    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 14.4k Views 8 Watching
      JMac @karsten13
      @karsten13 how do I update this specifically.
      Everything was working fine prior to the latest MM update.
        JMac @butchkemper
        @butchkemper Is this the default weather module or an additional one?
          sdetweil @JMac
          @JMac if you had used my upgrade script, it would have upgraded node as well
          see https://github.com/sdetweil/MagicMirror_scripts
          you can use the upgrade again with the parameter of
          force
          instead of
          apply
            JMac @sdetweil
            So I’ve run your update, and the weather still doesn’t load.
            Seems odd that the API issue would only arise following the update.
            Is this likely?
              sdetweil @JMac
              @JMac the provider announced that the old 2.5 API would be sunset in June of this year… we didn’t get that update into the last version…
              v3.0 is the ONLY one we provide default for…
              starting with MM version 2.29
              you MUST get a new v3 api key , which requires a credit card.
              the 1st 1000 calls to the new api are currently not charged
                JMac @sdetweil
                @sdetweil So I’ve upgraded to my account on OpenWeather (and added payment details.
                Generated a new APIkey and added this to the config of the weather module but it is still stuck on loading.
                  sdetweil @JMac
                  @JMac can you look at the messages from npm start
                  the ‘loading…’ message is just to have something on the screen until data arrives
                  and as such it didn’t arrive.
                  can u post the module config (xxx out your apiKey)
                    Peter @sdetweil
                    @sdetweil same problem here.
                    Upgraded my Openweather account, added paymentdetails (seemed to worked well), generated a new API key (how can I see it is a 3.0 key?)
                    Used your upgrade script, Sam.
                    Entered the new key in my config.
                    Everything works fine except the default weathermodule.
                    Peter
                      Peter @Peter
                      This is my config, maybe somebody can tell me what is wrong?
                      module: "weather",
                      type: "current",
                      locationID: "2759705", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      apiKey: "xxxxxxxxxxxxxxxxxxxxxx"
                      module: "weather",
                      header: "Weersverwachting",
                      colored: true,
                      type: "forecast",
                      apiKey: "xxxxxxxxxxxxxxxxxx"
                        sdetweil @Peter
                        @Peter ok, two things…
                        you ALSO have to add
                        weatherEndpoint: "/onecall",
                        to each config, as this is required for the 3.0 api
                        this makes it work with my 3.0 apikey
                        second,
                        in the forum, when you post config, or log info, please use the code block wrapper… else the quotes get changed to workd processing type which JS doesn’t understand
                        to do
                        paste the text into the editor, blank line above and below
                        select the text just pasted
                        hit the </> button above the editor
                        P J 2 Replies Last reply Reply Quote 2
                          pritikin71 @sdetweil
                          @sdetweil Thanks, You solve a 2 weeks headache problem wit this line:
                          weatherEndpoint: “/onecall”,
                            JMac @sdetweil
                            @sdetweil so my config was identical to above, so I’ve added you new line “weatherEndpoint…”
                            I’m using Putty to access the MM and used pm2 to stop the MM.
                            which it did.
                            However now, pm2 via Putty is no longer having any effect on the MM.
                            MM isn’t launching.
                            run pm2 logs mm and get a parsing error over adding the new line
                            unexpected token weatherEndpoint your configuration file contains syntax errors.
                            all I’ve added is weatherEndpoint: “/onecall”, to a final line under the apiKey line above.
                            any thoughts?
                            edit to add, pm2 status and logs show that pm2 exists still it’s just not launching. can pm2 be “updated” or should I follow the process for a first install?
                            for completeness I don’t want it to launch MM on boot I just want to be able to start and stop the MM using pm2.
                              sdetweil @JMac
                              @JMac did u have the trailing comma
                              we added code to stop MagicMirror coming up with garbage profile on error
                              J P 2 Replies Last reply Reply Quote 0
                                JMac @sdetweil
                                @sdetweil I have it exactly as you have it above.
                                can you share a config for this module as an example?
                                I can’t even check if this is working with pm2 not launching the MM
                                  sdetweil @JMac
                                  @JMac
                                  npm start
                                    Peter @sdetweil
                                    @sdetweil Adding ‘weatherEndpoint: “/onecall”,’’ gives some kind of weather, but for the wrong location I presume (26C but it is only 15C here).
                                    So, location ID does not work with API 3.0; it worked with 2.5.
                                    Somebody have the solution?
                                    Lat/ Lon?
                                    Peter
                                      JMac @sdetweil
                                      > magicmirror@2.29.0 start
                                      [2024-10-08 19:41:58.640] [LOG]   Starting MagicMirror: v2.29.0
                                      [2024-10-08 19:41:58.693] [LOG]   Loading config ...
                                      [2024-10-08 19:41:58.698] [LOG]   config template file not exists, no envsubst
                                      [2024-10-08 19:41:59.497] [INFO]  Checking config file /home/MagicMirror/MagicMirror/config/config.js ...
                                      [2024-10-08 19:41:59.584] [ERROR] Your configuration file contains syntax errors :(
                                      Line 94 column 5: Parsing error: Unexpected token weatherEndpoint
                                      That parsing error is for the new line added in for weatherEndpoint
                                        sdetweil @JMac
                                        @JMac yes, the line before needs a trailing comma
                                          MaXi-XCeL Project Sponsor @Peter
                                          @Peter Found it in the documentation!
                                          Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
                                          https://docs.magicmirror.builders/modules/weather.html#configuration-options
                                          P P 2 Replies Last reply Reply Quote 1
                                            Peter @MaXi-XCeL
                                            @MaXi-XCeL it works!
                                            Thanks,
                                            Peter
