    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 11.0k Views 2 Watching
      sdetweil @Ix
      @Ix ok, can u give the output of
      npm run install-mm
      now
      I 1 Reply Last reply
      • I
        Ix @sdetweil
        @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
        npm run install-mm
        mirror@raspberrypi:~/MagicMirror $ npm run install-mm
        > magicmirror@2.28.0 install-mm
        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
        npm error notsup Required: {"node":">=20"}
        npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
        npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
          sdetweil @Ix
          @Ix said in Error EBADENGINE when installing MM v2.28.0:
          ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
          show results of
          whoami
          ls -laF
          • I
            Ix @sdetweil
            whoami
            mirror@raspberrypi:~/MagicMirror $ whoami
            mirror
            and ls in MM directory:
            mirror@raspberrypi:~/MagicMirror $ ls -laF
            insgesamt 688
            drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
            drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
            -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
            drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
            -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
            drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
            drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
            -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
            -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
            -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
            -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
            drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
            drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
            -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
            drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
            -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
            drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
            -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
            drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
            -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
            drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
            -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
            -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
            -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
            drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
            -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
            drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
            -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
            -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
            -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
            -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
            -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
            -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
            drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
            drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
            -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
            drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
            drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
            drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
              sdetweil @Ix
              my only guess
              SO, lets try
              # using sudo here only to remove the root owned folder
              sudo rm -rf node_modules
              npm run install-mm
              • I
                Ix @sdetweil
                I deleted node_modules directory as recommended and after that, this is what happened:
                npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
                npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
                Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
                  sdetweil @Ix
                  @Ix wild… never seen this.
                  SO, i would use nvm and n to remove all the added node versions…
                  get back to whatever before…
                  exit the shell window and open again
                  verify still on the prior nodejs
                  then use n version_number
                  sudo n 20.9
                  verify that is correct node -v
                  the close shell and open again,
                  verify node
                  then try the npm run install-mm again
                  • I
                    Ix @sdetweil
                    done
                    done
                    sudo n 20.9
                    verify node
                    well, now there’s another problem:
                    mirror@raspberrypi:~ $ sudo n 20.9
                         copying : node/20.9.0
                    /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                       installed :  (with npm 10.1.0)
                    mirror@raspberrypi:~ $ node -v
                    -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                    Sry for German: it’s “no such file or directory”
                      sdetweil @Ix
                      @Ix do
                      which node
                      Then
                      sudo rm $(which node)
                      Then
                      hash -r
                      which node
                      and again
                      Then node -v
                      • I
                        Ix @sdetweil
                        okay done all that, node is completely gone from my machine. I guess, reinstalling it would be the next step?
                          sdetweil @Ix
                          @Ix rename the MagicMirror folder and run my install script
                          S I 2 Replies Last reply
                            @Ix then rename new out and old back in and do the npm run install-mm
                            • I
                              Ix @sdetweil
                              Tried that, but the script failed. I have attached the install.log
                              install starting  - Mon Aug  5 18:37:16 CEST 2024
                              installing on aarch64 processor system
                              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                             total        used        free      shared  buff/cache   available
                              Mem:            1849         228        1116          30         504        1527
                              Swap:           2047           0        2047
                              Updating packages ...
                              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists...
                              apt-get update  completed ok
                              Building dependency tree...
                              Reading state information...
                              pv is already the newest version (1.6.6-1).
                              apt-get upgrade  started
                              apt-get upgrade result =rc=0 Reading package lists...
                              Calculating upgrade...
                              Installing helper tools ...
                              build-essential is already the newest version (12.9).
                              curl is already the newest version (7.74.0-1.3+deb11u12).
                              git is already the newest version (1:2.30.2-1+deb11u2).
                              unzip is already the newest version (6.0-26+deb11u1).
                              wget is already the newest version (1.21-1+deb11u1).
                              node not installed, trying via apt-get
                              Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package nodejs:armv7l E: Unable to locate package npm:armv7l
                              npm not installed, trying via apt-get
                              npm installed now, install n
                              Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libnode72 : Conflicts: nodejs-legacy nodejs : Conflicts: npm E: Unable to correct problems, you have held broken packages.
                              installing on bullseye
                              node failed to execute, please check the error message and resolve before trying again
                              install aborted - Mon Aug  5 18:37:59 CEST 2024
                                sdetweil @Ix
                                @Ix do node -v
                                • I
                                  Ix @sdetweil
                                  @Ix do node -v
                                  bash: node: command not found
                                    sdetweil @Ix
                                    @Ix do
                                    which node
                                    Or
                                    Find /usr -type f -name node
                                    • I
                                      Ix @sdetweil
                                      @Ix do
                                      which node
                                      Or
                                      these commands don’t output anything.
                                        sdetweil @Ix
                                        @Ix well isn’t that interesting.
                                        do
                                        sudo apt update
                                        sudo apt install nodejs
                                        node -v
                                        • I
                                          Ix @sdetweil
                                          @sdetweil you’re so patient! Thank you!
                                          mirror@raspberrypi:~ $ sudo apt update
                                          Reading package lists... Done
                                          Building dependency tree... Done
                                          All packages are up to date.
                                          mirror@raspberrypi:~ $ sudo apt install node.js
                                          E: Unable to locate package node.js
                                          E: Couldn't find any package by glob 'node.js'
                                          rebooted beforehand
                                          • I
                                            Ix @sdetweil
                                            node -v
                                            ah snap, I made a small mistake here. I redid it without typo:
                                            mirror@raspberrypi:~ $ sudo apt install nodejs
                                            nodejs is already the newest version (18.17.1-deb-1nodesource1).
                                            somewhere in my OS must still remain some node debris…
                                            Edit: tried this:
                                            mirror@raspberrypi:~ $ sudo apt remove nodejs
                                            The following packages will be REMOVED:
                                              nodejs
                                            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                            After this operation, 177 MB disk space will be freed.
                                            Do you want to continue? [Y/n] y
                                            (Reading database ... 114411 files and directories currently installed.)
                                            Removing nodejs (18.17.1-deb-1nodesource1) ...
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_
                                            modules/yallist' not empty so not removed
                                            modules/write-file-atomic' not empty so not removed
                                            modules/wrap-ansi/node_modules/emoji-regex' not empty so not removed
                                            modules/wrap-ansi-cjs' not empty so not removed
                                            modules/which' not empty so not removed
                                            modules/walk-up-path' not empty so not removed
                                            modules/validate-npm-package-name' not empty so not removed
                                            modules/validate-npm-package-license' not empty so not removed
                                            modules/util-deprecate' not empty so not removed
                                            modules/unique-slug' not empty so not removed
                                            modules/unique-filename' not empty so not removed
                                            modules/tuf-js' not empty so not removed
                                            modules/treeverse' not empty so not removed
                                            modules/tiny-relative-date' not empty so not removed
                                            modules/text-table' not empty so not removed
                                            modules/tar/node_modules/fs-minipass/node_modules/minipass' not empty so not rem
                                            oved
                                            modules/ssri' not empty so not removed
                                            modules/spdx-expression-parse' not empty so not removed
                                            modules/spdx-exceptions' not empty so not removed
                                            modules/spdx-correct' not empty so not removed
                                            modules/socks' not empty so not removed
                                            modules/socks-proxy-agent' not empty so not removed
                                            modules/smart-buffer' not empty so not removed
                                            modules/sigstore' not empty so not removed
                                            modules/signal-exit' not empty so not removed
                                            modules/semver/internal' not empty so not removed
                                            modules/safer-buffer' not empty so not removed
                                            modules/retry' not empty so not removed
                                            modules/read' not empty so not removed
                                            modules/read-package-json-fast' not empty so not removed
                                            modules/read-cmd-shim' not empty so not removed
                                            modules/qrcode-terminal' not empty so not removed
                                            modules/promzard' not empty so not removed
                                            modules/promise-retry' not empty so not removed
                                            modules/promise-inflight' not empty so not removed
                                            modules/promise-call-limit' not empty so not removed
                                            modules/promise-all-reject-late' not empty so not removed
                                            modules/proc-log' not empty so not removed
                                            modules/postcss-selector-parser' not empty so not removed
                                            modules/path-scurry/dist' not empty so not removed
                                            modules/parse-conflict-json' not empty so not removed
                                            modules/pacote/lib/util' not empty so not removed
                                            modules/npm-user-validate' not empty so not removed
                                            modules/npm-registry-fetch' not empty so not removed
                                            modules/npm-profile' not empty so not removed
                                            modules/npm-pick-manifest' not empty so not removed
                                            modules/npm-packlist' not empty so not removed
                                            modules/npm-package-arg' not empty so not removed
                                            modules/npm-normalize-package-bin' not empty so not removed
                                            modules/npm-install-checks' not empty so not removed
                                            modules/npm-bundled' not empty so not removed
                                            modules/npm-audit-report' not empty so not removed
                                            modules/normalize-package-data' not empty so not removed
                                            modules/nopt' not empty so not removed
                                            modules/node-gyp/node_modules' not empty so not removed
                                            modules/node-gyp/lib' not empty so not removed
                                            modules/node-gyp/gyp/pylib' not empty so not removed
                                            modules/negotiator' not empty so not removed
                                            modules/mute-stream' not empty so not removed
                                            modules/ms' not empty so not removed
                                            modules/mkdirp' not empty so not removed
                                            modules/minizlib/node_modules/minipass' not empty so not removed
                                            modules/minipass-sized/node_modules/minipass' not empty so not removed
                                            modules/minipass-pipeline/node_modules/minipass' not empty so not removed
                                            modules/minipass-json-stream/node_modules/minipass' not empty so not removed
                                            modules/minipass-flush/node_modules/minipass' not empty so not removed
                                            modules/minipass-fetch' not empty so not removed
                                            modules/minipass-collect' not empty so not removed
                                            modules/minimatch/dist' not empty so not removed
                                            modules/make-fetch-happen' not empty so not removed
                                            modules/lru-cache' not empty so not removed
                                            modules/libnpmversion' not empty so not removed
                                            modules/libnpmteam' not empty so not removed
                                            modules/libnpmsearch' not empty so not removed
                                            modules/libnpmpublish' not empty so not removed
                                            modules/libnpmpack' not empty so not removed
                                            modules/libnpmorg' not empty so not removed
                                            modules/libnpmhook' not empty so not removed
                                            modules/libnpmfund' not empty so not removed
                                            modules/libnpmexec' not empty so not removed
                                            modules/libnpmdiff' not empty so not removed
                                            modules/libnpmaccess' not empty so not removed
                                            modules/just-diff' not empty so not removed
                                            modules/just-diff-apply' not empty so not removed
                                            modules/jsonparse' not empty so not removed
                                            modules/json-stringify-nice' not empty so not removed
                                            modules/json-parse-even-better-errors' not empty so not removed
                                            modules/jackspeak/dist' not empty so not removed
                                            modules/isexe' not empty so not removed
                                            modules/is-lambda' not empty so not removed
                                            modules/is-core-module' not empty so not removed
                                            modules/init-package-json' not empty so not removed
                                            modules/ini' not empty so not removed
                                            modules/ignore-walk' not empty so not removed
                                            modules/iconv-lite' not empty so not removed
                                            modules/https-proxy-agent' not empty so not removed
                                            modules/http-proxy-agent' not empty so not removed
                                            modules/http-cache-semantics' not empty so not removed
                                            modules/hosted-git-info' not empty so not removed
                                            modules/graceful-fs' not empty so not removed
                                            modules/glob/dist' not empty so not removed
                                            modules/function-bind' not empty so not removed
                                            modules/fs-minipass' not empty so not removed
                                            modules/foreground-child' not empty so not removed
                                            modules/fastest-levenshtein' not empty so not removed
                                            modules/err-code' not empty so not removed
                                            modules/encoding' not empty so not removed
                                            modules/diff/lib/patch' not empty so not removed
                                            modules/debug/node_modules/ms' not empty so not removed
                                            modules/cssesc' not empty so not removed
                                            modules/cross-spawn/node_modules/which' not empty so not removed
                                            modules/common-ancestor-path' not empty so not removed
                                            modules/color-name' not empty so not removed
                                            modules/color-convert' not empty so not removed
                                            modules/cmd-shim' not empty so not removed
                                            modules/cidr-regex' not empty so not removed
                                            modules/ci-info' not empty so not removed
                                            modules/chownr' not empty so not removed
                                            modules/chalk/source' not empty so not removed
                                            modules/cacache' not empty so not removed
                                            modules/brace-expansion' not empty so not removed
                                            modules/bin-links' not empty so not removed
                                            modules/balanced-match' not empty so not removed
                                            modules/archy' not empty so not removed
                                            modules/aproba' not empty so not removed
                                            modules/agent-base/dist' not empty so not removed
                                            modules/abbrev' not empty so not removed
                                            modules/@tufjs/models' not empty so not removed
                                            modules/@tufjs/canonical-json' not empty so not removed
                                            modules/@sigstore/protobuf-specs/dist/__generated__/google/protobuf' not empty s
                                            o not removed
                                            modules/@pkgjs/parseargs' not empty so not removed
                                            modules/@npmcli/run-script' not empty so not removed
                                            modules/@npmcli/query' not empty so not removed
                                            modules/@npmcli/promise-spawn' not empty so not removed
                                            modules/@npmcli/package-json' not empty so not removed
                                            modules/@npmcli/name-from-folder' not empty so not removed
                                            modules/@npmcli/metavuln-calculator' not empty so not removed
                                            modules/@npmcli/map-workspaces' not empty so not removed
                                            modules/@npmcli/installed-package-contents' not empty so not removed
                                            modules/@npmcli/git' not empty so not removed
                                            modules/@npmcli/fs/lib/cp' not empty so not removed
                                            modules/@npmcli/config/lib' not empty so not removed
                                            modules/@npmcli/arborist/lib' not empty so not removed
                                            modules/@isaacs/string-locale-compare' not empty so not removed
                                            modules/@isaacs/cliui/node_modules/emoji-regex' not empty so not removed
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/m
                                            an1' not empty so not removed
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/u
                                            tils' not empty so not removed
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/c
                                            ommands' not empty so not removed
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/
                                            output/configuring-npm' not empty so not removed
                                            output/commands' not empty so not removed
                                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin'
                                            Processing triggers for man-db (2.9.4-2) ...
