
                              112 packages are looking for funding
                              run npm fund for details
                              npm install completed - mar. avril 2 10:39:31 CEST 2024 on base
                              fixing sandbox permissions
                              downloading dumpactivemodules script
                              updating dependencies for active modules with package.json files
                              processing for module MMM-OneCallWeather please wait
                              added 1 package, and audited 2 packages in 4s
                              found 0 vulnerabilities
                              processing complete for module MMM-OneCallWeather
                              processing for module MMM-ISS-Map please wait
                              added 1 package, and audited 2 packages in 7s
                              processing complete for module MMM-ISS-Map
                              processing for module MMM-ISS-Live please wait
                              up to date, audited 1 package in 2s
                              processing complete for module MMM-ISS-Live
                              removing git alias
                              Upgrade ended - mar. avril 2 10:39:54 CEST 2024
                                sdetweil @manu85340
                                @manu85340 ok, we need to back up to version 2.27 and node 18
                                so, first lets go back to node 18
                                sudo n 18
                                verify
                                node -v
                                should return something like this
                                ~/MagicMirror$ node -v
                                v18.20.3
                                if that is successful, then on to MagicMirror
                                git fetch --tags
                                git checkout -b temp v.2.27.0
                                rm package-lock.json
                                rm -rf node_modules
                                npm run install-mm
                                then MagicMirror should start and run
                                npm start
                                and not for startup
                                sudo reboot
                                  manu85340 @sdetweil
                                  @sdetweil Sam I have an error when I pass the line
                                  v18.20.3
                                  pi@MagicMirror:~/MagicMirror $ git fetch --tags
                                  remote: Enumerating objects: 4, done.
                                  remote: Counting objects: 100% (4/4), done.
                                  remote: Compressing objects: 100% (4/4), done.
                                  remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
                                  D▒paquetage des objets: 100% (4/4), fait.
                                  Depuis https://github.com/MagicMirrorOrg/MagicMirror
                                  • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
                                    ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
                                    pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
                                    fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
                                  so I’m not going any further, I’m waiting for your instructions
                                    sdetweil @manu85340
                                    @manu85340 said in MM startup problem after update:
                                    my fault (that little dot after the v!..) sorry
                                    git checkout -b temp v2.27.0
                                      manu85340 @sdetweil
                                      @sdetweil I have an error see below, thanks Sam
                                      pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
                                      Basculement sur la nouvelle branche ‘temp’
                                      pi@MagicMirror:~/MagicMirror $ rm package-lock.json
                                      pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
                                      pi@MagicMirror:~/MagicMirror $ npm run install-mm
                                      magicmirror@2.27.0 install-mm
                                      npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                      <— Last few GCs —>
                                      [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
                                      [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
                                      <— JS stacktrace —>
                                      FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                      Aborted
                                      • BKeyportB
                                        BKeyport Module Developer @manu85340
                                        You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                                          manu85340 @BKeyport
                                          @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                                            sdetweil @manu85340
                                            @manu85340 see this post (and the one before it) in an issue w the same problem
                                            https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                                            • 2 / 3
