    MM startup problem after update
    42 Posts 3 Posters 11.1k Views 4 Watching
      manu85340 @sdetweil
      @sdetweil OK thanks to you
        sdetweil @manu85340
        @manu85340 so, after research. there is no way to get to the latest MagicMirror release on buster.
        unless there is some fix you NEED , I recommend staying where you were til you can plan to upgrade the os.
        now we’ve already tried going forward, so need to jump back.
        can you look in the upgrade log ~/MagicMirror/installers/upgrade.log
        for the string
        upgrading from version
        so we can get you back to that earlier release
        in prep for os migration, and general health backup your MagicMirror system
        see my backup restore
        https://github.com/sdetweil/MagicMirror-backup-restore
          manu85340 @sdetweil
          @sdetweil I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do
          restoring custom.css
          removing git alias
          Upgrade ended - mar. avril 2 10:35:49 CEST 2024
          Upgrade started - mar. avril 2 10:37:27 CEST 2024
          system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
          user requested to apply changes
          doing test run = false
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
          Minimum Node version: v18.18.0
          Installed Node version: v18.18.0
          Check current Node installation …
          No Node.js upgrade necessary.
          Check current NPM installation …
          Minimum npm version: V9.8.1
          Installed npm version: V9.8.1
          No npm upgrade necessary.
          saving custom.css
          remote name = origin
          upgrading from version 2.26.0 to 2.27.0
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.
          (use “git pull” to update your local branch)
          Untracked files:
          (use “git add …” to include in what will be committed)
          core
          css/icons/
          css/save_custom.css
          modules/default/currentweather/
          nohup.out
          nothing added to commit but untracked files present (use “git add” to track)
          no files different from github version
          test merge result rc=‘’ , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
          Updating 118e2123…5ea8a346 Fast-forward .eslintignore
          3 ± .eslintrc.json
          18 ± .github/codecov.yaml
          10 - .github/dependabot.yaml
          15 + .github/workflows/depsreview.yaml
          2 ± .github/workflows/electronRebuild.yaml
          20 + .github/workflows/enforce-pullrequest-rules.yaml
          2 ± .gitignore
          6 ± .husky/pre-commit
          2 - .npmrc
          1 + .prettierignore
          2 + CHANGELOG.md
          199 ± Collaboration.md
          24 ± LICENSE.md
          2 ± README.md
          10 ± clientonly/index.js
          4 ± config/config.js.sample
          5 ± css/custom.css.sample
          8 ± fonts/package-lock.json
          18 ± fonts/package.json
          11 ± js/animateCSS.js
          7 - js/app.js
          42 ± js/check_config.js
          23 ± js/defaults.js
          8 ± js/deprecated.js
          8 - js/electron.js
          1 + js/loader.js
          6 - js/logger.js
          43 ± js/main.js
          6 - js/module.js
          6 ± js/node_helper.js
          6 - js/server.js
          16 ± js/server_functions.js
          4 ± js/socketclient.js
          6 - js/translator.js
          6 - js/utils.js
          Bin 0 -> 6947 bytes modules/default/alert/alert.js
          6 - modules/default/calendar/calendar.js
          33 ± modules/default/calendar/calendarfetcher.js
          9 ± modules/default/calendar/calendarfetcherutils.js
          268 ± modules/default/calendar/calendarutils.js
          6 - modules/default/calendar/debug.js
          3 - modules/default/calendar/node_helper.js
          15 ± modules/default/clock/clock.js
          11 ± modules/default/compliments/compliments.js
          8 ± modules/default/defaultmodules.js
          5 ± modules/default/helloworld/helloworld.js
          6 - modules/default/newsfeed/newsfeed.js
          43 ± modules/default/newsfeed/newsfeedfetcher.js
          13 ± modules/default/newsfeed/node_helper.js
          7 - modules/default/updatenotification/git_helper.js
          10 ± …/default/updatenotification/update_helper.js
          57 ± …/updatenotification/updatenotification.js
          10 ± modules/default/weather/current.njk
          56 ± modules/default/weather/providers/envcanada.js
          8 ± modules/default/weather/providers/openmeteo.js
          12 ± …/default/weather/providers/openweathermap.js
          9 ± modules/default/weather/providers/pirateweather.js
          11 ± modules/default/weather/providers/smhi.js
          12 ± modules/default/weather/providers/ukmetoffice.js
          9 ± …/weather/providers/ukmetofficedatahub.js
          9 ± modules/default/weather/providers/weatherbit.js
          11 ± modules/default/weather/providers/weatherflow.js
          10 ± modules/default/weather/providers/weathergov.js
          10 ± modules/default/weather/providers/yr.js
          10 ± modules/default/weather/weather.js
          14 ± modules/default/weather/weatherobject.js
          12 - modules/default/weather/weatherprovider.js
          9 ± modules/default/weather/weatherutils.js
          6 - package-lock.json
          4180 ++++++++++++±------ package.json
          60 ± serveronly/index.js
          2 ± tests/configs/default.js
          5 - tests/configs/empty_ipWhiteList.js
          5 - tests/configs/modules/alert/default.js
          5 - tests/configs/modules/calendar/auth-default.js
          5 - tests/configs/modules/calendar/bad_rrule.js
          5 - tests/configs/modules/calendar/basic-auth.js
          5 - tests/configs/modules/calendar/changed-port.js
          5 - tests/configs/modules/calendar/custom.js
          6 ± tests/configs/modules/calendar/default.js
          5 - …/{exdate.js => exdate_la_at_midnight_dst.js}
          13 ± …/modules/calendar/exdate_la_at_midnight_std.js
          37 + …/modules/calendar/exdate_la_before_midnight.js
          37 + …/modules/calendar/exdate_syd_at_midnight_dst.js
          37 + …/modules/calendar/exdate_syd_at_midnight_std.js
          37 + …/modules/calendar/exdate_syd_before_midnight.js
          37 + tests/configs/modules/calendar/fail-basic-auth.js
          7 - …/configs/modules/calendar/long-fullday-event.js
          28 + tests/configs/modules/calendar/old-basic-auth.js
          5 - tests/configs/modules/calendar/recurring.js
          5 - tests/configs/modules/calendar/rrule_until.js
          30 + …/calendar/show-duplicates-in-calendar.js
          5 - …/modules/calendar/single-fullday-event.js
          28 + tests/configs/modules/clock/clock_12hr.js
          5 - tests/configs/modules/clock/clock_24hr.js
          5 - tests/configs/modules/clock/clock_analog.js
          4 - …/modules/clock/clock_displaySeconds_false.js
          5 - …/configs/modules/clock/clock_showDateAnalog.js
          5 - …/configs/modules/clock/clock_showPeriodUpper.js
          5 - tests/configs/modules/clock/clock_showSunMoon.js
          5 - tests/configs/modules/clock/clock_showTime.js
          5 - tests/configs/modules/clock/clock_showWeek.js
          5 - tests/configs/modules/clock/es/clock_12hr.js
          5 - tests/configs/modules/clock/es/clock_24hr.js
          5 - …/modules/clock/es/clock_showPeriodUpper.js
          5 - tests/configs/modules/clock/es/clock_showWeek.js
          6 - …/modules/compliments/compliments_animateCSS.js
          6 - …/compliments_animateCSS_fallbackToDefault.js
          7 - …compliments_animateCSS_invertedAnimationName.js
          6 - …/modules/compliments/compliments_anytime.js
          5 - …/modules/compliments/compliments_date.js
          5 - …/compliments/compliments_only_anytime.js
          5 - …/modules/compliments/compliments_parts_day.js
          5 - …/modules/compliments/compliments_remote.js
          5 - tests/configs/modules/display.js
          5 - tests/configs/modules/helloworld/helloworld.js
          5 - …/modules/helloworld/helloworld_default.js
          5 - tests/configs/modules/newsfeed/default.js
          5 - tests/configs/modules/newsfeed/ignore_items.js
          4 - tests/configs/modules/newsfeed/incorrect_url.js
          4 - tests/configs/modules/newsfeed/prohibited_words.js
          4 - tests/configs/modules/positions.js
          5 - …/modules/weather/currentweather_compliments.js
          5 - …/modules/weather/currentweather_default.js
          6 ± …/modules/weather/currentweather_options.js
          7 ± …/modules/weather/currentweather_units.js
          7 ± …/modules/weather/forecastweather_absolute.js
          5 - …/modules/weather/forecastweather_default.js
          5 - …/modules/weather/forecastweather_options.js
          5 - …/modules/weather/forecastweather_units.js
          5 - …/modules/weather/hourlyweather_default.js
          5 - …/modules/weather/hourlyweather_options.js
          5 - …/weather/hourlyweather_showPrecipitation.js
          5 - tests/configs/noIpWhiteList.js
          5 - tests/configs/port_8090.js
          5 - tests/configs/port_variable.js.template
          5 - tests/configs/without_modules.js
          5 - tests/e2e/animateCSS_spec.js
          7 - tests/e2e/fonts_spec.js
          2 ± tests/e2e/helpers/basic-auth.js
          2 ± tests/e2e/modules/calendar_spec.js
          31 + tests/e2e/modules/weather_current_spec.js
          16 ± tests/e2e/serveronly_spec.js
          2 ± tests/e2e/template_spec.js
          2 ± tests/e2e/translations_spec.js
          4 ± tests/electron/env_spec.js
          2 ± tests/electron/helpers/global-setup.js
          6 ± tests/electron/modules/calendar_spec.js
          105 ± tests/mocks/calendar_test_exdate.ics
          34 - tests/mocks/calendar_test_full_day_events.ics
          33 + …/calendar_test_multi_day_starting_today.ics
          33 + tests/mocks/exdate_la_at_midnight_dst.ics
          15 + tests/mocks/exdate_la_at_midnight_std.ics
          15 + tests/mocks/exdate_la_before_midnight.ics
          15 + tests/mocks/exdate_syd_at_midnight_dst.ics
          15 + tests/mocks/exdate_syd_at_midnight_std.ics
          15 + tests/mocks/exdate_syd_before_midnight.ics
          15 + tests/mocks/rrule_until.ics
          24 + tests/unit/classes/class_spec.js
          2 ± tests/unit/classes/translator_spec.js
          2 ± tests/unit/classes/utils_spec.js
          35 ± tests/unit/functions/cmp_versions_spec.js
          2 ± tests/unit/functions/updatenotification_spec.js
          22 ± tests/unit/global_vars/defaults_modules_spec.js
          4 ± tests/unit/global_vars/root_path_spec.js
          4 ± tests/utils/weather_mocker.js
          13 ± translations/et.json
          31 ± translations/translations.js
          7 - vendor/package-lock.json
          10 ± vendor/package.json
          9 ± vendor/vendor.js
          6 - 173 files changed, 4108 insertions(+), 2557 deletions(-) delete mode 100644 .github/codecov.yaml
          create mode 100644 .github/workflows/electronRebuild.yaml
          create mode 100644 mm2.png rename tests/configs/modules/calendar/{exdate.js => exdate_la_at_midnight_dst.js} (50%)
          create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js
          create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js
          create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js
          create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js
          create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js
          create mode 100644 tests/configs/modules/calendar/long-fullday-event.js
          create mode 100644 tests/configs/modules/calendar/rrule_until.js
          create mode 100644 tests/configs/modules/calendar/single-fullday-event.js delete mode 100644 tests/mocks/calendar_test_exdate.ics
          create mode 100644 tests/mocks/calendar_test_full_day_events.ics
          create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics
          create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics
          create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics
          create mode 100644 tests/mocks/exdate_la_before_midnight.ics
          create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics
          create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics
          create mode 100644 tests/mocks/exdate_syd_before_midnight.ics
          create mode 100644 tests/mocks/rrule_until.ics
          processor architecture is armv7l
          magicmirror@2.27.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.27.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          changed 1 package in 3s
          magicmirror@2.27.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          changed 2 packages in 6s
          magicmirror@2.27.0 prepare
          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          added 483 packages in 2m
          112 packages are looking for funding
          run npm fund for details
          npm install completed - mar. avril 2 10:39:31 CEST 2024 on base
          fixing sandbox permissions
          downloading dumpactivemodules script
          updating dependencies for active modules with package.json files
          processing for module MMM-OneCallWeather please wait
          added 1 package, and audited 2 packages in 4s
          found 0 vulnerabilities
          processing complete for module MMM-OneCallWeather
          processing for module MMM-ISS-Map please wait
          added 1 package, and audited 2 packages in 7s
          processing complete for module MMM-ISS-Map
          processing for module MMM-ISS-Live please wait
          up to date, audited 1 package in 2s
          processing complete for module MMM-ISS-Live
          removing git alias
          Upgrade ended - mar. avril 2 10:39:54 CEST 2024
            sdetweil @manu85340
            @manu85340 ok, we need to back up to version 2.27 and node 18
            so, first lets go back to node 18
            sudo n 18
            verify
            node -v
            should return something like this
            ~/MagicMirror$ node -v
            v18.20.3
            if that is successful, then on to MagicMirror
            git fetch --tags
            git checkout -b temp v.2.27.0
            rm package-lock.json
            rm -rf node_modules
            npm run install-mm
            then MagicMirror should start and run
            npm start
            and not for startup
            sudo reboot
              manu85340 @sdetweil
              @sdetweil Sam I have an error when I pass the line
              pi@MagicMirror:~ $ node -v
              v18.20.3
              pi@MagicMirror:~ $ cd ~/MagicMirror
              pi@MagicMirror:~/MagicMirror $ git fetch --tags
              remote: Enumerating objects: 4, done.
              remote: Counting objects: 100% (4/4), done.
              remote: Compressing objects: 100% (4/4), done.
              remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0
              D▒paquetage des objets: 100% (4/4), fait.
              Depuis https://github.com/MagicMirrorOrg/MagicMirror
              • [nouvelle branche] dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -> origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0
                ! [rejet▒] v2.17.0 -> v2.17.0 (▒craserait l’▒tiquette existante)
                pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0
                fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis
              so I’m not going any further, I’m waiting for your instructions
                sdetweil @manu85340
                @manu85340 said in MM startup problem after update:
                my fault (that little dot after the v!..) sorry
                git checkout -b temp v2.27.0
                  manu85340 @sdetweil
                  @sdetweil I have an error see below, thanks Sam
                  pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
                  Basculement sur la nouvelle branche ‘temp’
                  pi@MagicMirror:~/MagicMirror $ rm package-lock.json
                  pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
                  pi@MagicMirror:~/MagicMirror $ npm run install-mm
                  magicmirror@2.27.0 install-mm
                  npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                  <— Last few GCs —>
                  [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
                  [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
                  <— JS stacktrace —>
                  FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  Aborted
                  • BKeyportB Offline
                    BKeyport Module Developer @manu85340
                    You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
                      manu85340 @BKeyport
                      @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
                        sdetweil @manu85340
                        @manu85340 see this post (and the one before it) in an issue w the same problem
                        https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                          manu85340 @sdetweil
                          @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                            sdetweil @manu85340
                            @manu85340 I don’t understand.
                            we have restored back to 2.27
                            2.28 will not run on buster
                            you need the next at least bullseye
                            bur if you are upgrading, go to current, bookworm
                              manu85340 @sdetweil
                              @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                              so I didn't pass the other command lines
                              rm -rf node_modules
                              npm run install-mm
                                sdetweil @manu85340
                                @manu85340 yes and I replied with the corrected command
                                https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042
                                  manu85340 @sdetweil
                                  @sdetweil Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```
                                  npm run install-mm
                                  <— Last few GCs —>
                                  [12543:0x5273870] 17046 ms: Mark-sweep (reduce) 226.7 (234.0) -> 226.5 (234.0 ) MB, 147.4 / 0.0 ms (+ 65.0 ms in 7 steps since start of marking, biggest step 17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m u = 0.346) allo[12543:0x5273870] 17258 ms: Mark-sweep (reduce) 226.9 (234.0) -> 226.9 (234.5) MB, 207.1 / 0.0 ms (average mu = 0.705, current mu = 0.026) al location failure; scavenge might not succeed
                                  <— JS stacktrace —>
                                  FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor y
                                  Aborted
                                    sdetweil @manu85340
                                    @manu85340 and then i posted another link with instructions for that problem
                                      manu85340 @sdetweil
                                      @sdetweil Sam thanks for your help, but I think I’m going to give up… nothing works, I have another MM I’m going to copy the sd card and copy it to that of my MM and not do an update, if I understood correctly that it is the operating system that does not support updating? if this is it on which system should I install MM please?
                                        sdetweil @manu85340
                                        @manu85340 the latest raspi OS is bookworm…
                                        if this is a pi3 Id do the 32 bit version to save memory space.
                                        I have updated the installer and upgrader to fail if trying to install or upgrade now on buster
                                        • 2 / 3
