    Unable to install MagicMirror
    10 Posts 3 Posters 945 Views 3 Watching
      MarcLandis Module Developer @Klinge
      @Klinge your vlc installation is broken. This causes the installation of MagicMirror to fail.
      Try the following:
      sudo apt remove vlc
      sudo apt install vlc
        sdetweil @Klinge
        @Klinge MagicMirror will not run on buster, you must upgrade to one of the newer OS releases
        I changed the test for this due to another bug , and it appears to have failed the test
        I have just pushed a fix so this long process should not happen again
        it will abort if you try to install on buster
          sdetweil @MarcLandis
          @MarcLandis nah. the nodejs code we need isn’t provided for buster anymore
            MarcLandis Module Developer @sdetweil
            @sdetweil duh - I didn’t see that I can scroll down the error message
            • K Offline
              Klinge @sdetweil
              @sdetweil Ok, now I see the message when I start your script.
              But I think I updated my OS as you can see. It seems it is actual.
              pi@raspberrypi:~ $ sudo apt update
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:3 https://deb.nodesource.com/node_10.x buster InRelease
              Paketlisten werden gelesen... Fertig
              Abhängigkeitsbaum wird aufgebaut.
              Statusinformationen werden eingelesen.... Fertig
              Alle Pakete sind aktuell.
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $ sudo apt full-upgrade
              Paketaktualisierung (Upgrade) wird berechnet... Fertig
              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
              pi@raspberrypi:~ $ sudo apt-get update
              But it is still buster. So I have to install a complete new image on the card?
                @Klinge yes you have to put a new image on the card.
                • K Offline
                  Klinge @MarcLandis
                  @MarcLandis @sdetweil Ok, then I have to do it. Thank you for your help :-)
                    sdetweil @Klinge
                    @Klinge did you get this running?
                    • K Offline
                      Klinge @sdetweil
                      @sdetweil I have installed a completely new system. The current raspbian OS and of course the MM. The MM itself is running. At the moment I’m fighting with a news module and with the GoogleAssistant from @bugsounet. I am optimistic that I will win the battle. Otherwise, I’m looking for advice from this great community ;-) But first I’m going on holiday with my family tomorrow :-) Many thanks for your help
                      • K Klinge has marked this topic as solved on
