    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 10.8k Views 2 Watching
    • I
      Ix @sdetweil
      first: thanks for answering so fast!
      node -v gives this:
      mirror@raspberrypi:~ $ node -v
      v20.16.0
      this is also the version I installed via n
      nevertheless, the wrong version is recognized when trying npm i
        sdetweil @Ix
        @Ix how about npm -v
        • I
          Ix @sdetweil
          mirror@raspberrypi:~ $ npm -v
          10.8.1
            sdetweil @Ix
            @Ix ok, can u give the output of
            npm run install-mm
            now
            • I
              Ix @sdetweil
              @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
              npm run install-mm
              mirror@raspberrypi:~/MagicMirror $ npm run install-mm
              > magicmirror@2.28.0 install-mm
              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
              npm error code EBADENGINE
              npm error engine Unsupported engine
              npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
              npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
              npm error notsup Required: {"node":">=20"}
              npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
              npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
                sdetweil @Ix
                @Ix said in Error EBADENGINE when installing MM v2.28.0:
                ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
                show results of
                whoami
                ls -laF
                • I
                  Ix @sdetweil
                  whoami
                  mirror@raspberrypi:~/MagicMirror $ whoami
                  mirror
                  and ls in MM directory:
                  mirror@raspberrypi:~/MagicMirror $ ls -laF
                  insgesamt 688
                  drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
                  drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
                  -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
                  drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
                  -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
                  drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
                  drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
                  -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
                  -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
                  -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
                  -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
                  drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
                  drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
                  -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
                  drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
                  -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
                  drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
                  -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
                  drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
                  -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
                  drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
                  -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
                  -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
                  -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
                  drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
                  -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
                  drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
                  -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
                  -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
                  -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
                  -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
                  -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
                  -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
                  drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
                  drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
                  -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
                  drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
                  drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
                  drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
                    sdetweil @Ix
                    my only guess
                    SO, lets try
                    # using sudo here only to remove the root owned folder
                    sudo rm -rf node_modules
                    npm run install-mm
                    • I
                      Ix @sdetweil
                      I deleted node_modules directory as recommended and after that, this is what happened:
                      npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
                      npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
                      Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
                        sdetweil @Ix
                        @Ix wild… never seen this.
                        SO, i would use nvm and n to remove all the added node versions…
                        get back to whatever before…
                        exit the shell window and open again
                        verify still on the prior nodejs
                        then use n version_number
                        sudo n 20.9
                        verify that is correct node -v
                        the close shell and open again,
                        verify node
                        then try the npm run install-mm again
                        • I
                          Ix @sdetweil
                          done
                          done
                          sudo n 20.9
                          verify node
                          well, now there’s another problem:
                          mirror@raspberrypi:~ $ sudo n 20.9
                               copying : node/20.9.0
                          /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                             installed :  (with npm 10.1.0)
                          -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                          Sry for German: it’s “no such file or directory”
                            sdetweil @Ix
                            @Ix do
                            which node
                            Then
                            sudo rm $(which node)
                            Then
                            hash -r
                            which node
                            and again
                            Then node -v
                            • I
                              Ix @sdetweil
                              okay done all that, node is completely gone from my machine. I guess, reinstalling it would be the next step?
                                sdetweil @Ix
                                @Ix rename the MagicMirror folder and run my install script
                                S I 2 Replies Last reply Reply Quote 0
                                  @Ix then rename new out and old back in and do the npm run install-mm
                                  • I
                                    Ix @sdetweil
                                    Tried that, but the script failed. I have attached the install.log
                                    install starting  - Mon Aug  5 18:37:16 CEST 2024
                                    installing on aarch64 processor system
                                    the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                                   total        used        free      shared  buff/cache   available
                                    Mem:            1849         228        1116          30         504        1527
                                    Swap:           2047           0        2047
                                    Updating packages ...
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists...
                                    apt-get update  completed ok
                                    Building dependency tree...
                                    Reading state information...
                                    pv is already the newest version (1.6.6-1).
                                    apt-get upgrade  started
                                    apt-get upgrade result =rc=0 Reading package lists...
                                    Calculating upgrade...
                                    Installing helper tools ...
                                    build-essential is already the newest version (12.9).
                                    curl is already the newest version (7.74.0-1.3+deb11u12).
                                    git is already the newest version (1:2.30.2-1+deb11u2).
                                    unzip is already the newest version (6.0-26+deb11u1).
                                    wget is already the newest version (1.21-1+deb11u1).
                                    node not installed, trying via apt-get
                                    Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package nodejs:armv7l E: Unable to locate package npm:armv7l
                                    npm not installed, trying via apt-get
                                    npm installed now, install n
                                    Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libnode72 : Conflicts: nodejs-legacy nodejs : Conflicts: npm E: Unable to correct problems, you have held broken packages.
                                    installing on bullseye
                                    node failed to execute, please check the error message and resolve before trying again
                                    install aborted - Mon Aug  5 18:37:59 CEST 2024
                                      sdetweil @Ix
                                      @Ix do node -v
                                      • I
                                        Ix @sdetweil
                                        @Ix do node -v
                                        bash: node: command not found
                                          sdetweil @Ix
                                          @Ix do
                                          which node
                                          Or
                                          Find /usr -type f -name node
                                          • I
                                            Ix @sdetweil
                                            @Ix do
                                            which node
                                            Or
                                            these commands don’t output anything.
