    Error EBADENGINE when installing MM v2.28.0
    28 Posts 2 Posters 11.0k Views 2 Watching
    • I
      Ix @sdetweil
      @sdetweil said in Error EBADENGINE when installing MM v2.28.0:
      npm run install-mm
      mirror@raspberrypi:~/MagicMirror $ npm run install-mm
      > magicmirror@2.28.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
      npm error notsup Required: {"node":">=20"}
      npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
      npm error A complete log of this run can be found in: /root/.npm/_logs/2024-08-04T17_53_51_013Z-debug-0.log
        sdetweil @Ix
        @Ix said in Error EBADENGINE when installing MM v2.28.0:
        ok, it thinks you are running npm as root… probably cause of some sudo somwhere…
        show results of
        whoami
        ls -laF
        I 1 Reply Last reply
        • I
          Ix @sdetweil
          whoami
          mirror@raspberrypi:~/MagicMirror $ whoami
          mirror
          and ls in MM directory:
          mirror@raspberrypi:~/MagicMirror $ ls -laF
          insgesamt 688
          drwxr-xr-x  18 mirror mirror   4096  4. Aug 17:48 ./
          drwxr-xr-x  26 mirror mirror   4096  3. Jul 09:30 ../
          -rw-r--r--   1 mirror mirror  83743  4. Aug 17:48 CHANGELOG.md
          drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 clientonly/
          -rw-r--r--   1 mirror mirror   1617  3. Apr 17:11 Collaboration.md
          drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 config/
          drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 css/
          -rw-r--r--   1 mirror mirror  10244  2. Jul 21:56 .DS_Store
          -rw-r--r--   1 mirror mirror    238  2. Okt 2023  .editorconfig
          -rw-r--r--   1 mirror mirror     27  3. Apr 17:11 .eslintignore
          -rw-r--r--   1 mirror mirror   3020  3. Apr 17:11 .eslintrc.json
          drwxr-xr-x   3 mirror mirror   4096  4. Aug 17:48 fonts/
          drwxr-xr-x   8 mirror mirror   4096  4. Aug 20:28 .git/
          -rw-r--r--   1 mirror mirror   1034  2. Okt 2023  .gitattributes
          drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .github/
          -rw-r--r--   1 mirror mirror   1140  3. Apr 17:11 .gitignore
          drwxr-xr-x   3 mirror mirror   4096  3. Apr 17:11 .husky/
          -rw-r--r--   1 mirror mirror   3103  2. Okt 2023  index.html
          drwxr-xr-x   2 mirror mirror   4096  4. Aug 19:18 installers/
          -rw-r--r--   1 mirror mirror   1096  2. Okt 2023  jest.config.js
          drwxr-xr-x   2 mirror mirror   4096  4. Aug 17:48 js/
          -rw-r--r--   1 mirror mirror    264  2. Okt 2023  jsconfig.json
          -rw-r--r--   1 mirror mirror   1098  3. Apr 17:11 LICENSE.md
          -rw-r--r--   1 mirror mirror   6947  3. Apr 17:11 mm2.png
          drwxr-xr-x  13 mirror mirror   4096  3. M?r 11:49 modules/
          -rw-r--r--   1 mirror mirror   1130  2. Okt 2023  module-types.ts
          drwxr-xr-x 414 root   root    28672  3. Apr 17:16 node_modules/
          -rw-r--r--   1 mirror mirror     48  3. Apr 17:11 .npmrc
          -rw-r--r--   1 mirror mirror   3694  4. Aug 17:48 package.json
          -rw-r--r--   1 mirror mirror 414176  4. Aug 17:48 package-lock.json
          -rw-r--r--   1 mirror mirror     96  3. Apr 17:11 .prettierignore
          -rw-r--r--   1 mirror mirror     29  2. Okt 2023  .prettierrc.json
          -rw-r--r--   1 mirror mirror   3279  3. Apr 17:11 README.md
          drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 serveronly/
          drwxr-xr-x   2 mirror mirror   4096  2. Okt 2023  splashscreen/
          -rw-r--r--   1 mirror mirror    126  2. Okt 2023  .stylelintrc.json
          drwxr-xr-x   8 mirror mirror   4096  4. Jan 2024  tests/
          drwxr-xr-x   2 mirror mirror   4096  3. Apr 17:11 translations/
          drwxr-xr-x   4 mirror mirror   4096  4. Aug 17:48 vendor/
            sdetweil @Ix
            my only guess
            SO, lets try
            # using sudo here only to remove the root owned folder
            sudo rm -rf node_modules
            npm run install-mm
            • I
              Ix @sdetweil
              I deleted node_modules directory as recommended and after that, this is what happened:
              npm error notsup Actual:   {"npm":"10.8.2","node":"v18.18.0"}
              npm error A complete log of this run can be found in: /home/mirror/.npm/_logs/2024-08-04T20_08_34_045Z-debug-0.log
              Now it says it’s running on node v18.18.0 instead of v18.17.1 but still not v20.16 which is installed. I don’t get it at all…
                sdetweil @Ix
                @Ix wild… never seen this.
                SO, i would use nvm and n to remove all the added node versions…
                get back to whatever before…
                exit the shell window and open again
                verify still on the prior nodejs
                then use n version_number
                sudo n 20.9
                verify that is correct node -v
                the close shell and open again,
                verify node
                then try the npm run install-mm again
                • I
                  Ix @sdetweil
                  done
                  done
                  sudo n 20.9
                  verify node
                  well, now there’s another problem:
                  mirror@raspberrypi:~ $ sudo n 20.9
                       copying : node/20.9.0
                  /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                     installed :  (with npm 10.1.0)
                  mirror@raspberrypi:~ $ node -v
                  -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                  Sry for German: it’s “no such file or directory”
                    sdetweil @Ix
                    @Ix do
                    which node
                    Then
                    sudo rm $(which node)
                    Then
                    hash -r
                    which node
                    and again
                    Then node -v
                    • I
                      Ix @sdetweil
                      okay done all that, node is completely gone from my machine. I guess, reinstalling it would be the next step?
                        sdetweil @Ix
                        @Ix rename the MagicMirror folder and run my install script
                        S I 2 Replies Last reply
                          @Ix then rename new out and old back in and do the npm run install-mm
                          • I
                            Ix @sdetweil
                            Tried that, but the script failed. I have attached the install.log
                            install starting  - Mon Aug  5 18:37:16 CEST 2024
                            installing on aarch64 processor system
                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                           total        used        free      shared  buff/cache   available
                            Mem:            1849         228        1116          30         504        1527
                            Swap:           2047           0        2047
                            Updating packages ...
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists...
                            apt-get update  completed ok
                            Building dependency tree...
                            Reading state information...
                            pv is already the newest version (1.6.6-1).
                            apt-get upgrade  started
                            apt-get upgrade result =rc=0 Reading package lists...
                            Calculating upgrade...
                            Installing helper tools ...
                            build-essential is already the newest version (12.9).
                            curl is already the newest version (7.74.0-1.3+deb11u12).
                            git is already the newest version (1:2.30.2-1+deb11u2).
                            unzip is already the newest version (6.0-26+deb11u1).
                            wget is already the newest version (1.21-1+deb11u1).
                            node not installed, trying via apt-get
                            Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package nodejs:armv7l E: Unable to locate package npm:armv7l
                            npm not installed, trying via apt-get
                            npm installed now, install n
                            Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libnode72 : Conflicts: nodejs-legacy nodejs : Conflicts: npm E: Unable to correct problems, you have held broken packages.
                            installing on bullseye
                            node failed to execute, please check the error message and resolve before trying again
                            install aborted - Mon Aug  5 18:37:59 CEST 2024
                              sdetweil @Ix
                              @Ix do node -v
                              • I
                                Ix @sdetweil
                                @Ix do node -v
                                bash: node: command not found
                                  sdetweil @Ix
                                  @Ix do
                                  which node
                                  Or
                                  Find /usr -type f -name node
                                  • I
                                    Ix @sdetweil
                                    @Ix do
                                    which node
                                    Or
                                    these commands don’t output anything.
                                      sdetweil @Ix
                                      @Ix well isn’t that interesting.
                                      do
                                      sudo apt update
                                      sudo apt install nodejs
                                      node -v
                                      • I
                                        Ix @sdetweil
                                        @sdetweil you’re so patient! Thank you!
                                        mirror@raspberrypi:~ $ sudo apt update
                                        Reading package lists... Done
                                        Building dependency tree... Done
                                        All packages are up to date.
                                        mirror@raspberrypi:~ $ sudo apt install node.js
                                        E: Unable to locate package node.js
                                        E: Couldn't find any package by glob 'node.js'
                                        rebooted beforehand
                                        • I
                                          Ix @sdetweil
                                          node -v
                                          ah snap, I made a small mistake here. I redid it without typo:
                                          mirror@raspberrypi:~ $ sudo apt install nodejs
                                          nodejs is already the newest version (18.17.1-deb-1nodesource1).
                                          somewhere in my OS must still remain some node debris…
                                          Edit: tried this:
                                          mirror@raspberrypi:~ $ sudo apt remove nodejs
                                          The following packages will be REMOVED:
                                            nodejs
                                          0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                          After this operation, 177 MB disk space will be freed.
                                          Do you want to continue? [Y/n] y
                                          (Reading database ... 114411 files and directories currently installed.)
                                          Removing nodejs (18.17.1-deb-1nodesource1) ...
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_
                                          modules/yallist' not empty so not removed
                                          modules/write-file-atomic' not empty so not removed
                                          modules/wrap-ansi/node_modules/emoji-regex' not empty so not removed
                                          modules/wrap-ansi-cjs' not empty so not removed
                                          modules/which' not empty so not removed
                                          modules/walk-up-path' not empty so not removed
                                          modules/validate-npm-package-name' not empty so not removed
                                          modules/validate-npm-package-license' not empty so not removed
                                          modules/util-deprecate' not empty so not removed
                                          modules/unique-slug' not empty so not removed
                                          modules/unique-filename' not empty so not removed
                                          modules/tuf-js' not empty so not removed
                                          modules/treeverse' not empty so not removed
                                          modules/tiny-relative-date' not empty so not removed
                                          modules/text-table' not empty so not removed
                                          modules/tar/node_modules/fs-minipass/node_modules/minipass' not empty so not rem
                                          oved
                                          modules/ssri' not empty so not removed
                                          modules/spdx-expression-parse' not empty so not removed
                                          modules/spdx-exceptions' not empty so not removed
                                          modules/spdx-correct' not empty so not removed
                                          modules/socks' not empty so not removed
                                          modules/socks-proxy-agent' not empty so not removed
                                          modules/smart-buffer' not empty so not removed
                                          modules/sigstore' not empty so not removed
                                          modules/signal-exit' not empty so not removed
                                          modules/semver/internal' not empty so not removed
                                          modules/safer-buffer' not empty so not removed
                                          modules/retry' not empty so not removed
                                          modules/read' not empty so not removed
                                          modules/read-package-json-fast' not empty so not removed
                                          modules/read-cmd-shim' not empty so not removed
                                          modules/qrcode-terminal' not empty so not removed
                                          modules/promzard' not empty so not removed
                                          modules/promise-retry' not empty so not removed
                                          modules/promise-inflight' not empty so not removed
                                          modules/promise-call-limit' not empty so not removed
                                          modules/promise-all-reject-late' not empty so not removed
                                          modules/proc-log' not empty so not removed
                                          modules/postcss-selector-parser' not empty so not removed
                                          modules/path-scurry/dist' not empty so not removed
                                          modules/parse-conflict-json' not empty so not removed
                                          modules/pacote/lib/util' not empty so not removed
                                          modules/npm-user-validate' not empty so not removed
                                          modules/npm-registry-fetch' not empty so not removed
                                          modules/npm-profile' not empty so not removed
                                          modules/npm-pick-manifest' not empty so not removed
                                          modules/npm-packlist' not empty so not removed
                                          modules/npm-package-arg' not empty so not removed
                                          modules/npm-normalize-package-bin' not empty so not removed
                                          modules/npm-install-checks' not empty so not removed
                                          modules/npm-bundled' not empty so not removed
                                          modules/npm-audit-report' not empty so not removed
                                          modules/normalize-package-data' not empty so not removed
                                          modules/nopt' not empty so not removed
                                          modules/node-gyp/node_modules' not empty so not removed
                                          modules/node-gyp/lib' not empty so not removed
                                          modules/node-gyp/gyp/pylib' not empty so not removed
                                          modules/negotiator' not empty so not removed
                                          modules/mute-stream' not empty so not removed
                                          modules/ms' not empty so not removed
                                          modules/mkdirp' not empty so not removed
                                          modules/minizlib/node_modules/minipass' not empty so not removed
                                          modules/minipass-sized/node_modules/minipass' not empty so not removed
                                          modules/minipass-pipeline/node_modules/minipass' not empty so not removed
                                          modules/minipass-json-stream/node_modules/minipass' not empty so not removed
                                          modules/minipass-flush/node_modules/minipass' not empty so not removed
                                          modules/minipass-fetch' not empty so not removed
                                          modules/minipass-collect' not empty so not removed
                                          modules/minimatch/dist' not empty so not removed
                                          modules/make-fetch-happen' not empty so not removed
                                          modules/lru-cache' not empty so not removed
                                          modules/libnpmversion' not empty so not removed
                                          modules/libnpmteam' not empty so not removed
                                          modules/libnpmsearch' not empty so not removed
                                          modules/libnpmpublish' not empty so not removed
                                          modules/libnpmpack' not empty so not removed
                                          modules/libnpmorg' not empty so not removed
                                          modules/libnpmhook' not empty so not removed
                                          modules/libnpmfund' not empty so not removed
                                          modules/libnpmexec' not empty so not removed
                                          modules/libnpmdiff' not empty so not removed
                                          modules/libnpmaccess' not empty so not removed
                                          modules/just-diff' not empty so not removed
                                          modules/just-diff-apply' not empty so not removed
                                          modules/jsonparse' not empty so not removed
                                          modules/json-stringify-nice' not empty so not removed
                                          modules/json-parse-even-better-errors' not empty so not removed
                                          modules/jackspeak/dist' not empty so not removed
                                          modules/isexe' not empty so not removed
                                          modules/is-lambda' not empty so not removed
                                          modules/is-core-module' not empty so not removed
                                          modules/init-package-json' not empty so not removed
                                          modules/ini' not empty so not removed
                                          modules/ignore-walk' not empty so not removed
                                          modules/iconv-lite' not empty so not removed
                                          modules/https-proxy-agent' not empty so not removed
                                          modules/http-proxy-agent' not empty so not removed
                                          modules/http-cache-semantics' not empty so not removed
                                          modules/hosted-git-info' not empty so not removed
                                          modules/graceful-fs' not empty so not removed
                                          modules/glob/dist' not empty so not removed
                                          modules/function-bind' not empty so not removed
                                          modules/fs-minipass' not empty so not removed
                                          modules/foreground-child' not empty so not removed
                                          modules/fastest-levenshtein' not empty so not removed
                                          modules/err-code' not empty so not removed
                                          modules/encoding' not empty so not removed
                                          modules/diff/lib/patch' not empty so not removed
                                          modules/debug/node_modules/ms' not empty so not removed
                                          modules/cssesc' not empty so not removed
                                          modules/cross-spawn/node_modules/which' not empty so not removed
                                          modules/common-ancestor-path' not empty so not removed
                                          modules/color-name' not empty so not removed
                                          modules/color-convert' not empty so not removed
                                          modules/cmd-shim' not empty so not removed
                                          modules/cidr-regex' not empty so not removed
                                          modules/ci-info' not empty so not removed
                                          modules/chownr' not empty so not removed
                                          modules/chalk/source' not empty so not removed
                                          modules/cacache' not empty so not removed
                                          modules/brace-expansion' not empty so not removed
                                          modules/bin-links' not empty so not removed
                                          modules/balanced-match' not empty so not removed
                                          modules/archy' not empty so not removed
                                          modules/aproba' not empty so not removed
                                          modules/agent-base/dist' not empty so not removed
                                          modules/abbrev' not empty so not removed
                                          modules/@tufjs/models' not empty so not removed
                                          modules/@tufjs/canonical-json' not empty so not removed
                                          modules/@sigstore/protobuf-specs/dist/__generated__/google/protobuf' not empty s
                                          o not removed
                                          modules/@pkgjs/parseargs' not empty so not removed
                                          modules/@npmcli/run-script' not empty so not removed
                                          modules/@npmcli/query' not empty so not removed
                                          modules/@npmcli/promise-spawn' not empty so not removed
                                          modules/@npmcli/package-json' not empty so not removed
                                          modules/@npmcli/name-from-folder' not empty so not removed
                                          modules/@npmcli/metavuln-calculator' not empty so not removed
                                          modules/@npmcli/map-workspaces' not empty so not removed
                                          modules/@npmcli/installed-package-contents' not empty so not removed
                                          modules/@npmcli/git' not empty so not removed
                                          modules/@npmcli/fs/lib/cp' not empty so not removed
                                          modules/@npmcli/config/lib' not empty so not removed
                                          modules/@npmcli/arborist/lib' not empty so not removed
                                          modules/@isaacs/string-locale-compare' not empty so not removed
                                          modules/@isaacs/cliui/node_modules/emoji-regex' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/m
                                          an1' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/u
                                          tils' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/c
                                          ommands' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/
                                          output/configuring-npm' not empty so not removed
                                          output/commands' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin'
                                          Processing triggers for man-db (2.9.4-2) ...
                                            sdetweil @Ix
                                            @Ix do
                                            hash -r
                                            which node
                                            which npm
                                            if they respond then that is the path location of each program
