    'DISPLAY' is not recognized... on Windows 10
    9 Posts 3 Posters 2.0k Views 2 Watching
      sdetweil @swvalenti
      @swvalenti so, if you look does the path exist?
      you didn’t use my script on windows
      did you run the 3 npm installs?
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @sdetweil
        @sdetweil yea I ran the 3 npm scripts. Never had to change the path on prior so I assumed that would still be the case. You mean c:user etc?
          sdetweil @swvalenti
          @swvalenti no, in the MagicMirror folder is there a node_modules folder, etc
            @sdetweil there is not a node_modules folder
              sdetweil @swvalenti
              @swvalenti so the
              npm run install-mm
              was not done or not successful
                @sdetweil thanks sam that worked
