    Calendar shows late day events on next day but at correct time
    35 Posts 4 Posters 12.2k Views 6 Watching
      sdetweil @natmash
      @natmash can you turn on debug
      add
       ,"DEBUG"
      to the logLevel list in config.js
      redirect the output of npm start to a file
      npm start >somefile.txt
        @natmash
        and maybe post one event from your cal ics file which demonstrates the issue
          MMRIZE @natmash
          @natmash @sdetweil
          It seems a bug on the default calendar module. One of my CX3 user also reported it so I looked inside.
          https://github.com/MMRIZE/MMM-CalendarExt3/discussions/146#discussioncomment-9380307
            sdetweil @MMRIZE
            @MMRIZE i expect so, I’d like to see the event from the ics to see what we can do
            • N Offline
              natmash
              BEGIN:VEVENT
              CREATED:20240904T053053Z
              DTEND;TZID=America/Chicago:20240910T211500
              DTSTAMP:20240925T005517Z
              DTSTART;TZID=America/Chicago:20240910T201500
              LAST-MODIFIED:20240925T005515Z
              RELATED-TO;RELTYPE=X-CALENDARSERVER-RECURRENCE-SET:2D48CA37-FCE5-4E16-871
              9-1F47160BDBA3
              RRULE:FREQ=WEEKLY;UNTIL=20250601T011500Z
              SEQUENCE:3
              SUMMARY:Wife Barre Class
              UID:39669340-7AFD-4685-9BD6-6CE4B715486E
              X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
              END:VEVENT
              S 2 Replies Last reply Reply Quote 1
                sdetweil @natmash
                @natmash thanks
                • N Offline
                  natmash
                  Barre Class, with dates: ["2024-09-11T01:15:00.000Z","2024-09-18T01:15:00.000Z","2024-09-25T01:15:00.000Z","2024-10-02T01:15:00.000Z","2024-10-09T01:15:00.000Z","2024-10-16T01:15:00.000Z","2024-10-23T01:15:00.000Z","2024-10-30T01:15:00.000Z","2024-11-06T01:15:00.000Z","2024-11-13T01:15:00.000Z","2024-11-20T01:15:00.000Z","2024-11-27T01:15:00.000Z","2024-12-04T01:15:00.000Z","2024-12-11T01:15:00.000Z","2024-12-18T01:15:00.000Z","2024-12-25T01:15:00.000Z","2025-01-01T01:15:00.000Z","2025-01-08T01:15:00.000Z","2025-01-15T01:15:00.000Z","2025-01-22T01:15:00.000Z","2025-01-29T01:15:00.000Z","2025-02-05T01:15:00.000Z","2025-02-12T01:15:00.000Z","2025-02-19T01:15:00.000Z","2025-02-26T01:15:00.000Z","2025-03-05T01:15:00.000Z","2025-03-12T01:15:00.000Z","2025-03-19T01:15:00.000Z","2025-03-26T01:15:00.000Z","2025-04-02T01:15:00.000Z","2025-04-09T01:15:00.000Z","2025-04-16T01:15:00.000Z","2025-04-23T01:15:00.000Z","2025-04-30T01:15:00.000Z","2025-05-07T01:15:00.000Z","2025-05-14T01:15:00.000Z","2025-05-21T01:15:00.000Z","2025-05-28T01:15:00.000Z"]
                  [2024-09-28 11:26:06.920] [DEBUG] Rule has byweekday, checking for correction
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 10 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 17 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 24 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 01 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 08 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 15 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 22 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 29 2024 20:15:00 GMT-0500 (Central Daylight Time)
                  [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 6) and hour=19 >= 24-6, Adding 1 day to Tue Nov 05 2024 19:15:00 GMT-0600 (Central Standard Time)
                    sdetweil @natmash
                    @natmash yes… code I put in to fix another bug, in the repeating rule parser… it used to return the day prior UTC date and right time… so I adjusted it.
                    now in this one case it returns the correct UTC date…
                    if I fix this it breaks other testcases…
                    looking for another option
                      sdetweil @natmash
                      @natmash so, I think I finally have a fix for this.
                      Would you like to try it?
                      Which MagicMirror version are you using?
                        MarcLandis Module Developer @sdetweil
                        @sdetweil I am going to test your fix with my calendar too, as it was the cause for the initial fix.
                          sdetweil @MarcLandis
                          @MarcLandis you want it on 2.28 or 2.29?
                            @sdetweil 2.29 please
                            (2.28 is too old :) )
                              @MarcLandis understood, but I don’t want to force upgrade to test
                                @MarcLandis @natmash
                                here is a test version of the fixes for all kinds of calendar date problems.
                                best to make a new folder and git clone there
                                git  clone https://github.com/sdetweil/MagicMirror
                                cd MagicMirror
                                git checkout fixcaldates
                                npm run install-mm
                                copy your config.js and custom.css from the prior folder
                                and the non-default modules you have installed…
                                this ONLY changes the default calendar
                                but DOES ship an updated node-ical library too
                                if you need to fall back, just rename the folders around again so that
                                your original is called MagicMirror
                                all the testcases for node-ical and MagicMirror execute successfully.
                                the ‘BIG’ change here is to get the local NON-TZ dates for the
                                rrule.between()
                                all the checking and conversion code is commented out or not used
                                the node-ical fixes are for excluded dates (exdate) values being adjusted for DST/STD time… waiting to submit that PR
                                one fix in calendar.js for checking if a past date was too far back,
                                but it never checked to see IF the event date was in the past… (before today) so it chopped off too many
                                and one change in calendarfetcher.js to put out a better diagnostic message of the parsed data… (exdate was excluded cause JSON stringify couldn’t convert the complex structure)
                                  @sdetweil I testet your branch and so far it looks good with my test calendar and also with my real ones.
                                    @MarcLandis thanks. i still have some reported issues. so use it and let me know. will advise when i make nect updates
                                    we wouldn’t release til jan anyhow, so we have time
                                      sdetweil @natmash
                                      @natmash please see my latest test update this entry is now added to the testcases run
                                      (I had NOT fixed it before today)
                                        @MarcLandis can you retest at your convenience
                                        git pull and npm run install-mm
                                        • N Offline
                                          natmash @sdetweil
                                          @sdetweil I pulled down and started it up. Indeed the entries show up on the correct days, but now the entries that were right time, wrong day, are right day, wrong time (offset).
                                            sdetweil @natmash
                                            @natmash did you do that pull before today? cause it was broken yesterday
                                            not now…
                                            and requires the updated node-ical ., so npm install too…
