    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 7.3k Views 2 Watching
      sdetweil @Ix
      @Ix ONE… NEVER EVER use sudo for MM commands, EVER…
      once you do that then you HAVE to use SUDO for a lot of things you don’t want to give root permissions
      note node and npm are not MM commands
      SO, you had to upgrade node and npm for this release BEFORE doing the upgrade
      see https://forum.magicmirror.builders/topic/18836/v2-28-0
      OR, you could have run the upgrade command from my scripts repo
      see https://github.com/sdetweil/MagicMirror_scripts
      for node version, check (not what nvm thinks)
      node -v
      my scripts use the tool n, which is nvm written in javascript…
      • I Offline
        Ix @sdetweil
        first: thanks for answering so fast!
        node -v gives this:
        mirror@raspberrypi:~ $ node -v
        v20.16.0
        this is also the version I installed via n
        nevertheless, the wrong version is recognized when trying npm i
          sdetweil @Ix
          @Ix how about npm -v
          • I Offline
            Ix @sdetweil
            mirror@raspberrypi:~ $ npm -v
            10.8.1
              sdetweil @Ix
              @Ix ok, can u give the output of
              npm run install-mm
              now
              • I Offline
                Ix @sdetweil
                @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
                npm run install-mm
                mirror@raspberrypi:~/MagicMirror $ npm run install-mm
                > magicmirror@2.28.0 install-mm
                > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                npm error code EBADENGINE
                npm error engine Unsupported engine
                npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
                npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
                npm error notsup Required: {"node":">=20"}
                npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
                npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
                  sdetweil @Ix
                  @Ix said in Error EBADENGINE when installing MM v2.28.0:
                  ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
                  show results of
                  whoami
                  ls -laF
                  • I Offline
                    Ix @sdetweil
                    whoami
                    mirror@raspberrypi:~/MagicMirror $ whoami
                    mirror
                    and ls in MM directory:
                    mirror@raspberrypi:~/MagicMirror $ ls -laF
                    insgesamt 688
                    drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
                    drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
                    -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
                    drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
                    -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
                    drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
                    drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
                    -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
                    -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
                    -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
                    -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
                    drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
                    drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
                    -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
                    drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
                    -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
                    drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
                    -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
                    drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
                    -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
                    drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
                    -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
                    -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
                    -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
                    drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
                    -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
                    drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
                    -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
                    -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
                    -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
                    -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
                    -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
                    -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
                    drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
                    drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
                    -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
                    drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
                    drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
                    drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
                      sdetweil @Ix
                      my only guess
                      SO, lets try
                      # using sudo here only to remove the root owned folder
                      sudo rm -rf node_modules
                      npm run install-mm
                      • I Offline
                        Ix @sdetweil
                        I deleted node_modules directory as recommended and after that, this is what happened:
                        npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
                        npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
                        Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
