    MMM-Fritz-Box-Callmonitor: Notification formatting
    31 Posts 7 Posters 25.3k Views 7 Watching
      Jose Walsh
      @Jan-0 said in MMM-Fritz-Box-Callmonitor: Notification formatting:
      I’m referring to this module (https://github.com/paviro/MMM-FRITZ-Box-Callmonitor). Although it is quite outdated, I still like it and I was able to transfer it to an python3 environment. However, since some update (don’t know which one), the notification (“alert”) is not formatted properly.
      The reason seems to be in line 85 of the file MMM-FRITZ-Box-Callmonitor.js:
      // Override socket notification handler.
      if (notification === “call”) {
      //Show alert on UI
      this.sendNotification(“SHOW_ALERT”, {
      title: this.translate(“title”),
      message: “” + payload + “”,
      imageFA: “phone”
        	//Set active Alert to current call
        	this.activeAlert = payload;
      There are two problems: 1) the title is not translated but printed, 2) the message is not formatted but the formatting information is printed verbosely.
      Unfortunately, I’m neither an expert in the MagicMirror syntax nor in javascript. Could somebody give me a hint how I need to adopt the code?
      To fix this, you can remove the quotes and use template literals instead. Template literals allow you to include variables and formatting within a string using backticks () instead of quotes. Here's how you can modify the code to use template literals: socketNotificationReceived: function(notification, payload) { if (notification === "call") { //Show alert on UI this.sendNotification("SHOW_ALERT", { title: this.translate("title"), message: ${payload}`,
      imageFA: “phone”
      As for the translation issue, you need to make sure that the translate function is correctly configured in your module. The translate function should be defined in the getTranslations function in the module’s node_helper.js file. Here’s an example of how to define the translate function:
      getTranslations: function() {
      return {
      en: “translations/en.json”,
      de: “translations/de.json”
      translate: function(key) {
      return this.translate(key);
      This assumes that you have translation files for English and German located in the translations folder of your module. You may need to modify this code to match the structure of your module.
      I hope this helps! Let me know if you have any other questions.
      • wishmaster270W Offline
        wishmaster270 Module Developer @coernel
        @coernel
        as i can see this fork https://github.com/drtorchwood/MMM-FRITZ-Box-Callmonitor-py3/tree/code_update_2023 contains all changes needed.
        But you will need to either use the current development version of MagicMirror or wait for the next release which i think is planned for 2022-04-01 to get the alerts formatted correctly.
          coernel @wishmaster270
          @wishmaster270 said in MMM-Fritz-Box-Callmonitor: Notification formatting:
          @coernel
          This is great however I just get this:
          Is this the formatting error we are talking about without the Core update? If yes I am willing to wait. But this for me looks like more than a formatting setting!
          Callmonitor definately is enabled via Fritz!Phone. And username and password are correct - I can access the Fritz!Box and the user has the view and edit settings:
          Benutzer mit dieser Berechtigung können alle Einstellungen der FRITZ!Box sehen und bearbeiten.
          Any help would be appreciated!
            @coernel
            The view you show indicates that there are no recent calls and that the fetch of the telephone book is still running or was not successful. But it is the normal view. The calls will be signaled as alerts. So make sure you have the default alert module activated in your config.js:
            			module: "alert",
            The formatting will only be wrong in the alert.
            Please make sure to check the following things, too:
            • You cloned the right fork with the following command?
            cd ~/MagicMirror/modules
            git clone git@github.com:drtorchwood/MMM-FRITZ-Box-Callmonitor-py3.git
            Edit:
            * You use the right branch by calling the following commands?
            As of 2023-02-25 the changes are merged to the master branch of the fork. So no need to change to the code_update_2023 branch anymore.
            • You installed the JavaScript dependencies?
            cd ~/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor-py3
            npm install
            • You installed the Python dependencies?
            sudo pip3 install fritzconnection
            • You activated the call monitor service of the box by dialing the following number with one of your phones?
            #96*5*
            • You configured the right IP address in config.js with option fritzIP. Default is 192.168.178.1?
            			module: 'MMM-FRITZ-Box-Callmonitor-py3',
            			position: 'bottom_left',
            			header: "Verpasste Anrufe",
            				username: "foo",
            				password: "bar",
            				fritzIP: "10.18.8.1",
            				reloadContactsInterval: 50,
            				minimumCallLength: 0,
            				showContactsStatus: true,
            				maximumCallDistance: 60*6,
            				maximumCalls: 4,
            				fade: false,
            				debug: true,
            If the call monitor service is not activated on the fritz box you will see a message like this in the logs:
            [24.02.2023 16:31.29.944] [ERROR] Error: connect ECONNREFUSED 192.168.178.1:1012
                at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1494:16) {
              errno: -111,
              code: 'ECONNREFUSED',
              syscall: 'connect',
              address: '192.168.178.1,
              port: 1012
            And again the call monitor service is independent of username and password. The credentials are used to fetch the telephone book and the past calls only.
            Thats how the default view looks in my case:
            And thats how it looks if there is a incomming call:
            If you do not use the current development branch of MagicMirror there may be some html code in the alert and it will look like <span style='font-size:30px'>Tom</span>
              Jan 0 @coernel
              @coernel I now also pushed the changes into the master https://github.com/drtorchwood/MMM-FRITZ-Box-Callmonitor-py3/tree/master
                coernel @Jan 0
                @Jan-0
                This is so cool! It does work now. Has it been published to the list of modules?
                If you or @wishmaster270 are somewhere near Cologne you or are invited for a free professional solo session of Feldenkrais Functional Integration or a free professional singing lesson!
                  @coernel
                  Great to hear and you are welcome. I try to help where I can.
                  I live about 30km south of Munich but thanks for your invitation.
                  • X Offline
                    xIExodusIx
                    Hi Everybody out there using MMM-FRITZ-Box-Callmonitor,
                    I would love to use this Module, but I’m not really in the mod to code or to find errors.
                    I tried to install your new branch under PiOS “Bookworm” but I get some errors using
                    “sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection”!
                    The first error is: " E: For Package »python-dev« exists no Installationscandidate."
                    The second error for pip install is: “externally-managed-environment …”
                    How can I solve these problems?
                    Sorry for my bad english, I’m german and over 60 years old.
                    Thanks for helping.
                      rabbit83ka @xIExodusIx
                      @xIExodusIx that’s due to changes in the handling of the python packages. I installed “fritzconnection” in a virtual environment:
                      python -m venv venv
                      source venv/bin/activate
                      python -m pip install fritzconnection
                      to make the Callmonitor use the fritzconnection, I edited the nodehelper.js (in ~/MagicMirror/modules/MMM-FritzBox-Callmonitor-py3) in line 212 to look like this (user is “pi”, must be adapted if you use another user):
                      pythonPath: '/home/pi/venv/bin/python',
                      Don’t know if it’s the best solution, but it works.
                        sdetweil @rabbit83ka
                        @rabbit83ka you can set the venv in the mm.sh that starts MagicMirror
                        then you don’t need to do that
                          rabbit83ka @sdetweil
                          @sdetweil Thanks, so it should look like this?
                          #!/bin/bash
                          # This file is still here to keep PM2 working on older installations.
                          export PYTHONPATH="/home/pi/venv/bin/python"
                          DISPLAY=:0 npm start
                            @rabbit83ka no, execute the venv command to set the virtual environment in place of the export
                            the same venv command you did before running pip
                              @sdetweil I used your script
                              fixuppm2.sh
                              when I set up the mirror
                              Now I modified ~/MagicMirror/installers/mm.sh to
                              #!/bin/bash
                              but that doesn’t work, error occures again because node_helper doesn’t seem to use the venv.
                                @rabbit83ka when I look at my .bashrc whichs sets up the default venv on shell open
                                I see
                                # Virtual Environment Wrapper
                                source /usr/local/bin/virtualenvwrapper.sh
                                PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig
                                export PKG_CONFIG_PATH
                                cd ~
                                this topic seems applicable
                                https://unix.stackexchange.com/questions/87062/how-to-display-the-name-of-the-current-virtualenv
                                  @rabbit83ka I also see this for background
                                  https://arshovon.com/blog/python-background/
