    Top 5 unseen modules
    18 Posts 5 Posters 6.5k Views 5 Watching
      sdetweil @brentmatthews
      @brentmatthews motion detection is easy, there are multiple ways
      pir - heat
      mwave - actual motion
      camera - change in viewed content
      then you have the screen device technology, in the US the energy-star standards implemented to save energy, require monitors to turn off after 15 minutes of no change in input. period.
      AND to WARN the ‘user’ of this impending power off. so, you turn off the hdmi port, and the monitor puts ip an ugly NO INPUT screen.
      now some of the compensation for that is a newer technology, call consumer electronics control, CEC. which provides smarts inside the monitor to receive commands over the hdmi port as well as video signal. turn off, turn on. BUT the hdmi port implementation needs to support that too.
      pi4 is the first to support CEC commands.
      then the module providing motion detection would need to support CEC as well.
      none of my monitors support CEC , all put up the ugly NO INPUT screen. but i don’t want the LIGHT, so i can only hide all the modules. this is an 80% reduction in brightness. it will have to do
      • BKeyportB
        BKeyport Module Developer @brentmatthews
        @brentmatthews
        I have three:
        Built in Calendar module - While it’s normally a display module, I use it in the background to handle the calendar retrieval for MMM-CalendarExt3 (Day mode), MMM-CalendarExt3Agenda (Agenda), and MMM-Multimonth (My own module for month mode because I didn’t like MMM-CX3’s month mode)
        MMM-CommandToNotification - Enables display of various features, including data for an non-published module I wrote to handle display of my local weather data from my weather station.
        MMM-NotificationToCommand - Much like the previous - it will take a notification and issue a command to the system - I use it to adjust a set of LEDs I have rigged in to match the mode of my mirror.
        J 1 Reply Last reply
          juli2709 @BKeyport
          o@BKeyport said in Top 5 unseen modules:
          @brentmatthews
          I have three:
          How did you do that? Can you support me?
            sdetweil @juli2709
            @juli2709 just comment out the
            position:
            setting for the default calendar module
            BKeyportB 1 Reply Last reply
            • BKeyportB
              @juli2709
              two slashes before whatever you want to comment (//):
              			module: "calendar", // Built in
              			//position: "top_center",  // Currently hidden
              Or, simply don’t include the position item.
              As a side note, if you want to comment out more than one line in the config, you can use the alternate syntax (/* comment */):
              /*	IRS Dropped		{
              						url: "webcal://www.tax.gov/calendar/employer/calendar.ics",
              						symbol: "dollar-sign",
              						color: green,
              this will work with any module.
                juli2709 @BKeyport
                // Currently hidden
                Thank you! Actually so simple! :-)
                • BKeyportB
                  BKeyport Module Developer @juli2709
                  @juli2709 most everything on the config is.
                  • L
                    lxne Project Sponsor
                    Two modules…
                    My MagicMirror is running on an OLED display, so I am using MMM-MagicMover and MMM-BurnIn to prevent screen damage.
                    and a complete suite…
                    MMM-GoogleAssistant and its components (Pages, Volume, Screen, Pir, Keyboard, TelegramBot, …) – priceless.
                      brentmatthews @brentmatthews
                      @brentmatthews Hi Sam,
                      I seem to be missing something with KeyBindings as the arrow keys are not making the pages change. Would you mind advising if you have the time.
                      			module: "MMM-Carousel",
                      			disabled: false,
                            			position: "bottom_bar", // Required only for navigation controls
                              			transitionInterval: 0, //20000,
                                      		showPageIndicators: true,
                                      		showPageControls: true,
                              			ignoreModules: ['alert', 'updatenotification', 'MMM-KeyBindings'],
                      				mode: "slides",
                              			slides: {
                                				main: ['clock', 'MMM-OpenWeatherForecast', 'MMM-WOTD', 'MMM-BackgroundSlideshow'],
                                				"Slide 1": ['clock', 'MMM-OpenWeatherForecast', 'MMM-MyCalendar', 'MMM-TomTomCalculateRouteTraffic', 'MMM-MyWastePickup', 'MMM-BackgroundSlideshow'],
                      				keyBindings: {
                      					enabled: true,
                      					map: {
                      						NextSlide: "ArrowRight",
                      						PrevSlide: "ArrowLeft",
                      					mode: "DEFAULT"
                        @brentmatthews you have to use the MMM-Keybindings module for the actual keypress
                        Integration with MMM-KeyBindings
                          brentmatthews @sdetweil
                          @sdetweil so I would put this bit as a stand alone module just with no position.
                              module: 'MMM-KeyBindings',
                                  evdev: { enabled: false },
                                  enableKeyboard: true,
                            @brentmatthews sorry, I don’t know… give it a try
                            I don’t know the workings of most modules…
                            I can help with getting the config data into the right places, or detect when config isn’t specified right…
