    MM startup problem after update
    42 Posts 3 Posters 11.7k Views 4 Watching
      sdetweil @manu85340
      @manu85340 said in MM startup problem after update:
      git checkout -b temp v.2.27.0
      my fault (that little dot after the v!..) sorry
      git checkout -b temp v2.27.0
      M 1 Reply Last reply
        manu85340 @sdetweil
        @sdetweil I have an error see below, thanks Sam
        pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0
        Basculement sur la nouvelle branche ‘temp’
        pi@MagicMirror:~/MagicMirror $ rm package-lock.json
        pi@MagicMirror:~/MagicMirror $ rm -rf node_modules
        pi@MagicMirror:~/MagicMirror $ npm run install-mm
        magicmirror@2.27.0 install-mm
        npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
        <— Last few GCs —>
        [25028:0x4545870] 27358 ms: Mark-sweep (reduce) 226.0 (233.8) -> 225.8 (233.8) MB, 271.2 / 0.0 ms (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed
        [25028:0x4545870] 27592 ms: Mark-sweep (reduce) 226.3 (233.8) -> 226.2 (234.3) MB, 230.3 / 0.0 ms (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed
        <— JS stacktrace —>
        FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
        Aborted
        BKeyportB 1 Reply Last reply
        • BKeyportB
          BKeyport Module Developer @manu85340
          You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…
            manu85340 @BKeyport
            @BKeyport ok thank you for your answer I’m waiting to see if @sdetweil sdetweil finds a solution
              sdetweil @manu85340
              @manu85340 see this post (and the one before it) in an issue w the same problem
              https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685
                manu85340 @sdetweil
                @sdetweil hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,
                  sdetweil @manu85340
                  @manu85340 I don’t understand.
                  we have restored back to 2.27
                  2.28 will not run on buster
                  you need the next at least bullseye
                  bur if you are upgrading, go to current, bookworm
                    manu85340 @sdetweil
                    @sdetweil Sam a few posts above I told you that I had a problem passing this line:
                    so I didn't pass the other command lines
                    rm -rf node_modules
                    npm run install-mm
                      sdetweil @manu85340
                      @manu85340 yes and I replied with the corrected command
                      https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042
                        manu85340 @sdetweil
                        @sdetweil Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```
                        npm run install-mm
                        <— Last few GCs —>
                        [12543:0x5273870] 17046 ms: Mark-sweep (reduce) 226.7 (234.0) -> 226.5 (234.0 ) MB, 147.4 / 0.0 ms (+ 65.0 ms in 7 steps since start of marking, biggest step 17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m u = 0.346) allo[12543:0x5273870] 17258 ms: Mark-sweep (reduce) 226.9 (234.0) -> 226.9 (234.5) MB, 207.1 / 0.0 ms (average mu = 0.705, current mu = 0.026) al location failure; scavenge might not succeed
                        <— JS stacktrace —>
                        FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor y
                        Aborted
                          sdetweil @manu85340
                          @manu85340 and then i posted another link with instructions for that problem
                            manu85340 @sdetweil
                            @sdetweil Sam thanks for your help, but I think I’m going to give up… nothing works, I have another MM I’m going to copy the sd card and copy it to that of my MM and not do an update, if I understood correctly that it is the operating system that does not support updating? if this is it on which system should I install MM please?
                              sdetweil @manu85340
                              @manu85340 the latest raspi OS is bookworm…
                              if this is a pi3 Id do the 32 bit version to save memory space.
                              I have updated the installer and upgrader to fail if trying to install or upgrade now on buster
                              • 2 / 3
