    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 7.0k Views 2 Watching
      sdetweil @Ix
      @Ix how about npm -v
      • I Offline
        Ix @sdetweil
        mirror@raspberrypi:~ $ npm -v
        10.8.1
          sdetweil @Ix
          @Ix ok, can u give the output of
          npm run install-mm
          now
          • I Offline
            Ix @sdetweil
            @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
            npm run install-mm
            mirror@raspberrypi:~/MagicMirror $ npm run install-mm
            > magicmirror@2.28.0 install-mm
            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            npm error code EBADENGINE
            npm error engine Unsupported engine
            npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
            npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
            npm error notsup Required: {"node":">=20"}
            npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
            npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
              sdetweil @Ix
              @Ix said in Error EBADENGINE when installing MM v2.28.0:
              ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
              show results of
              whoami
              ls -laF
              • I Offline
                Ix @sdetweil
                whoami
                mirror@raspberrypi:~/MagicMirror $ whoami
                mirror
                and ls in MM directory:
                mirror@raspberrypi:~/MagicMirror $ ls -laF
                insgesamt 688
                drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
                drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
                -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
                drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
                -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
                drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
                drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
                -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
                -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
                -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
                -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
                drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
                drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
                -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
                drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
                -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
                drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
                -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
                drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
                -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
                drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
                -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
                -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
                -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
                drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
                -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
                drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
                -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
                -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
                -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
                -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
                -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
                -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
                drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
                drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
                -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
                drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
                drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
                drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
                  sdetweil @Ix
                  my only guess
                  SO, lets try
                  # using sudo here only to remove the root owned folder
                  sudo rm -rf node_modules
                  npm run install-mm
                  • I Offline
                    Ix @sdetweil
                    I deleted node_modules directory as recommended and after that, this is what happened:
                    npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
                    npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
                    Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
                      sdetweil @Ix
                      @Ix wild… never seen this.
                      SO, i would use nvm and n to remove all the added node versions…
                      get back to whatever before…
                      exit the shell window and open again
                      verify still on the prior nodejs
                      then use n version_number
                      sudo n 20.9
                      verify that is correct node -v
                      the close shell and open again,
                      verify node
                      then try the npm run install-mm again
                      • I Offline
                        Ix @sdetweil
                        done
                        done
                        sudo n 20.9
                        verify node
                        well, now there’s another problem:
                        mirror@raspberrypi:~ $ sudo n 20.9
                             copying : node/20.9.0
                        /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                           installed :  (with npm 10.1.0)
                        mirror@raspberrypi:~ $ node -v
                        -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                        Sry for German: it’s “no such file or directory”
