    MMM-OpenWeatherForecast Error 401
    15 Posts 4 Posters 5.4k Views 4 Watching
    • V Offline
      Vauxdvihl
      Hi all,
      i am getting crazy to bring this module to work.
      I always get the Error Message
      “Request failed with status 401”
      What have i done so far:
      • check if the api code works
      api.openweathermap.org/data/2.5/weather?q=peshawar&appid=API_key
      Works perfect ( in meanwhile i have 3 api codes = > all of them works fine)
      • change in the “MMM-OpenWeatherForecast.js” the version from 2.5 to 3.0
      Is there sonthings else what i can do
      Thanks for your help
      BR
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
        sdetweil @Vauxdvihl
        @Vauxdvihl yes openweather announced that they have terminated support for the 2.5 api and keys
        you must now get a v3 key, which
        requires supplying a credit card.
        the 1st 1000 requests a day are not charged, according to their Web pages
        you must also use the /onecall endpoint.
        we will update the module for the July 1 release
        • V Offline
          Vauxdvihl
          Ok
          Somehow strange
          The API key in the default weather module works
          Thx for your feedback
            sdetweil @Vauxdvihl
            @Vauxdvihl 401 is access denied.
            • KristjanESPERANTOK Offline
              KristjanESPERANTO Module Developer @Vauxdvihl
              @Vauxdvihl Are you using the fork from Tom-Hirschberger?
              • V Offline
                Vauxdvihl @KristjanESPERANTO
                @KristjanESPERANTO
                No…hmm i don’t know
                Can you guide me?
                Thx
                • V Offline
                  Vauxdvihl
                  For this is also really spuky
                  Using the default weather module with my api key
                  Config “OpenweatherMap”
                  Everything runs fine
                  Using the “MMM-OpenWeatherMapForecast” i get the error meassage 401
                  Strange…
                  kayakbabeK 1 Reply Last reply Reply Quote 0
                    @Vauxdvihl said in MMM-OpenWeatherForecast Error 401:
                    Can you guide me?
                    Try git remote -v in the module’s directory.
                    • V Offline
                      @KristjanESPERANTO
                      no change
                      Still error
                        sdetweil @Vauxdvihl
                        @Vauxdvihl that command will output which repo the module came from
                        please show the output
                        V 1 Reply Last reply Reply Quote 1
                        • V Offline
                          Vauxdvihl @sdetweil
                          Here ue are
                          @raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherForecast $ git remote -v
                          origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch)
                          origin	https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
                            @Vauxdvihl Okay, so that shows us that you’re using the right fork 👍 Let’s see the part of config.js for this module (without API key, of course).
                            • V Offline
                              @KristjanESPERANTO
                              Thank you
                              		module: "MMM-OpenWeatherForecast",
                              		//header: "Wetter Berlin", // Optional header
                              		classes: "default everyone",
                              		disabled: false,
                              			apikey: "key",
                              			latitude: "51.xxxxx",
                              			longitude: "-0.xxxxx",
                              			iconset: "2c",
                              			concise: true,
                              			showWind: false,
                              			displayKmhForWind: true,
                              			animatedIconStartDelay: 2000,
                              			label_timeFormat: "HH:mm",
                              			forecastLayout: "tiled",
                              			forecastHeaderText: "",
                              			label_sunriseTimeFormat: "HH:mm",
                              			maxHourliesToShow: 0,
                              			maxDailiesToShow: 4,
                              			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
                              • kayakbabeK Offline
                                kayakbabe @Vauxdvihl
                                @Vauxdvihl openweathermap discontinued their 2.5 api. so the url in the module might be wrong. Check the configuration possibilities for your module and see if you can choose the 3.0 api.
                                V 1 Reply Last reply Reply Quote 2
                                • V Offline
                                  Vauxdvihl @kayakbabe
                                  @kayakbabe
                                  I do not check your answer
                                  While having the default weather module running with “openweathermap” as the source for the datas, everthing runs fine.
                                  And the default module uses according to their css file also the 2.5.
                                  I was also switching the “MMM-OpenWeatherForecast” css to 3.0.
                                  Nothing changed
