    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 11.0k Views 2 Watching
      sdetweil @Ix
      @Ix said in Error EBADENGINE when installing MM v2.28.0:
      drwxr-xr-x 414 root root 28672 3. Apr 17:16 node_modules/
      my only guess
      SO, lets try
      # using sudo here only to remove the root owned folder
      sudo rm -rf node_modules
      npm run install-mm
      I 1 Reply Last reply
      • I
        Ix @sdetweil
        I deleted node_modules directory as recommended and after that, this is what happened:
        mirror@raspberrypi:~/MagicMirror $ npm run install-mm
        > magicmirror@2.28.0 install-mm
        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
        npm error notsup Required: {"node":">=20"}
        npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
        npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
        Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
          sdetweil @Ix
          @Ix wild… never seen this.
          SO, i would use nvm and n to remove all the added node versions…
          get back to whatever before…
          exit the shell window and open again
          verify still on the prior nodejs
          then use n version_number
          sudo n 20.9
          verify that is correct node -v
          the close shell and open again,
          verify node
          then try the npm run install-mm again
          • I
            Ix @sdetweil
            @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
            done
            done
            sudo n 20.9
            verify node
            well, now there’s another problem:
            mirror@raspberrypi:~ $ sudo n 20.9
                 copying : node/20.9.0
            /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
               installed :  (with npm 10.1.0)
            mirror@raspberrypi:~ $ node -v
            -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
            Sry for German: it’s “no such file or directory”
              sdetweil @Ix
              @Ix do
              which node
              Then
              sudo rm $(which node)
              Then
              hash -r
              which node
              and again
              Then node -v
              • I
                Ix @sdetweil
                okay done all that, node is completely gone from my machine. I guess, reinstalling it would be the next step?
                  sdetweil @Ix
                  @Ix rename the MagicMirror folder and run my install script
                  S I 2 Replies Last reply
                    @Ix then rename new out and old back in and do the npm run install-mm
                    • I
                      Ix @sdetweil
                      Tried that, but the script failed. I have attached the install.log
                      install starting  - Mon Aug  5 18:37:16 CEST 2024
                      installing on aarch64 processor system
                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                     total        used        free      shared  buff/cache   available
                      Mem:            1849         228        1116          30         504        1527
                      Swap:           2047           0        2047
                      Updating packages ...
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists...
                      apt-get update  completed ok
                      Building dependency tree...
                      Reading state information...
                      pv is already the newest version (1.6.6-1).
                      apt-get upgrade  started
                      apt-get upgrade result =rc=0 Reading package lists...
                      Calculating upgrade...
                      Installing helper tools ...
                      build-essential is already the newest version (12.9).
                      curl is already the newest version (7.74.0-1.3+deb11u12).
                      git is already the newest version (1:2.30.2-1+deb11u2).
                      unzip is already the newest version (6.0-26+deb11u1).
                      wget is already the newest version (1.21-1+deb11u1).
                      node not installed, trying via apt-get
                      Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package nodejs:armv7l E: Unable to locate package npm:armv7l
                      npm not installed, trying via apt-get
                      npm installed now, install n
                      Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libnode72 : Conflicts: nodejs-legacy nodejs : Conflicts: npm E: Unable to correct problems, you have held broken packages.
                      installing on bullseye
                      node failed to execute, please check the error message and resolve before trying again
                      install aborted - Mon Aug  5 18:37:59 CEST 2024
                        sdetweil @Ix
                        @Ix do node -v
                        • I
                          Ix @sdetweil
                          @Ix do node -v
                          bash: node: command not found
                            sdetweil @Ix
                            @Ix do
                            which node
                            Or
                            Find /usr -type f -name node
                            • I
                              Ix @sdetweil
                              @Ix do
                              which node
                              Or
                              these commands don’t output anything.
                                sdetweil @Ix
                                @Ix well isn’t that interesting.
                                do
                                sudo apt update
                                sudo apt install nodejs
                                node -v
                                • I
                                  Ix @sdetweil
                                  @sdetweil you’re so patient! Thank you!
                                  mirror@raspberrypi:~ $ sudo apt update
                                  Reading package lists... Done
                                  Building dependency tree... Done
                                  All packages are up to date.
                                  mirror@raspberrypi:~ $ sudo apt install node.js
                                  E: Unable to locate package node.js
                                  E: Couldn't find any package by glob 'node.js'
                                  rebooted beforehand
                                  • I
                                    Ix @sdetweil
                                    node -v
                                    ah snap, I made a small mistake here. I redid it without typo:
                                    mirror@raspberrypi:~ $ sudo apt install nodejs
                                    nodejs is already the newest version (18.17.1-deb-1nodesource1).
                                    somewhere in my OS must still remain some node debris…
                                    Edit: tried this:
                                    mirror@raspberrypi:~ $ sudo apt remove nodejs
                                    The following packages will be REMOVED:
                                      nodejs
                                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                    After this operation, 177 MB disk space will be freed.
                                    Do you want to continue? [Y/n] y
                                    (Reading database ... 114411 files and directories currently installed.)
                                    Removing nodejs (18.17.1-deb-1nodesource1) ...
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_
                                    modules/yallist' not empty so not removed
                                    modules/write-file-atomic' not empty so not removed
                                    modules/wrap-ansi/node_modules/emoji-regex' not empty so not removed
                                    modules/wrap-ansi-cjs' not empty so not removed
                                    modules/which' not empty so not removed
                                    modules/walk-up-path' not empty so not removed
                                    modules/validate-npm-package-name' not empty so not removed
                                    modules/validate-npm-package-license' not empty so not removed
                                    modules/util-deprecate' not empty so not removed
                                    modules/unique-slug' not empty so not removed
                                    modules/unique-filename' not empty so not removed
                                    modules/tuf-js' not empty so not removed
                                    modules/treeverse' not empty so not removed
                                    modules/tiny-relative-date' not empty so not removed
                                    modules/text-table' not empty so not removed
                                    modules/tar/node_modules/fs-minipass/node_modules/minipass' not empty so not rem
                                    oved
                                    modules/ssri' not empty so not removed
                                    modules/spdx-expression-parse' not empty so not removed
                                    modules/spdx-exceptions' not empty so not removed
                                    modules/spdx-correct' not empty so not removed
                                    modules/socks' not empty so not removed
                                    modules/socks-proxy-agent' not empty so not removed
                                    modules/smart-buffer' not empty so not removed
                                    modules/sigstore' not empty so not removed
                                    modules/signal-exit' not empty so not removed
                                    modules/semver/internal' not empty so not removed
                                    modules/safer-buffer' not empty so not removed
                                    modules/retry' not empty so not removed
                                    modules/read' not empty so not removed
                                    modules/read-package-json-fast' not empty so not removed
                                    modules/read-cmd-shim' not empty so not removed
                                    modules/qrcode-terminal' not empty so not removed
                                    modules/promzard' not empty so not removed
                                    modules/promise-retry' not empty so not removed
                                    modules/promise-inflight' not empty so not removed
                                    modules/promise-call-limit' not empty so not removed
                                    modules/promise-all-reject-late' not empty so not removed
                                    modules/proc-log' not empty so not removed
                                    modules/postcss-selector-parser' not empty so not removed
                                    modules/path-scurry/dist' not empty so not removed
                                    modules/parse-conflict-json' not empty so not removed
                                    modules/pacote/lib/util' not empty so not removed
                                    modules/npm-user-validate' not empty so not removed
                                    modules/npm-registry-fetch' not empty so not removed
                                    modules/npm-profile' not empty so not removed
                                    modules/npm-pick-manifest' not empty so not removed
                                    modules/npm-packlist' not empty so not removed
                                    modules/npm-package-arg' not empty so not removed
                                    modules/npm-normalize-package-bin' not empty so not removed
                                    modules/npm-install-checks' not empty so not removed
                                    modules/npm-bundled' not empty so not removed
                                    modules/npm-audit-report' not empty so not removed
                                    modules/normalize-package-data' not empty so not removed
                                    modules/nopt' not empty so not removed
                                    modules/node-gyp/node_modules' not empty so not removed
                                    modules/node-gyp/lib' not empty so not removed
                                    modules/node-gyp/gyp/pylib' not empty so not removed
                                    modules/negotiator' not empty so not removed
                                    modules/mute-stream' not empty so not removed
                                    modules/ms' not empty so not removed
                                    modules/mkdirp' not empty so not removed
                                    modules/minizlib/node_modules/minipass' not empty so not removed
                                    modules/minipass-sized/node_modules/minipass' not empty so not removed
                                    modules/minipass-pipeline/node_modules/minipass' not empty so not removed
                                    modules/minipass-json-stream/node_modules/minipass' not empty so not removed
                                    modules/minipass-flush/node_modules/minipass' not empty so not removed
                                    modules/minipass-fetch' not empty so not removed
                                    modules/minipass-collect' not empty so not removed
                                    modules/minimatch/dist' not empty so not removed
                                    modules/make-fetch-happen' not empty so not removed
                                    modules/lru-cache' not empty so not removed
                                    modules/libnpmversion' not empty so not removed
                                    modules/libnpmteam' not empty so not removed
                                    modules/libnpmsearch' not empty so not removed
                                    modules/libnpmpublish' not empty so not removed
                                    modules/libnpmpack' not empty so not removed
                                    modules/libnpmorg' not empty so not removed
                                    modules/libnpmhook' not empty so not removed
                                    modules/libnpmfund' not empty so not removed
                                    modules/libnpmexec' not empty so not removed
                                    modules/libnpmdiff' not empty so not removed
                                    modules/libnpmaccess' not empty so not removed
                                    modules/just-diff' not empty so not removed
                                    modules/just-diff-apply' not empty so not removed
                                    modules/jsonparse' not empty so not removed
                                    modules/json-stringify-nice' not empty so not removed
                                    modules/json-parse-even-better-errors' not empty so not removed
                                    modules/jackspeak/dist' not empty so not removed
                                    modules/isexe' not empty so not removed
                                    modules/is-lambda' not empty so not removed
                                    modules/is-core-module' not empty so not removed
                                    modules/init-package-json' not empty so not removed
                                    modules/ini' not empty so not removed
                                    modules/ignore-walk' not empty so not removed
                                    modules/iconv-lite' not empty so not removed
                                    modules/https-proxy-agent' not empty so not removed
                                    modules/http-proxy-agent' not empty so not removed
                                    modules/http-cache-semantics' not empty so not removed
                                    modules/hosted-git-info' not empty so not removed
                                    modules/graceful-fs' not empty so not removed
                                    modules/glob/dist' not empty so not removed
                                    modules/function-bind' not empty so not removed
                                    modules/fs-minipass' not empty so not removed
                                    modules/foreground-child' not empty so not removed
                                    modules/fastest-levenshtein' not empty so not removed
                                    modules/err-code' not empty so not removed
                                    modules/encoding' not empty so not removed
                                    modules/diff/lib/patch' not empty so not removed
                                    modules/debug/node_modules/ms' not empty so not removed
                                    modules/cssesc' not empty so not removed
                                    modules/cross-spawn/node_modules/which' not empty so not removed
                                    modules/common-ancestor-path' not empty so not removed
                                    modules/color-name' not empty so not removed
                                    modules/color-convert' not empty so not removed
                                    modules/cmd-shim' not empty so not removed
                                    modules/cidr-regex' not empty so not removed
                                    modules/ci-info' not empty so not removed
                                    modules/chownr' not empty so not removed
                                    modules/chalk/source' not empty so not removed
                                    modules/cacache' not empty so not removed
                                    modules/brace-expansion' not empty so not removed
                                    modules/bin-links' not empty so not removed
                                    modules/balanced-match' not empty so not removed
                                    modules/archy' not empty so not removed
                                    modules/aproba' not empty so not removed
                                    modules/agent-base/dist' not empty so not removed
                                    modules/abbrev' not empty so not removed
                                    modules/@tufjs/models' not empty so not removed
                                    modules/@tufjs/canonical-json' not empty so not removed
                                    modules/@sigstore/protobuf-specs/dist/__generated__/google/protobuf' not empty s
                                    o not removed
                                    modules/@pkgjs/parseargs' not empty so not removed
                                    modules/@npmcli/run-script' not empty so not removed
                                    modules/@npmcli/query' not empty so not removed
                                    modules/@npmcli/promise-spawn' not empty so not removed
                                    modules/@npmcli/package-json' not empty so not removed
                                    modules/@npmcli/name-from-folder' not empty so not removed
                                    modules/@npmcli/metavuln-calculator' not empty so not removed
                                    modules/@npmcli/map-workspaces' not empty so not removed
                                    modules/@npmcli/installed-package-contents' not empty so not removed
                                    modules/@npmcli/git' not empty so not removed
                                    modules/@npmcli/fs/lib/cp' not empty so not removed
                                    modules/@npmcli/config/lib' not empty so not removed
                                    modules/@npmcli/arborist/lib' not empty so not removed
                                    modules/@isaacs/string-locale-compare' not empty so not removed
                                    modules/@isaacs/cliui/node_modules/emoji-regex' not empty so not removed
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/m
                                    an1' not empty so not removed
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/u
                                    tils' not empty so not removed
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/c
                                    ommands' not empty so not removed
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/
                                    output/configuring-npm' not empty so not removed
                                    output/commands' not empty so not removed
                                    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin'
                                    Processing triggers for man-db (2.9.4-2) ...
                                      sdetweil @Ix
                                      @Ix do
                                      hash -r
                                      which node
                                      which npm
                                      if they respond then that is the path location of each program
                                      • I
                                        Ix @sdetweil
                                        Hey!
                                        I tried this several times. it seems like there is no way on my system to properly reinstall node. All I get is the same errors I posted above. So my next step (the one I didn’t want to do) is to set up a completely new system and build up everything from scratch.
                                        Anyway thank you for your help!
                                          sdetweil @Ix
                                          @Ix backup your MagicMirror config
                                          see my back up/ restore
                                          https://github.com/sdetweil/MagicMirror-backup-restore
