'DISPLAY' is not recognized... on Windows 10
9 Posts 3 Posters 1.0k Views 2 Watching
    dj94506
    This is my first stab at installing MagicMirror2. I’m on Windows 10. The installation was a straightforward, only default options, i.e., a click-click-click process that seems to have done its thing.
    Then, this happened:
    $ npm start
    magicmirror@2.25.0 start
    ‘DISPLAY’ is not recognized as an internal or external command,
    operable program or batch file.
    I’m aware of the DISPLAY:0 game in the UNIX world; however, I haven’t encountered it in the Windows. Any suggestions for a semi-skilled newbie would be deeply appreciated.
    Thanks in advance.
    S 1 Reply Last reply Nov 16, 2023, 12:18 PM Reply Quote 0
      sdetweil @swvalenti
      @swvalenti so the
      npm run install-mm
      was not done or not successful
      S 1 Reply Last reply Sep 17, 2024, 11:58 AM Reply Quote 0
        sdetweil @dj94506
        @dj94506 you did not follow all the instructions
        S 1 Reply Last reply Sep 17, 2024, 12:34 AM Reply Quote 0
          swvalenti Project Sponsor @sdetweil
          Upgraded on windows 10 using sam script. Changed the package.json but I am getting the below error. Any ideas
          > magicmirror@2.28.0 start
          > .\node_modules\.bin\electron js\electron.js
          The system cannot find the path specified.
          Below are the start lines per documentation
          "start": ".\\node_modules\\.bin\\electron js\\electron.js",
          "start:dev": ".\\node_modules\\.bin\\electron js\\electron.js dev",
          S 1 Reply Last reply Sep 17, 2024, 1:26 AM Reply Quote 0
            sdetweil @swvalenti
            @swvalenti so, if you look does the path exist?
            you didn’t use my script on windows
            did you run the 3 npm installs?
            S 1 Reply Last reply Sep 17, 2024, 1:45 AM Reply Quote 0
              @sdetweil yea I ran the 3 npm scripts. Never had to change the path on prior so I assumed that would still be the case. You mean c:user etc?
              S 1 Reply Last reply Sep 17, 2024, 2:40 AM Reply Quote 0
                sdetweil @swvalenti
                @swvalenti no, in the MagicMirror folder is there a node_modules folder, etc
                S 1 Reply Last reply Sep 17, 2024, 11:15 AM Reply Quote 0
                  @sdetweil there is not a node_modules folder
                  S 1 Reply Last reply Sep 17, 2024, 11:43 AM Reply Quote 0
                    sdetweil @swvalenti
                    @swvalenti so the
                    npm run install-mm
                      @sdetweil thanks sam that worked
                      • S sdetweil has marked this topic as solved on Sep 17, 2024, 1:55 PM
