    MMM-DailyBibleVerse
    Scheduled Pinned Locked Moved Education
    25 Posts 7 Posters 23.2k Views 7 Watching
      racampbellky
      I get the first day but then have socket errors when trying to refresh.
      • A
        arthurgarzajr
        What is the socket error you are getting?
          racampbellky
          MMM-DailyBibleVerse node helper received a socket notification: START - Payload: [object Object]
          {“error”:{“code”:“103”,“message”:“Invalid version: Please check your version parameter”}}
          • A
            arthurgarzajr
            Great! Thank you. It seems that the version is not being passed properly after a while…I’ve been trying to figure out what was going on but with that error message I am able to see what is happening.
            Let me try to fix it and I’ll get back with you on if my fix worked.
            Thanks!
            R 1 Reply Last reply
              racampbellky @arthurgarzajr
              @arthurgarzajr Any Luck on this issue? Love the module
              • A
                arthurgarzajr
                Hey! Thanks for checking back. Yes I think I have it fixed.
                I’ve been waiting a few days to verify it really is fixed before I updated this thread and pushed my code to Github.
                Let me check tonight if it’s still working and I will push my changes.
                • A
                  arthurgarzajr
                  Ok the fix seems stable. You can do a git pull to get the latest and please reply back if you’re still experiencing issues.
                  Thanks!
                    bminer1
                    How do i make the font smaller? With long verses, it sucks up a lot of space. If I could half the size or match the text size of the other modules, it would free up more mirror.
                    • cowboysdudeC
                      cowboysdude Module Developer @bminer1
                      @bminer1 said in MMM-DailyBibleVerse:
                      Custom css file:
                       MMM-DailyBibleVerse {
                      font-size: 12px;
                      should work… make is any size you want…
                      B 2 Replies Last reply
                        bminer1 @cowboysdude
                        @cowboysdude said in MMM-DailyBibleVerse:
                        font-size: 12px;
                        Im thinking to myself, i know i can do this without help. It has to be simple. Then i gave up and spit it out here. Now look, its a frickin 1 liner! ugh, ill get it eventually.
                        Thanks, even though your a cowboys fans. ;-)
                          @cowboysdude
                          No luck on the custom.css file. Still the same size. Tried a 8px and no changes.
                          brobergB 1 Reply Last reply
                          • brobergB
                            broberg Project Sponsor @bminer1
                            @bminer1 it’s missing a .
                            .MMM-DailyBibleVerse {
                            font-size: 12px;
                              bminer1 @broberg
                              @broberg Worked! Now to get it a little closer together. Line 1 is really far from line 2.
                              • cowboysdudeC
                                @bminer1
                                Eh thought I put the . in there LOL
                                Try this:
                                font-size: 12px;
                                line-height: 34%;
                                Adjust your % until you get what you want ;)
                                • A
                                  arthurgarzajr
                                  Would it be preferred to control the font size from the configuration of the actual module rather than in the custom.css file? Or what is the standard way to do this in the Magic Mirror framework?
                                  • cowboysdudeC
                                    cowboysdude Module Developer @arthurgarzajr
                                    @arthurgarzajr You could put in a config option to do it from config.js… using the custom css file is just as easy :)
                                    A 1 Reply Last reply
                                    • A
                                      arthurgarzajr @cowboysdude
                                      @cowboysdude Cool thanks! I might make it configurable as an option for the config.js later.
                                        maestro82
                                        Any issues running this module lately?
                                        • A
                                          arthurgarzajr @maestro82
                                          @maestro82 I haven’t had issues. Are you having issues?
                                          M 1 Reply Last reply
                                            maestro82 @arthurgarzajr
                                            @arthurgarzajr Being the newbie that I am I typed “bottom-bar” for location. Worked on it for an hour before the “-” was replaced with “_”. Amazing how one letter can use up your time. No the module is working fine now.
                                            Reply Quote 2
