    Large Numbers
    11 Posts 4 Posters 3.1k Views 5 Watching
    • N Offline
      NotMyCircus @sdetweil
      @sdetweil I am trying out MMM-CalendarExt3 at the moment, but I am not married to anything, yet. I am open to any suggestions to get that layout.
        sdetweil @NotMyCircus
        @NotMyCircus Ok, the module provides a LOT of customization thru css
        see the file he provides… in the module folder
        see the link below in my signature on using css…
        all your css overrides will go in css/custom.css
        I think its doable, but you are on the bleeding edge of this kind of customization.
        he already has a style that highlights the current day
        • N Offline
          NotMyCircus
          Thanks! Sounds like this will be a fun project, then. I’ll dig into the module files and see what I can tweak with css changes.
            MMRIZE
            You can get a hint from this thread.
            https://forum.magicmirror.builders/topic/18069/multiple-modules-in-a-region?page=1
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              NotMyCircus @MMRIZE
              @MMRIZE That is an excellent thread! I will read through that and see if I can figure out how to duplicate the results, and then adjust to what I want. The first question that comes to mind, and this may be a really dumb question, but would it make more sense to modify the EXT3 module rather than making so many changes in the css?
              M S 2 Replies Last reply Reply Quote 0
                MMRIZE @NotMyCircus
                @NotMyCircus said in Large Numbers:
                It is up to you. But when you modify the source code, you may have the problem on the next update of the module.
                  @NotMyCircus i think everything you want is all about style and placement, not about data
                  have you made any progress?
                  in the css header for this module, make the cell
                  lines disappear
                  hide the current week number
                  set the weekday format to narrow, to get the one letter
                  set the date format to just the day number
                  i think you can hide the footer.
                  override the cell background color, set its opacity to 0, transparent
                  override the day number color to .today
                  may need to customize that for the circle too.
                  then you can set the background of the calendar grid div to your blue gradient
                    @NotMyCircus
                    as an example with css changes I did this in about 20 minutes
                    config
                            module: "MMM-CalendarExt3",
                            position: "middle_center",
                            disabled: false,
                              mode: "week",
                              weeksInView:2,
                              firstDayOfWeek: "1",
                              fontSize:'30px',
                              headerWeekDayOptions: {
                                weekday: 'narrow'  // this makes the weekday 1 characater wide
                    css
                    .CX3 .cw {
                    	display: none !important;
                    .CX3.bodice {
                        background:linear-gradient( blue,lightblue);
                    .CX3 .cell {
                    	background: transparent;
                    	border: transparent;
                    .CX3 .cell.today {
                    .CX3 .cellDate  {
                      margin-right: 20px;
                    .CX3  .cellHeader .cellDate span.dateParts.month.seq_0  {
                        display: none;
                    • W Offline
                      wswenson @NotMyCircus
                      @NotMyCircus
                      Made some changes to custom.css file working towards that style…
                      .CX3 .cw {
                      .CX3.bodice {
                          background-image: linear-gradient(to top right, #22c1c3, #176561, #131813);
                      .CX3 .cell {
                          display: flex; /* Use flexbox for layout */
                          flex-direction: column; /* Stacks elements vertically */
                          align-items: center; /* Centers items horizontally */
                          justify-content: flex-start; /* Ensures content starts at the top */
                          padding: 0.5em; /* Adds space inside the cell */
                          text-align: center; /* Centers text content */
                          overflow: hidden; /* Ensures no content overlaps outside the cell */
                      .CX3 .cell.today {
                      .CX3 .cell.today .cellDate {
                          font-size: 4em; /* Adjust the size of the date text */
                          line-height: 1; /* Avoids extra spacing */
                          text-align: center; /* Centers the text within the circle */
                          width: 1.5em; /* Set equal width and height */
                          height: 1.5em; /* Matches width to create a circle */
                          display: flex; /* Use flexbox to align text */
                          justify-content: center; /* Centers text horizontally */
                          align-items: center; /* Centers text vertically */
                          background-color: red; /* Background color for the circle */
                          color: #ffffff; /* Text color */
                          border: 2px solid #e76f51; /* Optional border for the circle */
                          border-radius: 50%; /* Makes the box a circle */
                          margin: auto; /* Ensures proper alignment within the cell */
                      .CX3 .cellDate {
                          font-size: 4em; /* Adjust font size for the date */
                          text-align: center;
                          margin-bottom: 1em; /* Adds space below the date */
                          width: auto; /* Removes fixed width */
                          height: auto; /* Removes fixed height */
                      .CX3 .cellHeader {
                          display: flex;
                          text-align: center;
                          display: none;
                      /* Ensures the eventContainer is placed below the date numbers */
                      .CX3 .eventContainer {
                          margin-top: 1em; /* Adds space above the eventContainer */
                      	top: 74px;
                          width: 100%; /* Ensures it spans the cell width */
                          text-align: left; /* Aligns event text to the left, adjust if needed */
                          word-wrap: break-word; /* Prevents event text from overflowing */
                          //display: block; /* Ensures it behaves as a block element */
                          position: relative; /* Ensures it respects the flow of the document */
