    SWAKES Mirror
    8 Posts 5 Posters 8.1k Views 5 Watching
      pqpxo
      Here is my Magic Mirror
      • 32" TV (bought from auction for £35 as sound doesn’t work)
      • Raspberry Pi 2 B+ (thought RasPi 3 would be overkill)
      • Frame bought from Dunelm, original mirror removed and replaced with two way glass
      • Frame is mounted to the wall using metal wall brackets (second image), luckily the spacing was perfect and allows easy access to ports
      • Running Amazon Alexa Voice service in the background (activated by LED push switch)
      MitchfarinoM 1 Reply Last reply Reply Quote 4
        BROSS
        That’s a great looking mirror.
        • K Offline
          kanczug
          I would love to know how You hooked the Alexa and wired a button for it. Can You make a module for others to install in their mirror? I have seen some tutorials how to create Amazon Echo / Tap from a Raspberry PI, but they are freaking complicated! I am afraid that I will run in some troubles implementing it into MagicMirror
            pqpxo @BROSS
            @BROSS Cheers bro!
              pqpxo @kanczug
              @kanczug It was pretty easy to setup! Basically followed the instructions in this video (https://www.youtube.com/watch?v=frH9HaQTFL8)
              I connected the button to GPIO18
              Noticed my first button didn’t work unless I had a 10k resistor between the button and GPIO18
              I bought an external sound card for the mic and speakers from PiHut for £3!
              • K Offline
                kanczug
                Thanks! Gonna try it out!
                • MitchfarinoM Offline
                  Mitchfarino Module Developer @pqpxo
                  @pqpxo Where did you get your glass from?
                    RogierKentie @pqpxo
                    @pqpxo Can you show me a picture of the backsite of your mirror and the code? Than I know what to do for installing the button!
