    MMM-DailyBibleVerse
    Scheduled Pinned Locked Moved Education
    25 Posts 7 Posters 22.9k Views 7 Watching
      broberg Project Sponsor @arthurgarzajr
      @arthurgarzajr
      I googled it, and they have a RSS feed,
      So just add this adress : https://www.biblegateway.com/votd/get/?format=atom
      To the newsfeed module and you will get the verse every day.
      Edit : sorry, I thought this was a request, my bad :D
      • Y
        yawns Moderator @arthurgarzajr
        @arthurgarzajr said in MMM-DailyBibleVerse:
        I made a module to display the verse of the day from www.biblegateway.com. :)
        Please add the link to your github repository and please add a screenshot. Otherwise this entry is kind of useless :)
        • A
          arthurgarzajr
          Whoops! Here’s the link to the repository: https://github.com/arthurgarzajr/MMM-DailyBibleVerse
            racampbellky
            I get the first day but then have socket errors when trying to refresh.
            • A
              arthurgarzajr
              What is the socket error you are getting?
                racampbellky
                MMM-DailyBibleVerse node helper received a socket notification: START - Payload: [object Object]
                {“error”:{“code”:“103”,“message”:“Invalid version: Please check your version parameter”}}
                • A
                  arthurgarzajr
                  Great! Thank you. It seems that the version is not being passed properly after a while…I’ve been trying to figure out what was going on but with that error message I am able to see what is happening.
                  Let me try to fix it and I’ll get back with you on if my fix worked.
                  Thanks!
                  R 1 Reply Last reply
                    racampbellky @arthurgarzajr
                    @arthurgarzajr Any Luck on this issue? Love the module
                    • A
                      arthurgarzajr
                      Hey! Thanks for checking back. Yes I think I have it fixed.
                      I’ve been waiting a few days to verify it really is fixed before I updated this thread and pushed my code to Github.
                      Let me check tonight if it’s still working and I will push my changes.
                      • A
                        arthurgarzajr
                        Ok the fix seems stable. You can do a git pull to get the latest and please reply back if you’re still experiencing issues.
                        Thanks!
                          bminer1
                          How do i make the font smaller? With long verses, it sucks up a lot of space. If I could half the size or match the text size of the other modules, it would free up more mirror.
                          • cowboysdudeC
                            cowboysdude Module Developer @bminer1
                            @bminer1 said in MMM-DailyBibleVerse:
                            Custom css file:
                             MMM-DailyBibleVerse {
                            font-size: 12px;
                            should work… make is any size you want…
                            B 2 Replies Last reply
                              bminer1 @cowboysdude
                              @cowboysdude said in MMM-DailyBibleVerse:
                              font-size: 12px;
                              Im thinking to myself, i know i can do this without help. It has to be simple. Then i gave up and spit it out here. Now look, its a frickin 1 liner! ugh, ill get it eventually.
                              Thanks, even though your a cowboys fans. ;-)
                                @cowboysdude
                                No luck on the custom.css file. Still the same size. Tried a 8px and no changes.
                                B 1 Reply Last reply
                                  broberg Project Sponsor @bminer1
                                  @bminer1 it’s missing a .
                                  .MMM-DailyBibleVerse {
                                  font-size: 12px;
                                    bminer1 @broberg
                                    @broberg Worked! Now to get it a little closer together. Line 1 is really far from line 2.
                                    • cowboysdudeC
                                      @bminer1
                                      Eh thought I put the . in there LOL
                                      Try this:
                                      font-size: 12px;
                                      line-height: 34%;
                                      Adjust your % until you get what you want ;)
                                      • A
                                        arthurgarzajr
                                        Would it be preferred to control the font size from the configuration of the actual module rather than in the custom.css file? Or what is the standard way to do this in the Magic Mirror framework?
                                        • cowboysdudeC
                                          cowboysdude Module Developer @arthurgarzajr
                                          @arthurgarzajr You could put in a config option to do it from config.js… using the custom css file is just as easy :)
                                          A 1 Reply Last reply
                                          • A
                                            arthurgarzajr @cowboysdude
                                            @cowboysdude Cool thanks! I might make it configurable as an option for the config.js later.
