    'DISPLAY' is not recognized... on Windows 10
    9 Posts 3 Posters 2.1k Views 2 Watching
      dj94506
      This is my first stab at installing MagicMirror2. I’m on Windows 10. The installation was a straightforward, only default options, i.e., a click-click-click process that seems to have done its thing.
      Then, this happened:
      $ npm start
      magicmirror@2.25.0 start
      ‘DISPLAY’ is not recognized as an internal or external command,
      operable program or batch file.
      I’m aware of the DISPLAY:0 game in the UNIX world; however, I haven’t encountered it in the Windows. Any suggestions for a semi-skilled newbie would be deeply appreciated.
      Thanks in advance.
        sdetweil @swvalenti
        @swvalenti so the
        npm run install-mm
        was not done or not successful
        swvalentiS 1 Reply Last reply Reply Quote 0
          sdetweil @dj94506
          @dj94506 you did not follow all the instructions
          • swvalentiS Offline
            swvalenti Project Sponsor @sdetweil
            Upgraded on windows 10 using sam script. Changed the package.json but I am getting the below error. Any ideas
            > magicmirror@2.28.0 start
            > .\node_modules\.bin\electron js\electron.js
            The system cannot find the path specified.
            Below are the start lines per documentation
            "start": ".\\node_modules\\.bin\\electron js\\electron.js",
            "start:dev": ".\\node_modules\\.bin\\electron js\\electron.js dev",
              sdetweil @swvalenti
              @swvalenti so, if you look does the path exist?
              you didn’t use my script on windows
              did you run the 3 npm installs?
                @sdetweil yea I ran the 3 npm scripts. Never had to change the path on prior so I assumed that would still be the case. You mean c:user etc?
                  sdetweil @swvalenti
                  @swvalenti no, in the MagicMirror folder is there a node_modules folder, etc
                    @sdetweil there is not a node_modules folder
                      sdetweil @swvalenti
                      @swvalenti so the
                      npm run install-mm
                        @sdetweil thanks sam that worked
