    MMM-OpenWeatherForecast Error 401
    6 Posts 4 Posters 1.5k Views 5 Watching
      dcazman
      Re: MMM-OpenWeatherForecast Error 401
      I get this problem.
      git remote -v
      origin  https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
      origin  https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (push)
      			module: "MMM-OpenWeatherForecast",
      			position: "bottom_right",
      			header: "Forecast",
                      api_key: "KEY",
      				lat: 40.***,
      				lon: -74.***,
      				units: "imperial",
      				concise: true,
      				showFeelsLikeTemp: true,
      				iconset: "5c",
      				colored: true,
      				extraCurrentConditions: {
      					highLowTemp: true,
      					precipitation: true,
      					wind: true,
      					barometricPressure: false,
      					humidity: true,
      					dewPoint: false,
      					uvIndex: false,
      					visibility: false
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @dcazman
        @dcazman There is a working fork: https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
        D 1 Reply Last reply Reply Quote 2
          sdetweil @dcazman
          @dcazman yes, this module is broken because it does not use the new openweather.org 3.0 api call
          please use one of the openweathermap modules
              dcazman @KristjanESPERANTO
              @KristjanESPERANTO said in MMM-OpenWeatherForecast Error 401:
              I think this is the fork I used.
              KristjanESPERANTOK 1 Reply Last reply Reply Quote -1
              • D dcazman has marked this topic as solved on
                @dcazman said in MMM-OpenWeatherForecast Error 401:
                According to your first post (output of git remote -v) you use the repository of jclarke0000.
                  dherl0623
                  Use Tom Hirschberger’s fork https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast it works great!
                  You need to put in payment information to subscribe to the new 3.0 API, but once you do that, it will work (it took about 30 minutes or so for it to work properly on my end) Thank you to Tom for providing this updated version! Got the email about the old API being discontinued, and I knew I’d need to look around for a working fork.
